1 - 20 of 25 Posts
The Time Has Come For Me To Replace My Ball Joints, After Calling Many Places I Found That You Can Actually Do That In My Truck Instead Of Replacing The Entire Control Arm, I Was Just Wandering If Any Brand Would Work, Everyone Has Told Me To Go With Moog, But They Are Very Expensive, Should I Caugh Up The Money?
Thanks, Rock Auto Had Them Much Cheaper Than What I Was Looking At
My Friend That Is Putting On The Ball Joints For Me Told Me It Might Be A Good Idea To Go Ahead And Replace My Shocks While Everything Is Torn Apart, I Was Looking A Edelbrock, But I Am Afraid They Will Be Too Soft, As I Do Go Off Road During Hunting Season, But I Am Not Looking For Any 4x4 Shocks, Any Suggestions?
I Have Already Replaced The Idler And Pitman Arm When I Got The Truck, But I Havent Checked My Tie Rods Yet, Any Suggestions On Shocks For A Mainly Street Truck, Dont Want To Lower It But I Do Do Some Street Racing I Know Its A V6 So I Chose My Oppenents Carefull) So I Need A Good Street Set
· The Green Machine
When I was driving my truck 90 miles round trip everyday to work, I got some Monroe Reflex shocks - they were very nice for the street.
Now they've got about 60k miles on 'em, I'll be replacing them.
· ******* SPACESTATION
Go with the Moog. I bought the cheap set last time around and now I need to replace them after only 30,000 miles! :banghead:
You can rent the tools for free (minus the deposit) at Autozone, can be done in about 2-3 hours, less if you have an extra pair of hands or a gopher bitch.
edit: let me know which shocks you go with, I still have my OEM ones and am debating about getting a set of Monroe or going for the Ranchos.
I do off road a lot though.
Discussion Starter · #11 ·
Well, I Know Most Of You Are Muddin Types, But I Found A 2/4 Drop Kit Complete With Shocks And Upper And Lower Control Arms For My Truck Through A Friend For Dirt Cheap, So I Decided To Go With That, Ill Just Have To Use My Dads Z71 For The Rough Stuff, I Am In The Market For An Old Ramcharger 4x4 To Use Strictly As A Hunting Truck So If Yall Know Any Let Me Know
don't take this the wrong way, but with the V6 I think it would work out well lowering it. You have plenty of room in the engine bay to mount all your hydraulic stuff.
And, unless you got gears, the 6 would have a hard time turning 35s.
Discussion Starter · #13 ·
I Dont Plan On Using Hydrolics, I Found A Djm Drop Kit That Uses Shackles For The Rear And Control Arms Anad Springs For The Front, My Current Tires Are 32 Inch Street Tires And I Have An Extra Set Of 33 Inch Coopers I Put On When Going Off Road, I Can Roast The Hell Out Of The 32's Probably B/c Of The Cam, But I Cant Do A Thing With The 33's
Discussion Starter · #14 ·
I Would Love 4.10s But Am Afraid Of What They Would Do To My Mpg
won't hurt it as bad as you think.
what are you turning in O.D. @ 75?
running 70 w 4.11s I'm turning 2100.
Discussion Starter · #16 ·
At 75 I Am At 2000
which tranny do you have? 42RE or 46RE?
Either way, you have a final drive ratio (o.d.) of .69:1
Installing a set of 4.11s isn't going to kill your highway MPG, and will help you city MPG.
The mileage on my Ram went up by about 2 on the highway and 4 in the city.
I was getting 9 city 13 highway with 3.55s and 33s. I now get 12-13 city and solid 16 on highway. With the 35s I get about 10 city and I dont drive them on the highway.
Yeah i have noticed similar results after going from 3.55:1 to 4.1:1 my city mpg increased a little bit maybe 1mpg, as for highway i'm not really sure because I rarely drive on the highway enough to get any useful numbers. When I am on the highway I'm at around 2250rpms at 75MPH and a hair under 2k at 65MPH, only a 250rpm increase not to bad.
by the way final drive ratio = rear end ratio. ;)
Discussion Starter · #19 ·
I Have The 42 Re, But Are 4.11's So Low That They Will Kill My Highway Performance, Say When I Want To Punch At 70, Will I Still Get The Nice Kick That I Get Now?
it will raise the rpms in all gears by about 250-350, so it's not that big of a difference on the highway.
BUT, it's a lot easier to get the truck moving from a stop (city driving).
And it will prolong the life of your tranny, if you drive it right.
no, it will not hurt you highway performance, if anything it will help it since the engine & tranny will have more of a mechanical advantage.
1 - 20 of 25 Posts
