21 - 40 of 46 Posts
Tricked out Ram
Discussion Starter #21
cool.
dl the 08 TSB and one of the sites many pop ups triggered AVG which blocked 2 viruses!
ok... codes are good... now if i could get some help finding and OBD-II data link connector wiring diagram for my '02 1500 4.7 so i can put my connector on and get this little piggy inspected... is there a thread that will help with this???
Tricked out Ram
Discussion Starter #25
Here you go
awesome, thank you weedahoe.... now maybe i'll get this lil piggy inspected before the farmer gets to market man... LMAO.... NO, I AM NOT A FARMER....
weedahoe, Im sure it is already posted somewhere on here but you might add the key trick to your first post to let everyone know how to check their codes without having to go to autozone...
1.Turn the engine off, then turn the key ON, OFF, ON, OFF, ON without starting the engine.
2. The odometer display will start flashing codes in about 3 second intervals. (if you have more than one code tripping)
3. Write them down, the display will read doNE when it's finished.
Saved me a few trips!
Should work for all the rams, maybe more, I dont know...but it for sure works for the 02-05s.
Tricked out Ram
Discussion Starter #28
Yeah but for some reason it doesnt work on 04s I know. IDK about others honestly. Being I personally have always had a tuner i never bothered to learn that trick.
THX though for the insight.
Hmm... well, guess I cant say I know for sure then; either way, never hurts to try right?
Tricked out Ram
Discussion Starter #30
Thats right, never hurts to try.
Motörhead For Life!
From 2003 FSM.
Chrysler/Dodge DTC Code Interpretation
Code Description
P0001 Fuel Volume Regulator Control Circuit / Open
P0002 Fuel Volume Regulator Control Circuit Range/Performance
P0003 Fuel Volume Regulator Control Circuit Low
P0004 Fuel Volume Regulator Control Circuit High
P0005 Fuel Shutoff Valve A Control Circuit / Open
P0006 Fuel Shutoff Valve A Control Circuit Low
P0007 Fuel Shutoff Valve A Control Circuit High
P0008 Engine Position System Performance - Bank 1
P0009 Engine Position System Performance - Bank 2
P0010 Intake Camshaft Position Actuator Circuit / Open (Bank 1)
P0011 Intake Camshaft Position Timing - Over-Advanced (Bank 1)
P0012 Intake Camshaft Position Timing - Over-Retarded (Bank 1)
P0013 Exhaust Camshaft Position Actuator Circuit / Open (Bank 1)
P0014 Exhaust Camshaft Position Timing - Over-Advanced (Bank 1)
P0015 Exhaust Camshaft Position Timing - Over-Retarded (Bank 1)
P0016 Crankshaft Position - Camshaft Position Correlation - Bank 1 Sensor A
P0017 Crankshaft Position - Camshaft Position Correlation - Bank 1 Sensor B
P0018 Crankshaft Position - Camshaft Position Correlation - Bank 2 Sensor A
P0019 Crankshaft Position - Camshaft Position Correlation - Bank 2 Sensor B
P0020 Intake Camshaft Position Actuator Circuit / Open (Bank 2)
P0021 Intake Camshaft Position Timing - Over-Advanced (Bank 2)
P0022 Intake Camshaft Position Timing - Over-Retarded (Bank 2)
P0023 Exhaust Camshaft Position Actuator Circuit / Open (Bank 2)
P0024 Exhaust Camshaft Position Timing - Over-Advanced (Bank 2)
P0025 Exhaust Camshaft Position Timing - Over-Retarded (Bank 2)
P0026 Intake Valve Control Solenoid Circuit Range/Performance (Bank 1)
P0027 Exhaust Valve Control Solenoid Circuit Range/Performance (Bank 1)
P0028 Intake Valve Control Solenoid Circuit Range/Performance (Bank 2)
P0029 Exhaust Valve Control Solenoid Circuit Range/Performance (Bank 2)
P0030 HO2S Heater Control Circuit (Bank 1, Sensor 1)
P0031 HO2S Heater Control Circuit Low (Bank 1, Sensor 1)
P0032 HO2S Heater Control Circuit High (Bank 1, Sensor 1)
P0033 Turbo/Super Charger Bypass Valve Control Circuit / Open
P0034 Turbo/Super Charger Bypass Valve Control Circuit Low
P0035 Turbo/Super Charger Bypass Valve Control Circuit High
P0036 HO2S Heater Control Circuit (Bank 1, Sensor 2)
P0037 HO2S Heater Control Circuit Low (Bank 1, Sensor 2)
P0038 HO2S Heater Control Circuit High (Bank 1, Sensor 2)
P0039 Turbo/Super Charger Bypass Valve Control Circuit Range/Performance
P0040 Oxygen Sensor Signals Swapped Bank 1 Sensor 1 / Bank 2 Sensor 1
P0041 Oxygen Sensor Signals Swapped Bank 1 Sensor 2 / Bank 2 Sensor 2
P0042 HO2S Heater Control Circuit (Bank 1, Sensor 3)
P0043 HO2S Heater Control Circuit Low (Bank 1, Sensor 3)
P0044 HO2S Heater Control Circuit High (Bank 1, Sensor 3)
P0045 Turbo/Super Charger Boost Control Solenoid Circuit / Open
P0046 Turbo/Super Charger Boost Control Solenoid Circuit Range/Performance
P0047 Turbo/Super Charger Boost Control Solenoid Circuit Low
P0048 Turbo/Super Charger Boost Control Solenoid Circuit High
P0049 Turbo/Super Charger Turbine Overspeed
P0050 HO2S Heater Control Circuit (Bank 2, Sensor 1)
P0051 HO2S Heater Control Circuit Low (Bank 2, Sensor 1)
P0052 HO2S Heater Control Circuit High (Bank 2, Sensor 1)
P0053 HO2S Heater Resistance (Bank 1, Sensor 1)
P0054 HO2S Heater Resistance (Bank 1, Sensor 2)
P0055 HO2S Heater Resistance (Bank 1, Sensor 3)
P0056 HO2S Heater Control Circuit (Bank 2, Sensor 2)
P0057 HO2S Heater Control Circuit Low (Bank 2, Sensor 2)
P0058 HO2S Heater Control Circuit High (Bank 2, Sensor 2)
P0059 HO2S Heater Resistance (Bank 2, Sensor 1)
P0060 HO2S Heater Resistance (Bank 2, Sensor 2)
P0061 HO2S Heater Resistance (Bank 2, Sensor 3)
P0062 HO2S Heater Control Circuit (Bank 2, Sensor 3)
P0063 HO2S Heater Control Circuit Low (Bank 2, Sensor 3)
P0064 HO2S Heater Control Circuit High (Bank 2, Sensor 3)
P0065 Air Assisted Injector Control Range/Performance
P0066 Air Assisted Injector Control Circuit or Circuit Low
P0067 Air Assisted Injector Control Circuit High
P0068 MAP / MAF - Throttle Position Correlation
P0069 MAP - Barometric Pressure Correlation
P0070 Ambient Air Temperature Sensor Circuit
P0071 Ambient Air Temperature Sensor Range/Performance
P0072 Ambient Air Temperature Sensor Circuit Low Input
P0073 Ambient Air Temperature Sensor Circuit High Input
P0074 Ambient Air Temperature Sensor Circuit Intermittent/Erratic
P0075 Intake Valve Control Circuit (Bank 1)
P0076 Intake Valve Control Circuit Low (Bank 1)
P0077 Intake Valve Control Circuit High (Bank 1)
P0078 Exhaust Valve Control Circuit (Bank 1)
P0079 Exhaust Valve Control Circuit Low (Bank 1)
P0080 Exhaust Valve Control Circuit High (Bank 1)
P0081 Intake Valve Control Circuit (Bank 2)
P0082 Intake Valve Control Circuit Low (Bank 2)
P0083 Intake Valve Control Circuit High (Bank 2)
P0084 Exhaust Valve Control Circuit (Bank 2)
P0085 Exhaust Valve Control Circuit Low (Bank 2)
P0086 Exhaust Valve Control Circuit High (Bank 2)
P0087 Fuel Rail/System Pressure - Too Low
P0088 Fuel Rail/System Pressure - Too High
P0089 Fuel Pressure Regulator Performance
P0090 Fuel Pressure Regulator Control Circuit
P0091 Fuel Pressure Regulator Control Circuit Low
P0092 Fuel Pressure Regulator Control Circuit High
P0093 Fuel System Leak Detected - Large Leak
P0094 Fuel System Leak Detected - Small Leak
P0095 Intake Air Temperature Sensor 2 Circuit
P0096 Intake Air Temperature Sensor 2 Circuit Range/Performance
P0097 Intake Air Temperature Sensor 2 Circuit Low Input
P0098 Intake Air Temperature Sensor 2 Circuit High Input
P0099 Intake Air Temperature Sensor 2 Circuit Intermittent/Erratic
P0100 Mass or Volume Air Flow Circuit
P0101 Mass or Volume Air Flow Circuit Range/Performance
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/BARO Circuit
P0106 Manifold Absolute Pressure/BARO Sensor Range/Performance
P0107 Manifold Absolute Pressure/BARO Sensor Low Input
P0108 Manifold Absolute Pressure/BARO Sensor High Input
P0109 Manifold Absolute Pressure/BARO Sensor Intermittent
P0110 Intake Air Temperature Sensor 1 Circuit
P0111 Intake Air Temperature Sensor 1 Circuit Range/Performance
P0112 Intake Air Temperature Sensor 1 Circuit Low Input
P0113 Intake Air Temperature Sensor 1 Circuit High Input
P0114 Intake Air Temperature Sensor 1 Intermittent/Erratic
P0115 Engine Coolant Temperature Circuit
P0116 Engine Coolant Temperature Circuit Range/Performance
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent/Erratic
P0120 Throttle/Pedal Position Sensor A Circuit
P0121 Throttle/Pedal Position Sensor A Circuit Range/Performance
P0122 Throttle/Pedal Position Sensor A Circuit Low Input
P0123 Throttle/Pedal Position Sensor A Circuit High Input
P0124 Throttle/Pedal Position Sensor A Intermittent
P0125 Insufficient Coolant Temp For Closed Loop Fuel Control
P0126 Insufficient Coolant Temp For Stable Operation
P0127 Intake Air Temperature Too High
P0128 Coolant Thermostat (Coolant Temp Below Thermostat Regulating Temperature)
P0129 Barometric Pressure Too Low
P0130 O2 Circuit (Bank 1, Sensor 1)
P0131 O2 Circuit Low Voltage (Bank 1, Sensor 1)
P0132 O2 Circuit High Voltage (Bank 1, Sensor 1)
P0133 O2 Circuit Slow Response (Bank 1, Sensor 1)
P0134 O2 Circuit No Activity Detected (Bank 1, Sensor 1)
P0135 O2 Heater Circuit (Bank 1, Sensor 1)
P0136 O2 Circuit (Bank 1, Sensor 2) (See P2270, P2271)
P0137 O2 Circuit Low Voltage (Bank 1, Sensor 2)
P0138 O2 Circuit High Voltage (Bank 1, Sensor 2)
P0139 O2 Circuit Slow Response (Bank 1, Sensor 2)
P0140 O2 Circuit No Activity Detected (Bank 1, Sensor 2)
P0141 O2 Heater Circuit (Bank 1, Sensor 2)
P0142 O2 Circuit (Bank 1, Sensor 3)
P0143 O2 Circuit Low Voltage (Bank 1, Sensor 3)
P0144 O2 Circuit High Voltage (Bank 1, Sensor 3)
P0145 O2 Circuit Slow Response (Bank 1, Sensor 3)
P0146 O2 Circuit No Activity Detected (Bank 1, Sensor 3)
P0147 O2 Heater Circuit (Bank 1, Sensor 3)
P0148 Fuel Delivery Error
P0149 Fuel Timing Error
P0150 O2 Circuit (Bank 2, Sensor 1)
P0151 O2 Circuit Low Voltage (Bank 2, Sensor 1)
P0152 O2 Circuit High Voltage (Bank 2, Sensor 1)
P0153 O2 Circuit Slow Response (Bank 2, Sensor 1)
