are you getting the m1 or the edlebrock airgap ??
I already have the M1 so I will give that a try next. Right now with the way it is I cannot do a burnout. The engine will not push enough. I got the truck to do a burn out once. It took a while to get the revs up but once it hit 2500 rpm WOW it hit hard. I left a huge patch. I will have to go back and take pictures.
The only reason I can explain for the lack of low end power is the fact that I ended up reusing the old timing chain since I broke the new one. So the cam could be retarded a few degrees.
I have a new chain, I finally have the retainers. So I can install the new higher lift springs and 1.7 rr along with the M1.
I am sure a computer tune would help also...but when it comes to mailing stuff I am such a procrastinator. I already paid for a tune I just have to send the computer in.
Speaking of tuning which do you think I should send in the stock computer or the MP computer. I still need to pass emission so I am worried that the new tune will not pass and if it does not pass which would I have a better chance at passing with the MP or stock ?