P0154 O2 Circuit No Activity Detected (Bank 2, Sensor 1)
P0155 O2 Heater Circuit (Bank 2, Sensor 1)
P0156 O2 Circuit (Bank 2, Sensor 2) (See P2272, P2273)
P0157 O2 Circuit Low Voltage (Bank 2, Sensor 2)
P0158 O2 Circuit High Voltage (Bank 2, Sensor 2)
P0159 O2 Circuit Slow Response (Bank 2, Sensor 2)
P0160 O2 Circuit No Activity Detected (Bank 2, Sensor 2)
P0161 O2 Heater Circuit (Bank 2, Sensor 2)
P0162 O2 Circuit (Bank 2, Sensor 3)
P0163 O2 Circuit Low Voltage (Bank 2, Sensor 3)
P0164 O2 Circuit High Voltage (Bank 2, Sensor 3)
P0165 O2 Circuit Slow Response (Bank 2, Sensor 3)
P0166 O2 Circuit No Activity Detected (Bank 2, Sensor 3)
P0167 O2 Heater Circuit (Bank 2, Sensor 3)
P0168 Engine Fuel Temperature Too High
P0169 Incorrect Fuel Composition
P0170 Fuel Trim (Bank 1)
P0171 System Too Lean (Bank 1)
P0172 System Too Rich (Bank 1)
P0173 Fuel Trim (Bank 2)
P0174 System Too Lean (Bank 2)
P0175 System Too Rich (Bank 2)
P0176 Flexible Fuel Sensor Circuit
P0177 Flexible Fuel Sensor Circuit Range/Performance
P0178 Flexible Fuel Sensor Circuit Low Input
P0179 Flexible Fuel Sensor Circuit High Input
P0180 Fuel Temperature Sensor A Circuit
P0181 Fuel Temperature Sensor A Circuit Range/Performance
P0182 Fuel Temperature Sensor A Circuit Low Input
P0183 Fuel Temperature Sensor A Circuit High Input
P0184 Fuel Temperature Sensor A Circuit Intermittent
P0185 Fuel Temperature Sensor B Circuit
P0186 Fuel Temperature Sensor B Circuit Range/Performance
P0187 Fuel Temperature Sensor B Circuit Low Input
P0188 Fuel Temperature Sensor B Circuit High Input
P0189 Fuel Temperature Sensor B Circuit Intermittent
P0190 Fuel Rail Pressure Sensor
P0191 Fuel Rail Pressure Sensor Range/Performance
P0192 Fuel Rail Pressure Sensor Low Input
P0193 Fuel Rail Pressure Sensor High Input
P0194 Fuel Rail Pressure Sensor Intermittent
P0195 Engine Oil Temperature Sensor Circuit
P0196 Engine Oil Temperature Sensor Circuit Range/Performance
P0197 Engine Oil Temperature Sensor Circuit Low Input
P0198 Engine Oil Temperature Sensor Circuit High Input
P0199 Engine Oil Temperature Sensor Circuit Intermittent
P0200 Injector Circuit
P0201 Injector Circuit / Open - Cylinder 1
P0202 Injector Circuit / Open - Cylinder 2
P0203 Injector Circuit / Open - Cylinder 3
P0204 Injector Circuit / Open - Cylinder 4
P0205 Injector Circuit / Open - Cylinder 5
P0206 Injector Circuit / Open - Cylinder 6
P0207 Injector Circuit / Open - Cylinder 7
P0208 Injector Circuit / Open - Cylinder 8
P0209 Injector Circuit / Open - Cylinder 9
P0210 Injector Circuit / Open - Cylinder 10
P0211 Injector Circuit / Open - Cylinder 11
P0212 Injector Circuit / Open - Cylinder 12
P0213 Cold Start Injector 1
P0214 Cold Start Injector 2
P0215 Engine Shutoff Solenoid
P0216 Injector/Injection Timing Control Circuit
P0217 Engine Coolant Overtemperature Condition
P0218 Transmission Fluid Overtemperature Condition
P0219 Engine Overspeed Condition
P0220 Throttle/Pedal Position Switch B Circuit
P0221 Throttle/Pedal Position Switch B Circuit Range/Performance
P0222 Throttle/Pedal Position Sensor B Circuit Low Input
P0223 Throttle/Pedal Position Sensor B Circuit High Input
P0224 Throttle/Pedal Position Sensor B Circuit Intermittent
P0225 Throttle/Pedal Position Sensor C Circuit
P0226 Throttle/Pedal Position Sensor C Circuit Range/Performance
P0227 Throttle/Pedal Position Sensor C Circuit Low Input
P0228 Throttle/Pedal Position Sensor C Circuit High Input
P0229 Throttle/Pedal Position Sensor C Circuit Intermittent
P0230 Fuel Pump Primary Circuit
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Turbo/Super Charger Overboost Condition
P0235 Turbo/Super Charger Boost Sensor A Circuit
P0236 Turbo/Super Charger Boost Sensor A Circuit Range/Performance
P0237 Turbo/Super Charger Boost Sensor A Circuit Low
P0238 Turbo/Super Charger Boost Sensor A Circuit High
P0239 Turbo/Super Charger Boost Sensor B Circuit
P0240 Turbo/Super Charger Boost Sensor B Circuit Range/Performance
P0241 Turbo/Super Charger Boost Sensor B Circuit Low
P0242 Turbo/Super Charger Boost Sensor B Circuit High
P0243 Turbo/Super Charger Wastegate Solenoid A
P0244 Turbo/Super Charger Wastegate Solenoid A Range/Performance
P0245 Turbo/Super Charger Wastegate Solenoid A Low
P0246 Turbo/Super Charger Wastegate Solenoid A High
P0247 Turbo/Super Charger Wastegate Solenoid B
P0248 Turbo/Super Charger Wastegate Solenoid B Range/Performance
P0249 Turbo/Super Charger Wastegate Solenoid B Low
P0250 Turbo/Super Charger Wastegate Solenoid B High
P0251 Injection Pump Fuel Metering Control A
P0252 Injection Pump Fuel Metering Control A Range/Performance
P0253 Injection Pump Fuel Metering Control A Low
P0254 Injection Pump Fuel Metering Control A High
P0255 Injection Pump Fuel Metering Control A Intermittent
P0256 Injection Pump Fuel Metering Control B
P0257 Injection Pump Fuel Metering Control B Range/Performance
P0258 Injection Pump Fuel Metering Control B Low
P0259 Injection Pump Fuel Metering Control B High
P0260 Injection Pump Fuel Metering Control B Intermittent
P0261 Cylinder 1 Injector Circuit Low
P0262 Cylinder 1 Injector Circuit High
P0263 Cylinder 1 Contribution/Balance
P0264 Cylinder 2 Injector Circuit Low
P0265 Cylinder 2 Injector Circuit High
P0266 Cylinder 2 Contribution/Balance
P0267 Cylinder 3 Injector Circuit Low
P0268 Cylinder 3 Injector Circuit High
P0269 Cylinder 3 Contribution/Balance
P0270 Cylinder 4 Injector Circuit Low
P0271 Cylinder 4 Injector Circuit High
P0272 Cylinder 4 Contribution/Balance
P0273 Cylinder 5 Injector Circuit Low
P0274 Cylinder 5 Injector Circuit High
P0275 Cylinder 5 Contribution/Balance
P0276 Cylinder 6 Injector Circuit Low
P0277 Cylinder 6 Injector Circuit High
P0278 Cylinder 6 Contribution/Balance
P0279 Cylinder 7 Injector Circuit Low
P0280 Cylinder 7 Injector Circuit High
P0281 Cylinder 7 Contribution/Balance
P0282 Cylinder 8 Injector Circuit Low
P0283 Cylinder 8 Injector Circuit High
P0284 Cylinder 8 Contribution/Balance
P0285 Cylinder 9 Injector Circuit Low
P0286 Cylinder 9 Injector Circuit High
P0287 Cylinder 9 Contribution/Balance
P0288 Cylinder 10 Injector Circuit Low
P0289 Cylinder 10 Injector Circuit High
P0290 Cylinder 10 Contribution/Balance
P0291 Cylinder 11 Injector Circuit Low
P0292 Cylinder 11 Injector Circuit High
P0293 Cylinder 11 Contribution/Balance
P0294 Cylinder 12 Injector Circuit Low
P0295 Cylinder 12 Injector Circuit High
P0296 Cylinder 12 Contribution/Balance
P0297 Vehicle Overspeed Condition
P0298 Engine Oil Overtemperature Condition
P0299 Turbo / Super Charger Underboost
P0300 Random Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0307 Cylinder 7 Misfire Detected
P0308 Cylinder 8 Misfire Detected
P0309 Cylinder 9 Misfire Detected
P0310 Cylinder 10 Misfire Detected
P0311 Cylinder 11 Misfire Detected
P0312 Cylinder 12 Misfire Detected
P0313 Misfire Detected with Low Fuel
P0314 Single Cylinder Misfire (Cylinder not Specified)
P0315 Crankshaft Position System Variation Not Learned
P0316 Misfire Detected On Startup (First 1000 Revolutions)
P0317 Rough Road Hardware Not Present
P0318 Rough Road Sensor A Signal Circuit
P0319 Rough Road Sensor B Signal Circuit
P0320 Ignition/Distributor Engine Speed Input Circuit
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0324 Knock Control System Error
P0325 Knock Sensor 1 Circuit (Bank 1)
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1)
P0327 Knock Sensor 1 Circuit Low Input (Bank1)
P0328 Knock Sensor 1 Circuit High Input (Bank 1)
P0329 Knock Sensor 1 Circuit Intermittent (Bank 1)
P0330 Knock Sensor 2 Circuit (Bank 2)
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
P0333 Knock Sensor 2 Circuit High Input (Bank 2)
P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
P0335 Crankshaft Position Sensor A Circuit
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P0337 Crankshaft Position Sensor A Circuit Low Input
P0338 Crankshaft Position Sensor A Circuit High Input
P0339 Crankshaft Position Sensor A Circuit Intermittent
P0340 Camshaft Position Sensor A Circuit (Bank 1 or single sensor)
P0341 Camshaft Position Sensor A Circuit Range/Performance (Bank 1 or single sensor)
P0342 Camshaft Position Sensor A Circuit Low Input (Bank 1 or single sensor)
P0343 Camshaft Position Sensor A Circuit High Input (Bank 1 or single sensor)
P0344 Camshaft Position Sensor A Circuit Intermittent (Bank 1 or single sensor)
P0345 Camshaft Position Sensor A Circuit (Bank 2)
P0346 Camshaft Position Sensor A Circuit Range/Performance (Bank 2)
P0347 Camshaft Position Sensor A Circuit Low Input (Bank 2)
P0348 Camshaft Position Sensor A Circuit High Input (Bank 2)
P0349 Camshaft Position Sensor A Circuit Intermittent (Bank 2)
P0350 Ignition Coil Primary/Secondary Circuit
P0351 Ignition Coil A Primary/Secondary Circuit
P0352 Ignition Coil B Primary/Secondary Circuit
P0353 Ignition Coil C Primary/Secondary Circuit
P0354 Ignition Coil D Primary/Secondary Circuit
P0355 Ignition Coil E Primary/Secondary Circuit
P0356 Ignition Coil F Primary/Secondary Circuit
P0357 Ignition Coil G Primary/Secondary Circuit
P0358 Ignition Coil H Primary/Secondary Circuit
P0359 Ignition Coil I Primary/Secondary Circuit
P0360 Ignition Coil J Primary/Secondary Circuit
P0361 Ignition Coil K Primary/Secondary Circuit
P0362 Ignition Coil L Primary/Secondary Circuit
P0363 Misfire Detected - Fueling Disabled
P0365 Camshaft Position Sensor B Circuit (Bank 1)
P0366 Camshaft Position Sensor B Circuit Range/Performance (Bank 1)
P0367 Camshaft Position Sensor B Circuit Low Input (Bank 1)
P0368 Camshaft Position Sensor B Circuit High Input (Bank 1)
P0369 Camshaft Position Sensor B Circuit Intermittent (Bank 1)
P0370 Timing Reference High Resolution Signal A
P0371 Timing Reference High Resolution Signal A Too Many Pulses
P0372 Timing Reference High Resolution Signal A Too Few Pulses
P0373 Timing Reference High Resolution Signal A Intermittent
P0374 Timing Reference High Resolution Signal A No Pulses
P0375 Timing Reference High Resolution Signal B
P0376 Timing Reference High Resolution Signal B Too Many Pulses
P0377 Timing Reference High Resolution Signal B Too Few Pulses
P0378 Timing Reference High Resolution Signal B Intermittent
P0379 Timing Reference High Resolution Signal B No Pulses
P0380 Glow Plug/Heater Circuit A
P0381 Glow Plug/Heater Indicator Circuit
P0382 Glow Plug/Heater Circuit B
P0385 Crankshaft Position Sensor B Circuit
P0386 Crankshaft Position Sensor B Circuit Range/Performance
P0387 Crankshaft Position Sensor B Circuit Low Input
P0388 Crankshaft Position Sensor B Circuit High Input
P0389 Crankshaft Position Sensor B Circuit Intermittent
P0390 Camshaft Position Sensor B Circuit (Bank 2)
P0391 Camshaft Position Sensor B Circuit Range/Performance (Bank 2)
P0392 Camshaft Position Sensor B Circuit Low Input (Bank 2)
P0393 Camshaft Position Sensor B Circuit High Input (Bank 2)
P0394 Camshaft Position Sensor B Circuit Intermittent (Bank 2)
P0400 Exhaust Gas Recirculation Flow
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Control Circuit
P0404 Exhaust Gas Recirculation Control Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
P0406 Exhaust Gas Recirculation Sensor A Circuit High
P0407 Exhaust Gas Recirculation Sensor B Circuit Low
P0408 Exhaust Gas Recirculation Sensor B Circuit High
P0409 Exhaust Gas Recirculation Sensor A Circuit
P0410 Secondary Air Injection System
P0411 Secondary Air Injection Incorrect Upstream Flow Detected
P0412 Secondary Air Injection Switching Valve A Circuit
P0413 Secondary Air Injection Switching Valve A Circuit Open
P0414 Secondary Air Injection Switching Valve A Circuit Shorted
P0415 Secondary Air Injection Switching Valve B Circuit
P0416 Secondary Air Injection Switching Valve B Circuit Open
P0417 Secondary Air Injection Switching Valve B Circuit Shorted
P0418 Secondary Air Injection System Control A Circuit
P0419 Secondary Air Injection System Control B Circuit
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
P0425 Catalyst Temperature Sensor (Bank 1)
P0426 Catalyst Temperature Sensor Range/Performance (Bank1)
P0427 Catalyst Temperature Sensor Low Input (Bank 1)
P0428 Catalyst Temperature Sensor High Input (Bank 1)
P0429 Catalyst Heater Control Circuit (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
P0435 Catalyst Temperature Sensor (Bank 2)
P0436 Catalyst Temperature Sensor Range/Performance (Bank2)
P0437 Catalyst Temperature Sensor Low Input (Bank 2)
P0438 Catalyst Temperature Sensor High Input (Bank 2)
P0439 Catalyst Heater Control Circuit (Bank 2)
P0440 Evaporative Emission System
P0441 Evaporative Emission System Incorrect Purge Flow
P0442 Evaporative Emission System Leak Detected (small leak)
P0443 Evaporative Emission System Purge Control Valve Circuit
P0444 Evaporative Emission System Purge Control Valve Circuit Open
P0445 Evaporative Emission System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission System Vent Control Circuit
P0447 Evaporative Emission System Vent Control Circuit Open
P0448 Evaporative Emission System Vent Control Circuit Shorted
P0449 Evaporative Emission System Vent Control Circuit Intermittent
P0450 Evaporative Emission System Pressure Sensor/Switch
P0451 Evaporative Emission System Pressure Sensor/Switch Range/Performance
P0452 Evaporative Emission System Pressure Sensor/Switch Low Input
P0453 Evaporative Emission System Pressure Sensor/Switch High Input
P0454 Evaporative Emission System Pressure Sensor/Switch Intermittent
P0455 Evaporative Emission System Leak Detected (gross leak/no flow)
P0456 Evaporative Emission System Leak Detected (very small leak)
P0457 Evaporative Emission System Leak Detected (fuel cap loose/off)
P0458 Evaporative Emission System Purge Control Valve Circuit Low
P0459 Evaporative Emission System Purge Control Valve Circuit High
P0460 Fuel Level Sensor A Circuit
P0461 Fuel Level Sensor A Circuit Range/Performance
P0462 Fuel Level Sensor A Circuit Low Input
P0463 Fuel Level Sensor A Circuit High Input
P0464 Fuel Level Sensor A Circuit Intermittent
P0465 Evaporative Emission System Purge Flow Sensor Circuit
P0466 Evaporative Emission System Purge Flow Sensor Circuit Range/Performance
P0467 Evaporative Emission System Purge Flow Sensor Circuit Low Input
P0468 Evaporative Emission System Purge Flow Sensor Circuit High Input
P0469 Evaporative Emission System Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low Input
P0473 Exhaust Pressure Sensor High Input
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low Input
P0478 Exhaust Pressure Control Valve High Input
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Fan 1 Control Circuit
P0481 Fan 2 Control Circuit
P0482 Fan 3 Control Circuit
P0483 Fan Performance
P0484 Fan Current
P0485 Fan Power/Ground Circuit
P0486 Exhaust Gas Recirculation Sensor B Circuit
P0487 EGR Throttle Position Control Circuit
P0488 EGR Throttle Position Control Range/Performance
P0489 Exhaust Gas Recirculation Control Circuit Low
P0490 Exhaust Gas Recirculation Control Circuit High
P0491 Secondary Air Injection System Insufficient Flow (Bank 1)
P0492 Secondary Air Injection System Insufficient Flow (Bank 2)
P0493 Fan Overspeed (clutch locked)
P0494 Fan Speed Low
P0495 Fan Speed High
P0496 Evaporative Emission System High Purge Flow
P0497 Evaporative Emission System Low Purge Flow
P0498 Evaporative Emission System Vent Control Circuit Low
P0499 Evaporative Emission System Vent Control Circuit High
P0500 Vehicle Speed Sensor A
P0500 Vehicle Speed Signal Not Detected
P0501 Vehicle Speed Sensor A Range/Performance
P0502 Vehicle Speed Sensor A Circuit Low Input
P0503 Vehicle Speed Sensor A Intermittent/Erratic/High
P0504 Brake Switch A / B Correlation
P0505 Idle Air Control System
P0506 Idle Air Control System RPM Lower Than Expected
P0507 Idle Air Control System RPM Higher Than Expected
P0508 Idle Air Control System Circuit Low
P0509 Idle Air Control System Circuit High
P0510 Closed Throttle Position Switch
P0511 Idle Air Control Circuit
P0512 Starter Request Circuit
P0513 Incorrect Immobilizer Key
P0514 Battery Temperature Sensor Circuit Range/Performance
P0515 Battery Temperature Sensor Circuit
P0516 Battery Temperature Sensor Circuit Low
P0517 Battery Temperature Sensor Circuit High
P0518 Idle Air Control Circuit Intermittent
P0519 Idle Air Control Circuit System Performance
P0520 Engine Oil Pressure Sensor/Switch Circuit
P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Input
P0523 Engine Oil Pressure Sensor/Switch Circuit High Input
P0524 Engine Oil Pressure Too Low
P0525 Cruise Control Servo Control Circuit Range/Performance
P0526 Fan Speed Sensor Circuit
P0527 Fan Speed Sensor Circuit Range/Performance
P0528 Fan Speed Sensor Circuit No Signal
P0529 Fan Speed Sensor Circuit Intermittent
P0530 A/C Refrigerant Pressure Sensor A Circuit
P0531 A/C Refrigerant Pressure Sensor A Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor A Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor A Circuit High Input
P0534 A/C Refrigerant Charge Loss
P0535 A/C Evaporator Temperature Sensor Circuit
P0536 A/C Evaporator Temperature Sensor Circuit Range/Performance
P0537 A/C Evaporator Temperature Sensor Circuit Low
P0538 A/C Evaporator Temperature Sensor Circuit High
P0539 A/C Evaporator Temperature Sensor Circuit Intermittent
P0540 Intake Air Heater A Circuit
P0541 Intake Air Heater A Circuit Low
P0542 Intake Air Heater A Circuit High
P0543 Intake Air Heater A Circuit Open
P0544 Exhaust Gas Temperature Sensor Circuit - Bank 1 Sensor 1
P0545 Exhaust Gas Temperature Sensor Circuit Low - Bank 1 Sensor 1
P0546 Exhaust Gas Temperature Sensor Circuit High - Bank 1 Sensor 1
P0547 Exhaust Gas Temperature Sensor Circuit - Bank 2 Sensor 1
P0548 Exhaust Gas Temperature Sensor Circuit Low - Bank 2 Sensor 1
P0549 Exhaust Gas Temperature Sensor Circuit High - Bank 2 Sensor 1
P0550 Power Steering Pressure Sensor/Switch Circuit
P0551 Power Steering Pressure Sensor/Switch Circuit Range/Performance
P0552 Power Steering Pressure Sensor/Switch Circuit Low Input
P0553 Power Steering Pressure Sensor/Switch Circuit High Input
P0554 Power Steering Pressure Sensor/Switch Circuit Intermittent
P0555 Brake Booster Pressure Sensor Circuit
P0556 Brake Booster Pressure Sensor Circuit Range/Performance
P0557 Brake Booster Pressure Sensor Circuit Low Input
P0558 Brake Booster Pressure Sensor Circuit High Input
P0559 Brake Booster Pressure Sensor Circuit Intermittent
P0560 System Voltage
P0561 System Voltage Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0564 Cruise Control Multi-Function Input A Circuit
P0565 Cruise Control ON Signal
P0566 Cruise Control OFF Signal
P0567 Cruise Control RESUME Signal
P0568 Cruise Control SET Signal
P0569 Cruise Control COAST Signal
P0570 Cruise Control ACCEL Signal
P0571 Brake Switch A Circuit
P0572 Brake Switch A Circuit Low
P0573 Brake Switch A Circuit High
P0574 Cruise Control System - Vehicle Speed Too High
P0575 Cruise Control Input Circuit
P0576 Cruise Control Input Circuit Low
P0577 Cruise Control Input Circuit High
P0578 Cruise Control Multi-Function Input A Circuit Stuck
P0579 Cruise Control Multi-Function Input A Circuit Range/Performance
P0580 Cruise Control Multi-Function Input A Circuit Low
P0581 Cruise Control Multi-Function Input A Circuit High
P0582 Cruise Control Vacuum Control Circuit /Open
P0583 Cruise Control Vacuum Control Circuit Low
P0584 Cruise Control Vacuum Control Circuit High
P0585 Cruise Control Multi-Function Input A / B Correlation
P0586 Cruise Control Vent Control Circuit / Open
P0587 Cruise Control Vent Control Circuit Low
P0588 Cruise Control Vent Control Circuit High
P0589 Cruise Control Multi-Function Input B Circuit
P0590 Cruise Control Multi-Function Input B Circuit Stuck
P0591 Cruise Control Multi-Function Input B Circuit Range/Performance
P0592 Cruise Control Multi-Function Input B Circuit Low
P0593 Cruise Control Multi-Function Input B Circuit High
P0594 Cruise Control Servo Control Circuit / Open
P0595 Cruise Control Servo Control Circuit Low
P0596 Cruise Control Servo Control Circuit High
P0597 Thermostat Heater Control Circuit / Open
P0598 Thermostat Heater Control Circuit Low
P0599 Thermostat Heater Control Circuit High
P0600 Serial Communication Link
P0601 Internal Control Module Memory Check Sum Error
P0602 Powertrain Control Module Programming Error
P0603 Powertrain Control Module Keep Alive Memory (KAM) Error
P0604 Powertrain Control Module Random Access Memory (RAM) Error
P0605 Powertrain Control Module Read Only Memory (ROM) Error
P0606 ECM / PCM Processor
P0607 Control Module Performance
P0608 Powertrain Control Module Vehicle Speed Output A
P0609 Powertrain Control Module Vehicle Speed Output B
P0610 Control Module Vehicle Options Error
P0611 Fuel Injector Control Module Performance
P0612 Fuel Injector Control Module Relay Control Circuit
P0613 TCM Processor
P0614 ECM / TCM Incompatible
P0615 Starter Relay Circuit
P0616 Starter Relay Circuit Low
P0617 Starter Relay Circuit High
P0618 Alternative Fuel Control Module KAM Error
P0619 Alternative Fuel Control Module RAM/ROM Error
P0620 Generator Control Circuit
P0621 Generator Lamp Terminal Circuit
P0622 Generator Field Terminal Circuit
P0623 Generator Lamp Control Circuit
P0624 Fuel Cap Lamp Control Circuit
P0625 Generator Field Terminal Circuit Low
P0626 Generator Field Terminal Circuit High
P0627 Fuel Pump A Control Circuit / Open
P0628 Fuel Pump A Control Circuit Low
P0629 Fuel Pump A Control Circuit High
P0630 VIN Not Programmed or Incompatible - ECM/PCM
P0631 VIN Not Programmed or Incompatible - TCM
P0632 Odometer Not Programmed - ECM/PCM
P0633 Immobolizer Key Not Programmed - ECM/PCM
P0634 PCM / ECM / TCM Internal Temperature Too High
P0635 Power Steering Control Circuit
P0636 Power Steering Control Circuit Low
P0637 Power Steering Control Circuit High
P0638 Throttle Actuator Control Range/Performance - Bank 1
P0639 Throttle Actuator Control Range/Performance - Bank 2
P0640 Intake Air Heater Control Circuit
P0641 Sensor Reference Voltage A Circuit/Open
P0642 Sensor Reference Voltage A Circuit Low
P0643 Sensor Reference Voltage A Circuit High
P0644 Driver Display Serial Communication Circuit
P0645 A/C Clutch Relay Control Circuit
P0646 A/C Clutch Relay Control Circuit Low
P0647 A/C Clutch Relay Control Circuit High
P0648 Immobilizer Lamp Control Circuit
P0649 Cruise Control Lamp Control Circuit
P0650 Malfunction Indicator Light Control Circuit
P0651 Sensor Reference Voltage B Circuit/Open
P0652 Sensor Reference Voltage B Circuit Low
P0653 Sensor Reference Voltage B Circuit High
P0654 Engine RPM Output Circuit
P0655 Engine Hot Lamp Output Control Circuit
P0656 Fuel level Output Circuit
P0657 Actuator Supply Voltage A Circuit / Open
P0658 Actuator Supply Voltage A Circuit Low
P0659 Actuator Supply Voltage A Circuit High
P0660 Intake Manifold Tuning Valve Control Circuit / Open - Bank 1
P0661 Intake Manifold Tuning Valve Control Circuit Low - Bank 1
P0662 Intake Manifold Tuning Valve Control Circuit High - Bank 1
P0663 Intake Manifold Tuning Valve Control Circuit / Open - Bank 2
P0664 Intake Manifold Tuning Valve Control Circuit Low - Bank 2
P0665 Intake Manifold Tuning Valve Control Circuit High - Bank 2
P0666 PCM / ECM / TCM Internal Temperature Sensor Circuit
P0667 PCM / ECM / TCM Internal Temperature Sensor Range/Performance
P0668 PCM / ECM / TCM Internal Temperature Sensor Circuit Low
P0669 PCM / ECM / TCM Internal Temperature Sensor Circuit High
P0670 Glow Plug Module Control Circuit
P0671 Cylinder 1 Glow Plug Circuit
P0672 Cylinder 2 Glow Plug Circuit
P0673 Cylinder 3 Glow Plug Circuit
P0674 Cylinder 4 Glow Plug Circuit
P0675 Cylinder 5 Glow Plug Circuit
P0676 Cylinder 6 Glow Plug Circuit
P0677 Cylinder 7 Glow Plug Circuit
P0678 Cylinder 8 Glow Plug Circuit
P0679 Cylinder 9 Glow Plug Circuit
P0680 Cylinder 10 Glow Plug Circuit
P0681 Cylinder 11 Glow Plug Circuit
P0682 Cylinder 12 Glow Plug Circuit
P0683 Glow Plug Control Module to PCM Communication Circuit
P0684 Glow Plug Control Module to PCM Communication Circuit Range/Performance
P0685 ECM/PCM Power Relay Control Circuit/Open
P0686 ECM/PCM Power Relay Control Circuit Low
P0687 ECM/PCM Power Relay Control Circuit High
P0688 ECM/PCM Power Relay Sense Circuit
P0689 ECM/PCM Power Relay Sense Circuit Low
P0690 ECM/PCM Power Relay Sense Circuit High
P0691 Fan 1 Control Circuit Low
P0692 Fan 1 Control Circuit High
P0693 Fan 2 Control Circuit Low
P0694 Fan 2 Control Circuit High
P0695 Fan 3 Control Circuit Low
P0696 Fan 3 Control Circuit High
P0697 Sensor Reference Voltage C Circuit / Open
P0698 Sensor Reference Voltage C Circuit Low
P0699 Sensor Reference Voltage C Circuit High
P0700 Transmission Control System (MIL Request)
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Brake Switch B Input Circuit
P0704 Clutch Switch Input Circuit
P0705 Transmission Range Sensor A Circuit (PRNDL Input)
P0706 Transmission Range Sensor A Circuit Range/Performance
P0707 Transmission Range Sensor A Circuit Low Input
P0708 Transmission Range Sensor A Circuit High Input
P0709 Transmission Range Sensor A Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor A Circuit
P0711 Transmission Fluid Temperature Sensor A Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor A Circuit Low Input
P0713 Transmission Fluid Temperature Sensor A Circuit High Input
P0714 Transmission Fluid Temperature Sensor A Circuit Intermittent
P0715 Turbine/Input Shaft Speed SensorA Circuit
P0716 Turbine/Input Shaft Speed Sensor A Circuit Range/Performance
P0717 Turbine/Input Shaft Speed Sensor A Circuit No Signal
P0718 Turbine/Input Shaft Speed Sensor A Circuit Intermittent
P0719 Brake Switch B Input Circuit Low
P0720 Output Shaft Speed Sensor Circuit
P0721 Output Shaft Speed Sensor Circuit Range/Performance
P0722 Output Shaft Speed Sensor Circuit No Signal
P0723 Output Shaft Speed Sensor Circuit Intermittent
P0724 Brake Switch B Input Circuit High
P0725 Engine Speed Input Circuit
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0729 Gear 6 Incorrect Ratio
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P0737 TCM Engine Speed Output Circuit
P0738 TCM Engine Speed Output Circuit Low
P0739 TCM Engine Speed Output Circuit High
P0740 Torque Converter Clutch Solenoid Circuit / Open
P0741 Torque Converter Clutch Solenoid Circuit Performance Or Stuck Off
P0742 Torque Converter Clutch Solenoid Circuit Stuck On
P0743 Torque Converter Clutch Solenoid Circuit Electrical
P0744 Torque Converter Clutch Solenoid Circuit Intermittent
P0745 Pressure Control Solenoid A
P0746 Pressure Control Solenoid A Performance or Stuck Off
P0747 Pressure Control Solenoid A Stuck On
P0748 Pressure Control Solenoid A Electrical
P0749 Pressure Control Solenoid A Intermittent
P0750 Shift Solenoid A
P0751 Shift Solenoid A Performance or Stuck Off
P0752 Shift Solenoid A Stuck On
P0753 Shift Solenoid A Electrical
P0754 Shift Solenoid A Intermittent
P0755 Shift Solenoid B
P0756 Shift Solenoid B Performance or Stuck Off
P0757 Shift Solenoid B Stuck On
P0758 Shift Solenoid B Electrical
P0759 Shift Solenoid B Intermittent
P0760 Shift Solenoid C
P0761 Shift Solenoid C Performance or Stuck Off
P0762 Shift Solenoid C Stuck On
P0763 Shift Solenoid C Electrical
P0764 Shift Solenoid C Intermittent
P0765 Shift Solenoid D
P0766 Shift Solenoid D Performance or Stuck Off
P0767 Shift Solenoid D Stuck On
P0768 Shift Solenoid D Electrical
P0769 Shift Solenoid D Intermittent
P0770 Shift Solenoid E
P0771 Shift Solenoid E Performance or Stuck Off
P0772 Shift Solenoid E Stuck On
P0773 Shift Solenoid E Electrical
P0774 Shift Solenoid E Intermittent
P0775 Pressure Control Solenoid B
P0776 Pressure Control Solenoid B Performance or Stuck Off
P0777 Pressure Control Solenoid B Stuck On
P0778 Pressure Control Solenoid B Electrical
P0779 Pressure Control Solenoid B Intermittent
P0780 Shift Malfunction
P0781 1-2 Shift
P0782 2-3 Shift
P0783 3-4 Shift
P0784 4-5 Shift
P0785 Shift/Timing Solenoid
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit
P0791 Intermediate Shaft Speed Sensor A Circuit
P0792 Intermediate Shaft Speed Sensor A Circuit Range/Performance
P0793 Intermediate Shaft Speed Sensor A Circuit No Signal
P0794 Intermediate Shaft Speed Sensor A Circuit Intermittent
P0795 Pressure Control Solenoid C
P0796 Pressure Control Solenoid C Performance or Stuck Off
P0797 Pressure Control Solenoid C Stuck On
P0798 Pressure Control Solenoid C Electrical
P0799 Pressure Control Solenoid C Intermittent
P0800 Transfer Case Control System (MIL Request)
P0801 Reverse Inhibit Control Circuit
P0802 Transmission Control System MIL Request Circuit / Open
P0803 1-4 Upshift (skip shift) Solenoid Circuit
P0804 1-4 Upshift (skip shift) Lamp Control Circuit
P0805 Clutch Position Sensor Circuit
P0806 Clutch Position Sensor Circuit Range/Performance
P0807 Clutch Position Sensor Circuit Low
P0808 Clutch Position Sensor Circuit High
P0809 Clutch Position Sensor Circuit Intermittent
P0810 Clutch Position Control Error
P0811 Excessive Clutch Slippage
P0812 Reverse Input Circuit
P0813 Reverse Output Circuit
P0814 Transmission Range Display Circuit
P0815 Upshift Switch Circuit
P0816 Downshift Switch Circuit
P0817 Starter Disable Circuit
P0818 Driveline Disconnect Switch Input Circuit
P0819 Up and Down Shift Switch to Transmission Range Correlation
P0820 Gear Lever X-Y Position Sensor Circuit
P0821 Gear Lever X Position Sensor Circuit
P0822 Gear Lever Y Position Sensor Circuit
P0823 Gear Lever X Position Sensor Circuit Intermittent
P0824 Gear Lever Y Position Sensor Circuit Intermittent
P0825 Gear Lever Push/Pull Switch Circuit (Shift Anticipate)
P0826 Up and Down Switch Input Circuit
P0827 Up and Down Switch Input Circuit Low
P0828 Up and Down Switch Input Circuit High
P0829 5-6 Shift
P0830 Clutch Pedal Switch A Circuit
P0831 Clutch Pedal Switch A Circuit Low
P0832 Clutch Pedal Switch A Circuit High
P0833 Clutch Pedal Switch B Circuit
P0834 Clutch Pedal Switch B Circuit Low
P0835 Clutch Pedal Switch B Circuit High
P0836 Four wheel Drive (4WD) Switch Circuit
P0837 Four Wheel Drive (4WD) Switch Circuit Range/Performance
P0838 Four Wheel Drive (4WD) Switch Circuit Low
P0839 Four Wheel Drive (4WD) Switch Circuit High
P0840 Transmission Fluid Pressure Sensor/Switch A Circuit
P0841 Transmission Fluid Pressure Sensor/Switch A Circuit Range/Performance
P0842 Transmission Fluid Pressure Sensor/Switch A Circuit Low
P0843 Transmission Fluid Pressure Sensor/Switch A Circuit High
P0844 Transmission Fluid Pressure Sensor/Switch A Circuit Intermittent
P0845 Transmission Fluid Pressure Sensor/Switch B Circuit
P0846 Transmission Fluid Pressure Sensor/Switch B Circuit Range/Performance
P0847 Transmission Fluid Pressure Sensor/Switch B Circuit Low
P0848 Transmission Fluid Pressure Sensor/Switch B Circuit High
P0849 Transmission Fluid Pressure Sensor/Switch B Circuit Intermittent
P0850 Park / Neutral Switch Input Circuit
P0851 Park / Neutral Switch Input Circuit Low
P0852 Park / Neutral Switch Input Circuit High
P0853 Drive Switch Input Circuit
P0854 Drive Switch Input Circuit Low
P0855 Drive Switch Input Circuit High
P0856 Traction Control Input Signal
P0857 Traction Control Input Signal Range/Performance
P0858 Traction Control Input Signal Low
P0859 Traction Control Input Signal High
P0860 Gear Shift Module Communication Circuit
P0861 Gear Shift Module Communication Circuit Low
P0862 Gear Shift Module Communication Circuit High
P0863 TCM Communication Circuit
P0864 TCM Communication Circuit Range/Performance
P0865 TCM Communication Circuit Low
P0866 TCM Communication Circuit High
P0867 Transmission Fluid Pressure
P0868 Transmission Fluid Pressure Low
P0869 Transmission Fluid Pressure High
P0870 Transmission Fluid Pressure Sensor/Switch C Circuit
P0871 Transmission Fluid Pressure Sensor/Switch C Circuit Range/Performance
P0872 Transmission Fluid Pressure Sensor/Switch C Circuit Low
P0873 Transmission Fluid Pressure Sensor/Switch C Circuit High
P0874 Transmission Fluid Pressure Sensor/Switch C Circuit Intermittent
P0875 Transmission Fluid Pressure Sensor/Switch D Circuit
P0876 Transmission Fluid Pressure Sensor/Switch D Circuit Range/Performance
P0877 Transmission Fluid Pressure Sensor/Switch D Circuit Low
P0878 Transmission Fluid Pressure Sensor/Switch D Circuit High
P0879 Transmission Fluid Pressure Sensor/Switch D Circuit Intermittent
P0880 TCM Power Input Signal
P0881 TCM Power Input Signal Range/Performance
P0882 TCM Power Input Signal Low
P0883 TCM Power Input Signal High
P0884 TCM Power Input Signal Intermittent
P0885 TCM Power Relay Control Circuit /Open
P0886 TCM Power Relay Control Circuit Low
P0887 TCM Power Relay Control Circuit High
P0888 TCM Power Relay Sense Circuit
P0889 TCM Power Relay Sense Circuit Range/Performance
P0890 TCM Power Relay Sense Circuit Low
P0891 TCM Power Relay Sense Circuit High
P0892 TCM Power Relay Sense Circuit Intermittent
P0893 Multiple Gears Engaged
P0894 Transmission Component Slipping
P0895 Shift Time Too Short
P0896 Shift Time Too Long
P0897 Transmission Fluid Deteriorated
P0898 Transmission Control System MIL Request Circuit Low
P0899 Transmission Control System MIL Request Circuit High
P0900 Clutch Actuator Circuit / Open
P0901 Clutch Actuator Circuit Range/Performance
P0902 Clutch Actuator Circuit Low
P0903 Clutch Actuator Circuit High
P0904 Gate Select Position Circuit [senses left / right position]
P0905 Gate Select Position Circuit Range/Performance
P0906 Gate Select Position Circuit Low
P0907 Gate Select Position Circuit High
P0908 Gate Select Position Circuit Intermittent
P0909 Gate Select Control Error
P0910 Gate Select Actuator Circuit / Open [left / right motion]
P0911 Gate Select Actuator Circuit Range/Performance
P0912 Gate Select Actuator Circuit Low
P0913 Gate Select Actuator Circuit High
P0914 Gear Shift Position Circuit [senses forward / rearward position, odd / even gears]
P0915 Gear Shift Position Circuit Range/Performance
P0916 Gear Shift Position Circuit Low
P0917 Gear Shift Position Circuit High
P0918 Gear Shift Position Circuit Intermittent
P0919 Gear Shift Position Control Error
P0920 Gear Shift Forward Actuator Circuit / Open [forward motion, odd gears, 1,3,5]
P0921 Gear Shift Forward Actuator Circuit Range/Performance
P0922 Gear Shift Forward Actuator Circuit Low
P0923 Gear Shift Forward Actuator Circuit High
P0924 Gear Shift Reverse Actuator Circuit / Open [rearward motion, even gears, 2,4,6]
P0925 Gear Shift Reverse Actuator Circuit Range/Performance
P0926 Gear Shift Reverse Actuator Circuit Low
P0927 Gear Shift Reverse Actuator Circuit High
P0928 Gear Shift Lock Solenoid Circuit / Open
P0929 Gear Shift Lock Solenoid Circuit Range/Performance
P0930 Gear Shift Lock Solenoid Circuit Low
P0931 Gear Shift Lock Solenoid Circuit High
P0932 Hydraulic Pressure Sensor Circuit
P0933 Hydraulic Pressure Sensor Range/Performance
P0934 Hydraulic Pressure Sensor Circuit Low Input
P0935 Hydraulic Pressure Sensor Circuit High Input
P0936 Hydraulic Pressure Sensor Circuit Intermittent
P0937 Hydraulic Oil Temperature Sensor Circuit
P0938 Hydraulic Oil Temperature Sensor Range/Performance
P0939 Hydraulic Oil Temperature Sensor Circuit Low Input
P0940 Hydraulic Oil Temperature Sensor Circuit High Input
P0941 Hydraulic Oil Temperature Sensor Circuit Intermittent
P0942 Hydraulic Pressure Unit
P0943 Hydraulic Pressure Unit Cycling Period Too Short
P0944 Hydraulic Pressure Unit Loss of Pressure
P0945 Hydraulic Pump Relay Circuit / Open
P0946 Hydraulic Pump Relay Circuit Range/Performance
P0947 Hydraulic Pump Relay Circuit Low
P0948 Hydraulic Pump Relay Circuit High
P0949 Auto Shift Manual Adaptive Learning Not Done
P0950 Auto Shift Manual Control Circuit [Up / Down / Auto / etc]
P0951 Auto Shift Manual Control Circuit Range/Performance
P0952 Auto Shift Manual Control Circuit Low
P0953 Auto Shift Manual Control Circuit High
P0954 Auto Shift Manual Control Circuit Intermittent
P0955 Auto Shift Manual Mode Circuit [Perf / Winter / Sport / etc]
P0956 Auto Shift Manual Mode Circuit Range/Performance
P0957 Auto Shift Manual Mode Circuit Low
P0958 Auto Shift Manual Mode Circuit High
P0959 Auto Shift Manual Mode Circuit Intermittent
P0960 Pressure Control Solenoid A Control Circuit / Open
P0961 Pressure Control Solenoid A Control Circuit Range/Performance
P0962 Pressure Control Solenoid A Control Circuit Low
P0963 Pressure Control Solenoid A Control Circuit High
P0964 Pressure Control Solenoid B Control Circuit / Open
P0965 Pressure Control Solenoid B Control Circuit Range/Performance
P0966 Pressure Control Solenoid B Control Circuit Low
P0967 Pressure Control Solenoid B Control Circuit High
P0968 Pressure Control Solenoid C Control Circuit / Open
P0969 Pressure Control Solenoid C Control Circuit Range/Performance
P0970 Pressure Control Solenoid C Control Circuit Low
P0971 Pressure Control Solenoid C Control Circuit High
P0972 Shift Solenoid A Control Circuit Range/Performance
P0973 Shift Solenoid A Control Circuit Low
P0974 Shift Solenoid A Control Circuit High
P0975 Shift Solenoid B Control Circuit Range/Performance
P0976 Shift Solenoid B Control Circuit Low
P0977 Shift Solenoid B Control Circuit High
P0978 Shift Solenoid C Control Circuit Range/Performance
P0979 Shift Solenoid C Control Circuit Low
P0980 Shift Solenoid C Control Circuit High
P0981 Shift Solenoid D Control Circuit Range/Performance
P0982 Shift Solenoid D Control Circuit Low
P0983 Shift Solenoid D Control Circuit High
P0984 Shift Solenoid E Control Circuit Range/Performance
P0985 Shift Solenoid E Control Circuit Low
P0986 Shift Solenoid E Control Circuit High
P0987 Transmission Fluid Pressure Sensor/Switch E Circuit
P0988 Transmission Fluid Pressure Sensor/Switch E Circuit Range/Performance
P0989 Transmission Fluid Pressure Sensor/Switch E Circuit Low
P0990 Transmission Fluid Pressure Sensor/Switch E Circuit High
P0991 Transmission Fluid Pressure Sensor/Switch E Circuit Intermittent
P0992 Transmission Fluid Pressure Sensor/Switch F Circuit
P0993 Transmission Fluid Pressure Sensor/Switch F Circuit Range/Performance
P0994 Transmission Fluid Pressure Sensor/Switch F Circuit Low
P0995 Transmission Fluid Pressure Sensor/Switch F Circuit High
P0996 Transmission Fluid Pressure Sensor/Switch F Circuit Intermittent
P0997 Shift Solenoid F Control Circuit Range/Performance
P0998 Shift Solenoid F Control Circuit Low
P0999 Shift Solenoid F Control Circuit High
P1000 Ignition Circuit Low
P1001 Ignition Circuit High
P1004 ECU Battery Feed & Power Grounds
P1005 System Ground Circuit
P1006 EGR/EVAP Solenoid Circuit Low
P1007 EGR/EVAP Solenoid Circuit High
P1008 Power Steering Circuit Low
P1009 Power Steering Circuit High
P1012 MPA Circuit Low
P1013 MPA Circuit High
P1014 Fuel Pump Circuit Low
P1015 Fuel Pump Circuit High
P1016 Charge Air Temp Circuit Low
P1017 Charge Air Temp Circuit High
P1018 Serial Data Circuit
P1019 Power Latch Not Seat
P1021 Engine Fai To Sart due to Mech Damage, Fuel or Ign Conditions
P1022 Starter Relay Circuit Low
P1023 Starter Relay Circuit High
P1024 ECU Start Circuit Low
P1025 WOT Circuit Low
P1026 WOT Circuit High
P1027 ECU Sees Wide Open Throttle
P1028 ECU Does Not See Wide Open Throttle
P1029 ISA Closed Throttle Circuit Low
P1030 ISA Closed Throttle Circuit High
P1031 ECU Sees Closed Throttle
P1032 ECU Does Not See Closed Throttle
P1033�36 ISA Circuits
P1037 TP Sensor Circuit Reads Low
P1038 Park/Neutral Line High
P1039 Park/Neutral Line Low
P1040 Latched B+ Line Low
P1041 Latched B+ Line High
P1042 No Latched B+ 1/2 Volt Drop
P1043 Shift Lamp Circuit Grounded
P1044 D2�1 Circuit Low (A/T) or
P1044 Upshift Lamp Circuit (M/T) or
P1044 Shift Lamp Circuit High
P1045 Shift Lamp Circuit Open
P1047 Wrong ECU
P1048 M/T Vehicle Configuration
P1049 A/T Vehicle Configuration
P1050 Idle RPM Low
P1051 Idle RPM High
P1052 MAP Sensor Out Of Limits
P1053 Change In MAP Reading Out Of Limits
P1054 Coolant Sensor & 5 V for TP Sensor/MAP Circuits Low
P1055 Coolant Sensor Circuit High
P1056 Inactive Coolant Temperature Sensor
P1059 A/C Request Circuit Low
P1060 A/C Request Circuit High
P1061 A/C Select Circuit Low
P1062 A/C Select Circuit High
P1063 A/C Clutch Circuit Low
P1064 A/C Clutch Circuit High & Power Steering Input
P1065 Rich Oxygen Sensor Input
P1066 Lean Oxygen Sensor Input
P1067 Latch Relay Circuit Low
P1068 Latch Relay Circuit High
P1069 No Tach
P1074 ECU Does Not See Speed Sensor
P1106 MAP Sensor Circuit Intermittent High Voltage
P1107 MAP Sensor Circuit Circuit Intermittent Low Voltage
P1110 Decreased Engine Perf Due To High Intake Air Temperature
P1111 IAT Sensor Circuit Intermittent High Voltage
P1112 IAT Sensor Circuit Intermittent Low Voltage
P1114 ECT Sensor Circuit Intermittent Low Voltage
P1115 ECT Sensor Circuit Intermittent High Voltage
P1121 TPS Circuit Intermittent High Voltage
P1122 TPS Circuit Intermittent Low Voltage
P1125 Accelerator Pedal Position System
P1133 HO2S Insufficient Switching Bank 1 Sensor 1
P1134 HO2S Insufficient Transition Time Ratio Bank 1 Sensor 1
P1153 HO2S Insufficient Switching Bank 2 Sensor 1
P1154 HO2S Insufficient Transition Time Ratio Bank 2 Sensor 1
P1180 Decreased Engine Perf Due To High IP Fuel Temperature
P1191 Intake Air Duct Leak
P1192 Inlet air temperature sensor voltage is wrong
P1193 Inlet air temperature sensor voltage is wrong
P1194 Oxygen sensor heater performance is faulty
P1195 Oxygen sensor is slow
P1196 The oxygen sensor switched too slowly (bank 2).
P1197 The oxygen sensor switched too slowly (bank 1).
P1198 Radiator coolant temperature sensor voltage is wrong.
P1199 Radiator coolant temperature sensor voltage is wrong.
P1214 Injection Pump Timing Offset
P1216 Fuel Solenoid Response Time Too Short
P1217 Fuel Solenoid Response Time Too Long
P1218 Injection Pump Calibration Circuit
P1271 Accelerator Pedal Position Sensor 1-2 Correlation
P1272 Accelerator Pedal Position Sensor 2-3 Correlation
P1273 Accelerator Pedal Position Sensor 1-3 Correlation
P1275 Accelerator Pedal Position Sensor 1 Circuit
P1277 Accelerator Pedal Position Sensor 1 Low Voltage
P1278 Accelerator Pedal Position Sensor 1 High Voltage
P1280 Accelerator Pedal Position Sensor 2 Circuit
P1281 The engine is staying cold too long - check your thermostat.
P1282 The fuel pump relay circuit seems to be having a problem.
P1283 Idle Select Signal Invalid or
P1283 Accelerator Pedal Position Sensor 2 High Voltage
P1284 Fuel Injection Pump Battery Voltage Out Of Range
P1285 Fuel Injection Pump Controller Always On or
P1285 Accelerator Pedal Position Sensor 3 Circuit
P1286 Accelerator Position Sensor Supply Voltage Too High
P1287 Fuel Injection Pump Control Supply Voltage Low or
P1287 Accelerator Pedal Position Sensor 3 Low Voltage
P1288 The intake manifold short runner tuning valve circuit seems to be having a problem.
P1289 There's a problem in the manifold tuning valve solenoid control circuit.
P1290 Compressed natural gas system pressure is too high
P1291 The heated air intake sensor does not seem to be working.
P1292 Natural gas pressure sensor issue
P1293 Natural gas pressure sensor issue
P1294 Can't get to target engine speed, check for vacuum leaks and idle speed motor issues.
P1295 The throttle position sensor doesn't seem to be getting enough electricity.
P1296 The MAP sensor doesn't seem to be getting enough electricity.
P1297 The MAP sensor doesn't change its reading when the engine is running!
P1298 During wide-open throttle, the engine runs lean.
P1299 MAP Sensor and Throttle Position Sensor signals don't match, check for a vacuum leak.
P1336 Crankshaft Position System Variation Not Learned
P1345 Crankshaft Position/Camshaft Position Correlation
P1351 Ignition Control Circuit High Voltage
P1361 Ignition Control Circuit Low Voltage
P1380 Electronic Brake Control Rough Road Data Unusable
P1381 Misfire Detected-No Electronic Brake Control Data
P1388 Auto shutdown relay circuit problems?
P1389 No Z1 or Z2 voltage seen by the computer when the auto shutdown relay is used.
P1390 Cam and crank signals don't match - did the timing belt skip a tooth?
P1391 Sometimes, I can't see the crank or cam sensor signal.
P1398 I can see the Crank Sensor's signal when I prepare for Misfire Diagnostics. Try replacing it.
P1399 Problem in the Wait to Start Lamp circuit - (diesels only?)
P1403 EGR position sensor not getting (enough) voltage.
P1404 EGR Valve Closed Pintle Position
P1406 EGR Valve Position
P1409 EGR Valve System leak
P1415 AIR System Bank 1
P1416 AIR System Bank 1
P1441 Evap Emissions Flow During Non-Purge
P1475 Auxiliary 5 Volt Supply Voltage High
P1476 Too little secondary air injection during aspirator test.
P1477 Too much secondary air injection during aspirator test.
P1478 Battery temperature sensor voltage wrong.
P1479 Transmission fan relay circuit problems?
P1480 PCV solenoid circuit problems?
P1481 Transmission RPM pulse generator signal for misfire detection seems wrong.
P1482 Catalyst temperature sensor circuit shorted low.
P1483 Catalyst temperature sensor circuit shorted high.
P1484 The catalyst seems to be overheating!
P1485 Air injection solenoid circuit problems.
P1486 Pinched or blocked hose in the evaporative hose system.
P1487 Control circuit of the #2 high-speed radiator fan control relay is having problems.
P1488 Auxiliary 5-volt sensor feed is too low.
P1489 High speed radiator fan control circuit problem.
P1490 Low speed radiator fan control circuit problem.
P1491 Radiator fan control circuit problem (may be solid state relays as well as other circuits).
P1492 Ambient or battery temperature sensor voltage wrong
P1493 Ambient or battery temperature sensor voltage wrong
P1494 Leak Detection Pump (LDP) pressure switch problem - electrical or the pump itself.
P1495 Leak Detection Pump (LDP) pressure switch problem - the solenoid circuit.
P1496 Sensor feed is below an acceptable limit. (under 4v for 4 seconds - should be 5v).
P1498 High speed radiator fan control circuit problem. (#3 control relay)
P1508 IAC System Low RPM
P1509 IAC System High RPM
P1594 Voltage too high in charging system.
P1595 Speed control vacuum or vent solenoid control circuits shorted or lost.
P1596 Speed control switch always high
P1597 Speed control switch always low
P1598 A/C pressure sensor voltage high
P1599 A/C pressure sensor voltage low
P1602 PCM Not Programmed
P1621 PCM Memory performance or Write
P1626 Vehicle Theft System Control Loss of Data
P1627 A/D Performance
P1630 Vehicle Theft System PCM in Learn Mode
P1631 Vehicle Theft System Improper Password
P1635 5 Volt Reference (A) Circuit
P1639 5 Volt Reference (B) Circuit
P1641 MIL Control Circuit
P1643 Wait To Start Lamp Control Circuit
P1646 5 Volt Reference (C) Circuit
P1652 J1850 Communications Bus
P1653 EGR Vent Solenoid Control Circuit
P1654 Service Throttle Soon Lamp Control Circuit
P1655 EGR Solenoid Control Circuit
P1656 Wastegate Solenoid Control Circuit
P1680 Clutch Released Switch Circuit
P1681 No messages received from the cluster control module (dashboard computer).
P1682 Charging system doesn't seem to be working well. Check alternator, etc.
P1683 Speed control servo power control circuit problem.
P1684 The battery has been disconnected within the last 50 starts.
P1685 Invalid key received from the Smart Key Immobilizer Module.
P1686 No messages received from the Smart Key Immobilizer Module.
P1687 No messages received from the Mechanical Instrument Cluster module.
P1688 Internal Fuel Injection Pump Controller Failure
P1689 No Comm between ECM & Injection Pump Module
P1690 CKP Sensor Does Not Agree With ECM CKP Sensor
P1691 Fuel System ESS RPM Error
P1692 DTC Set In ECM
P1693 The companion engine control module has shown a fault.
P1694 No messages received from the powertrain control module-Aisin transmission.
P1695 No messages received from the body control module.
P1696 Unsuccessful attempt to write to an EEPROM location!
P1697 Unsuccessful attempt to update Service Reminder Indicator (SRI or EMR) mileage!
P1698 No messages received from the electronic transmission control module or the Aisin transmission controller.
P1719 Transmission 2-3 gear lockout solenoid control circuit problem.
P1740 Either the tcc solenoid or overdrive solenoid systems doesn't seem to be making much sense.
P1756 Transmission control pressure not equal to target. (Mid pressure problem)
P1757 Transmission control pressure not equal to target. (Zero pressure problem)
P1762 The Governor Pressure Sensor input was too high or too low for 3 consecutive park/neutral calibrations.
P1763 The Governor Pressure Sensor input is too high
P1764 The Governor Pressure Sensor input is too low.
P1765 Open or short in the Transmission Relay control circuit.
P1899 The Park/Neutral switch seems to be stuck!
P2000 NOx Trap Efficiency Below Threshold (Bank 1)
P2001 NOx Trap Efficiency Below Threshold (Bank 2)
P2002 Particulate Trap Efficiency Below Threshold (Bank 1)
P2003 Particulate Trap Efficiency Below Threshold (Bank 2)
P2004 Intake Manifold Runner Control Stuck Open (Bank 1)
P2005 Intake Manifold Runner Control Stuck Open (Bank 2)
P2006 Intake Manifold Runner Control Stuck Closed (Bank 1)
P2007 Intake Manifold Runner Control Stuck Closed (Bank 2)
P2008 Intake Manifold Runner Control Circuit / Open (Bank 1)
P2009 Intake Manifold Runner Control Circuit Low (Bank 1)
P2010 Intake Manifold Runner Control Circuit High (Bank 1)
P2011 Intake Manifold Runner Control Circuit / Open (Bank 2)
P2012 Intake Manifold Runner Control Circuit Low (Bank 2)
P2013 Intake Manifold Runner Control Circuit High (Bank 2)
P2014 Intake Manifold Runner Position Sensor/Switch Circuit (Bank 1)
P2015 Intake Manifold Runner Position Sensor/Switch Circuit Range/Perf. (Bank 1)
P2016 Intake Manifold Runner Position Sensor/Switch Circuit Low (Bank 1)
P2017 Intake Manifold Runner Position Sensor/Switch Circuit High (Bank 1)
P2018 Intake Manifold Runner Position Sensor/Switch Circuit Intermittent (Bank 1)
P2019 Intake Manifold Runner Position Sensor/Switch Circuit (Bank 2)
P2020 Intake Manifold Runner Position Sensor/Switch Circuit Range/Perf. (Bank 2)
P2021 Intake Manifold Runner Position Sensor/Switch Circuit Low (Bank 2)
P2022 Intake Manifold Runner Position Sensor/Switch Circuit High (Bank 2)
P2023 Intake Manifold Runner Position Sensor/Switch Circuit Intermittent (Bank 2)
P2024 Evaporative Emissions Fuel Vapor Temperature Sensor Circuit
P2025 Evaporative Emissions Fuel Vapor Temperature Sensor Circuit Performance
P2026 Evaporative Emissions Fuel Vapor Temperature Sensor Circuit Low Voltage
P2027 Evaporative Emissions Fuel Vapor Temperature Sensor Circuit High Voltage
P2028 Evaporative Emissions Fuel Vapor Temperature Sensor Circuit Intermittent
P2029 Fuel Fired Heater Disabled
P2030 Fuel Fired Heater Performance
P2031 Exhaust Gas Temperature Sensor Circuit Bank 1 Sensor 2
P2032 Exhaust Gas Temperature Sensor Circuit Low Bank 1 Sensor 2
P2033 Exhaust Gas Temperature Sensor Circuit High Bank 1 Sensor 2
P2034 Exhaust Gas Temperature Sensor Circuit Bank 2 Sensor 2
P2035 Exhaust Gas Temperature Sensor Circuit Low Bank 2 Sensor 2
P2036 Exhaust Gas Temperature Sensor Circuit High Bank 2 Sensor 2
P2037 Reductant Injection Air Pressure Sensor Circuit
P2038 Reductant Injection Air Pressure Sensor Circuit Range/Performance
P2039 Reductant Injection Air Pressure Sensor Circuit Low Input
P2040 Reductant Injection Air Pressure Sensor Circuit High Input
P2041 Reductant Injection Air Pressure Sensor Circuit Intermittent
P2042 Reductant Temperature Sensor Circuit
P2043 Reductant Temperature Sensor Circuit Range/Performance
P2044 Reductant Temperature Sensor Circuit Low Input
P2045 Reductant Temperature Sensor Circuit High Input
P2046 Reductant Temperature Sensor Circuit Intermittent
P2047 Reductant Injector Circuit / Open Bank 1 Unit 1
P2048 Reductant Injector Circuit Low Bank 1 Unit 1
P2049 Reductant Injector Circuit High Bank 1 Unit 1
P2050 Reductant Injector Circuit / Open Bank 2 Unit 1
P2051 Reductant Injector Circuit Low Bank 2 Unit 1
P2052 Reductant Injector Circuit High Bank 2 Unit 1
P2053 Reductant Injector Circuit / Open Bank 1 Unit 2
P2054 Reductant Injector Circuit Low Bank 1 Unit 2
P2055 Reductant Injector Circuit High Bank 1 Unit 2
P2056 Reductant Injector Circuit / Open Bank 2 Unit 2
P2057 Reductant Injector Circuit Low Bank 2 Unit 2
P2058 Reductant Injector Circuit High Bank 2 Unit 2
P2059 Reductant Injection Air Pump Control Circuit / Open
P2060 Reductant Injection Air Pump Control Circuit Low
P2061 Reductant Injection Air Pump Control Circuit High
P2062 Reductant Supply Control Circuit / Open
P2063 Reductant Supply Control Circuit Low
P2064 Reductant Supply Control Circuit High
P2065 Fuel Level Sensor B Circuit
P2066 Fuel Level Sensor B Circuit Range/Performance
P2067 Fuel Level Sensor B Circuit Low
P2068 Fuel Level Sensor B Circuit High
P2069 Fuel Level Sensor B Circuit Intermittent
P2070 Intake Manifold Tuning Valve Stuck Open
P2071 Intake Manifold Tuning Valve Stuck Closed
P2072 Throttle Actuator Control System - Ice Blockage
P2073 Manifold Absolute Pressure/Mass Air Flow - Throttle Position Correlation at Idle
P2074 Manifold Absolute Pressure/Mass Air Flow - Throttle Position Correlation at Higher Load
P2075 Intake Manifold Tuning Valve Position Sensor/Switch Circuit
P2076 Intake Manifold Tuning Valve Position Sensor/Switch Circuit Range/Performance
P2077 Intake Manifold Tuning Valve Position Sensor/Switch Circuit Low
P2078 Intake Manifold Tuning Valve Position Sensor/Switch Circuit High
P2079 Intake Manifold Tuning Valve Position Sensor/Switch Circuit Intermittent
P2080 Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 1 Sensor 1
P2081 Exhaust Gas Temperature Sensor Circuit Intermittent Bank 1 Sensor 1
P2082 Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 2 Sensor 1
P2083 Exhaust Gas Temperature Sensor Circuit Intermittent Bank 2 Sensor 1
P2084 Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 1 Sensor 2
P2085 Exhaust Gas Temperature Sensor Circuit Intermittent Bank 1 Sensor 2
P2086 Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 2 Sensor 2
P2087 Exhaust Gas Temperature Sensor Circuit Intermittent Bank 2 Sensor 2
P2088 A Camshaft Position Actuator Control Circuit Low Bank 1
P2089 A Camshaft Position Actuator Control Circuit High Bank 1
P2090 B Camshaft Position Actuator Control Circuit Low Bank 1
P2091 B Camshaft Position Actuator Control Circuit High Bank 1
P2092 A Camshaft Position Actuator Control Circuit Low Bank 2
P2093 A Camshaft Position Actuator Control Circuit High Bank 2
P2094 B Camshaft Position Actuator Control Circuit Low Bank 2
P2095 B Camshaft Position Actuator Control Circuit High Bank 2
P2096 Post Catalyst Fuel Trim System Too Lean Bank 1
P2097 Post Catalyst Fuel Trim System Too Rich Bank 1
P2098 Post Catalyst Fuel Trim System Too Lean Bank 2
P2099 Post Catalyst Fuel Trim System Too Rich Bank 2
P2100 Throttle Actuator Control Motor Circuit /Open
P2101 Throttle Actuator Control Motor Circuit Range/Performance
P2102 Throttle Actuator Control Motor Circuit Low
P2103 Throttle Actuator Control Motor Circuit High
P2104 Throttle Actuator Control System - Forced Idle
P2105 Throttle Actuator Control System - Forced Engine Shutdown
P2106 Throttle Actuator Control System - Forced Limited Power
P2107 Throttle Actuator Control Module Processor
P2108 Throttle Actuator Control Module Performance
P2109 Throttle / Pedal Position Sensor A Minimum Stop Performance
P2110 Throttle Actuator Control System - Forced Limited RPM
P2111 Throttle Actuator Control System - Stuck Open
P2112 Throttle Actuator Control System - Stuck Closed
P2113 Throttle / Pedal Position Sensor B Minimum Stop Performance
P2114 Throttle / Pedal Position Sensor C Minimum Stop Performance
P2115 Throttle / Pedal Position Sensor D Minimum Stop Performance
P2116 Throttle / Pedal Position Sensor E Minimum Stop Performance
P2117 Throttle / Pedal Position Sensor F Minimum Stop Performance
P2118 Throttle Actuator Control Motor Current Range/Performance
P2119 Throttle Actuator Control Throttle Body Range/Performance
P2120 Throttle/Pedal Position Sensor/Switch D Circuit
P2121 Throttle/Pedal Position Sensor/Switch D Circuit Range/Performance
P2122 Throttle/Pedal Position Sensor/Switch D Circuit Low Input
P2123 Throttle/Pedal Position Sensor/Switch D Circuit High Input
P2124 Throttle/Pedal Position Sensor/Switch D Circuit Intermittent
P2125 Throttle/Pedal Position Sensor/Switch E Circuit
P2126 Throttle/Pedal Position Sensor/Switch E Circuit Range/Performance
P2127 Throttle/Pedal Position Sensor/Switch E Circuit Low Input
P2128 Throttle/Pedal Position Sensor/Switch E Circuit High Input
P2129 Throttle/Pedal Position Sensor/Switch E Circuit Intermittent
P2130 Throttle/Pedal Position Sensor/Switch F Circuit
P2131 Throttle/Pedal Position Sensor/Switch F Circuit Range/Performance
P2132 Throttle/Pedal Position Sensor/Switch F Circuit Low Input
P2133 Throttle/Pedal Position Sensor/Switch F Circuit High Input
P2134 Throttle/Pedal Position Sensor/Switch F Circuit Intermittent
P2135 Throttle/Pedal Position Sensor/Switch A / B Voltage Correlation
P2136 Throttle/Pedal Position Sensor/Switch A / C Voltage Correlation
P2137 Throttle/Pedal Position Sensor/Switch B / C Voltage Correlation
P2138 Throttle/Pedal Position Sensor/Switch D / E Voltage Correlation
P2139 Throttle/Pedal Position Sensor/Switch D / F Voltage Correlation
P2140 Throttle/Pedal Position Sensor/Switch E / F Voltage Correlation
P2141 Exhaust Gas Recirculation Throttle Control Circuit Low
P2142 Exhaust Gas Recirculation Throttle Control Circuit High
P2143 Exhaust Gas Recirculation Vent Control Circuit / Open
P2144 Exhaust Gas Recirculation Vent Control Circuit Low
P2145 Exhaust Gas Recirculation Vent Control Circuit High
P2146 Fuel Injector Group A Supply Voltage Circuit / Open
P2147 Fuel Injector Group A Supply Voltage Circuit Low
P2148 Fuel Injector Group A Supply Voltage Circuit High
P2149 Fuel Injector Group B Supply Voltage Circuit / Open
P2150 Fuel Injector Group B Supply Voltage Circuit Low
P2151 Fuel Injector Group B Supply Voltage Circuit High
P2152 Fuel Injector Group C Supply Voltage Circuit / Open
P2153 Fuel Injector Group C Supply Voltage Circuit Low
P2154 Fuel Injector Group C Supply Voltage Circuit High
P2155 Fuel Injector Group D Supply Voltage Circuit / Open
P2156 Fuel Injector Group D Supply Voltage Circuit Low
P2157 Fuel Injector Group D Supply Voltage Circuit High
P2158 Vehicle Speed Sensor B
P2159 Vehicle Speed Sensor B Range/Performance
P2160 Vehicle Speed Sensor B Circuit Low
P2161 Vehicle Speed Sensor A Intermittent/Erratic
P2162 Vehicle Speed Sensor A / B Correlation
P2163 Throttle/Pedal Position Sensor A Maximum Stop Performance
P2164 Throttle/Pedal Position Sensor B Maximum Stop Performance
P2165 Throttle/Pedal Position Sensor C Maximum Stop Performance
P2166 Throttle/Pedal Position Sensor D Maximum Stop Performance
P2167 Throttle/Pedal Position Sensor E Maximum Stop Performance
P2168 Throttle/Pedal Position Sensor F Maximum Stop Performance
P2169 Exhaust Pressure Regulator Vent Solenoid Control Circuit / Open
P2170 Exhaust Pressure Regulator Vent Solenoid Control Circuit Low
P2171 Exhaust Pressure Regulator Vent Solenoid Control Circuit high
P2172 Throttle Actuator Control System - Sudden High Airflow Detected
P2173 Throttle Actuator Control System - High Airflow Detected
P2174 Throttle Actuator Control System - Sudden Low Airflow Detected
P2175 Throttle Actuator Control System - Low Airflow Detected
P2176 Throttle Actuator Control System - Idle Position Not Learned
P2177 System Too Lean Off Idle - Bank 1
P2178 System Too Rich Off Idle - Bank 1
P2179 System Too Lean Off Idle - Bank 2
P2180 System Too Rich Off Idle - Bank 2
P2181 Cooling System Performance
P2182 Engine Coolant Temperature Sensor 2 Circuit
P2183 Engine Coolant Temperature Sensor 2 Circuit Range/Performance
P2184 Engine Coolant Temperature Sensor 2 Circuit Low
P2185 Engine Coolant Temperature Sensor 2 Circuit High
P2186 Engine Coolant Temperature Sensor 2 Circuit Intermittent/Erratic
P2187 System Too Lean at Idle - Bank 1
P2188 System Too Rich at Idle - Bank 1
P2189 System Too Lean at Idle - Bank 2
P2190 System Too Rich at Idle - Bank 2
P2191 System Too Lean at Higher Load - Bank 1
P2192 System Too Rich at Higher Load - Bank 1
P2193 System Too Lean at Higher Load - Bank 2
P2194 System Too Rich at Higher Load - Bank 2
P2195 O2 Sensor Signal Stuck Lean - Bank 1, Sensor 1
P2196 O2 Sensor Signal Stuck Rich - Bank 1, Sensor 1
P2197 O2 Sensor Signal Stuck Lean - Bank 2, Sensor 1
P2198 O2 Sensor Signal Stuck Rich - Bank 2, Sensor 1
P2199 Intake Air Temperature 1/2 Correlation
P2200 NOx Sensor Circuit Bank 1
P2201 NOx Sensor Circuit Range/Performance Bank 1
P2202 NOx Sensor Circuit Low Input Bank 1
P2203 NOx Sensor Circuit High Input Bank 1
P2204 NOx Sensor Circuit Intermittent Bank 1
P2205 NOx Sensor Heater Control Circuit / Open Bank 1
P2206 NOx Sensor Heater Control Circuit Low Bank 1
P2207 NOx Sensor Heater Control Circuit High Bank 1
P2208 NOx Sensor Heater Sense Circuit Bank 1
P2209 NOx Sensor Heater Sense Circuit Range/Performance Bank 1
P2210 NOx Sensor Heater Sense Circuit Low Input Bank 1
P2211 NOx Sensor Heater Sense Circuit High Input Bank 1
P2212 NOx Sensor Heater Sense Circuit Intermittent Bank 1
P2213 NOx Sensor Circuit Bank 2
P2214 NOx Sensor Circuit Range/Performance Bank 2
P2215 NOx Sensor Circuit Low Input Bank 2
P2216 NOx Sensor Circuit High Input Bank 2
P2217 NOx Sensor Circuit Intermittent Bank 2
P2218 NOx Sensor Heater Control Circuit / Open Bank 2
P2219 NOx Sensor Heater Control Circuit Low Bank 2
P2220 NOx Sensor Heater Control Circuit High Bank 2
P2221 NOx Sensor Heater Sense Circuit Bank 2
P2222 NOx Sensor Heater Sense Circuit Range/Performance Bank 2
P2223 NOx Sensor Heater Sense Circuit Low Input Bank 2
P2224 NOx Sensor Heater Sense Circuit High Input Bank 2
P2225 NOx Sensor Heater Sense Circuit Intermittent Bank 2
P2226 Barometric Pressure Circuit
P2227 Barometric Pressure Circuit Range/Performance
P2228 Barometric Pressure Circuit Low Input
P2229 Barometric Pressure Circuit High Input
P2230 Barometric Pressure Circuit Intermittent
P2231 O2 Sensor Signal Circuit Shorted to Heater Circuit - Bank 1, Sensor 1
P2232 O2 Sensor Signal Circuit Shorted to Heater Circuit - Bank 1, Sensor 2
P2233 O2 Sensor Signal Circuit Shorted to Heater Circuit - Bank 1, Sensor 3
P2234 O2 Sensor Signal Circuit Shorted to Heater Circuit - Bank 2, Sensor 1
P2235 O2 Sensor Signal Circuit Shorted to Heater Circuit - Bank 2, Sensor 2
P2236 O2 Sensor Signal Circuit Shorted to Heater Circuit - Bank 2, Sensor 3
P2237 O2 Sensor Positive Current Control Circuit / Open - Bank 1, Sensor 1
P2238 O2 Sensor Positive Current Control Circuit Low - Bank 1, Sensor 1
P2239 O2 Sensor Positive Current Control Circuit High - Bank 1, Sensor 1
P2240 O2 Sensor Positive Current Control Circuit / Open - Bank 2, Sensor 1
P2241 O2 Sensor Positive Current Control Circuit Low - Bank 2, Sensor 1
P2242 O2 Sensor Positive Current Control Circuit High - Bank 2, Sensor 1
P2243 O2 Sensor Reference Voltage Circuit / Open - Bank 1, Sensor 1
P2244 O2 Sensor Reference Voltage Performance - Bank 1, Sensor 1
P2245 O2 Sensor Reference Voltage Circuit Low - Bank 1, Sensor 1
P2246 O2 Sensor Reference Voltage Circuit High - Bank 1, Sensor 1
P2247 O2 Sensor Reference Voltage Circuit / Open - Bank 2, Sensor 1
P2248 O2 Sensor Reference Voltage Performance - Bank 2, Sensor 1
P2249 O2 Sensor Reference Voltage Circuit Low - Bank 2, Sensor 1
P2250 O2 Sensor Reference Voltage Circuit High - Bank 2, Sensor 1
P2251 O2 Sensor Negative Current Control Circuit / Open - Bank 1, Sensor 1
P2252 O2 Sensor Negative Current Control Circuit Low - Bank 1, Sensor 1
P2253 O2 Sensor Negative Current Control Circuit High - Bank 1, Sensor 1
P2254 O2 Sensor Negative Current Control Circuit / Open - Bank 2, Sensor 1
P2255 O2 Sensor Negative Current Control Circuit Low - Bank 2, Sensor 1
P2256 O2 Sensor Negative Current Control Circuit High - Bank 2, Sensor 1
P2257 Secondary Air Injection System Control A Circuit Low
P2258 Secondary Air Injection System Control A Circuit High
P2259 Secondary Air Injection System Control B Circuit Low
P2260 Secondary Air Injection System Control B Circuit High
P2261 Turbo / Super Charger Bypass Valve - Mechanical
P2262 Turbo / Super Charger Boost Pressure Not Detected - Mechanical
P2263 Turbo / Super Charge Boost System Performance
P2264 Water in Fuel Sensor Circuit
P2265 Water in Fuel Sensor Circuit Range/Performance
P2266 Water in Fuel Sensor Circuit Low
P2267 Water in Fuel Sensor Circuit High
P2268 Water in Fuel Sensor Circuit Intermittent
P2269 Water in Fuel Condition
P2270 O2 Sensor Signal Stuck Lean - Bank 1, Sensor 2
P2271 O2 Sensor Signal Stuck Rich - Bank 1, Sensor 2
P2272 O2 Sensor Signal Stuck Lean - Bank 2, Sensor 2
P2273 O2 Sensor Signal Stuck Rich - Bank 2, Sensor 2
P2274 O2 Sensor Signal Stuck Lean - Bank 1, Sensor 3
P2275 O2 Sensor Signal Stuck Rich - Bank 1, Sensor 3
P2276 O2 Sensor Signal Stuck Lean - Bank 2, Sensor 3
P2277 O2 Sensor Signal Stuck Rich - Bank 2, Sensor 3
P2278 Oxygen Sensor Signals Swapped Bank 1 Sensor 3 / Bank 2 Sensor 3
P2279 Intake Air System Leak
P2280 Air Flow Restriction / Air Leak Between Air Cleaner and MAF
P2281 Air Leak Between MAF and Throttle Body
P2282 Air Leak Between Throttle Body and Intake Valve
P2283 Injector Control Pressure Sensor Circuit
P2284 Injector Control Pressure Sensor Circuit Range/Performance
P2285 Injector Control Pressure Sensor Circuit Low
P2286 Injector Control Pressure Sensor Circuit High
P2287 Injector Control Pressure Sensor Circuit Intermittent
P2288 Injector Control Pressure Too High
P2289 Injector Control Pressure Too High - Engine Off
P2290 Injector Control Pressure Too Low
P2291 Injector Control Pressure Too Low - Engine Cranking
P2292 Injector Control Pressure Erratic
P2293 Fuel Pressure Regulator 2 Performance
P2294 Fuel Pressure Regulator 2 Control Circuit
P2295 Fuel Pressure Regulator 2 Control Circuit Low
P2296 Fuel Pressure Regulator 2 Control Circuit High
P2297 O2 Sensor Out of Range During Deceleration Bank 1, Sensor 1
P2298 O2 Sensor Out of Range During Deceleration Bank 2, Sensor 1
P2299 Brake Pedal Position/Accelerator Pedal Position Incompatible
P2300 Ignition Coil A Primary Control Circuit Low
P2301 Ignition Coil A Primary Control Circuit High
P2302 Ignition Coil A Secondary Circuit
P2303 Ignition Coil B Primary Control Circuit Low
P2304 Ignition Coil B Primary Control Circuit High
P2305 Ignition Coil B Secondary Circuit
P2306 Ignition Coil C Primary Control Circuit Low
P2307 Ignition Coil C Primary Control Circuit High
P2308 Ignition Coil C Secondary Circuit
P2309 Ignition Coil D Primary Control Circuit Low
P2310 Ignition Coil D Primary Control Circuit High
P2311 Ignition Coil D Secondary Circuit
P2312 Ignition Coil E Primary Control Circuit Low
P2313 Ignition Coil E Primary Control Circuit High
P2314 Ignition Coil E Secondary Circuit
P2315 Ignition Coil F Primary Control Circuit Low
P2316 Ignition Coil F Primary Control Circuit High
P2317 Ignition Coil F Secondary Circuit
P2318 Ignition Coil G Primary Control Circuit Low
P2319 Ignition Coil G Primary Control Circuit High
P2320 Ignition Coil G Secondary Circuit
P2321 Ignition Coil H Primary Control Circuit Low
P2322 Ignition Coil H Primary Control Circuit High
P2323 Ignition Coil H Secondary Circuit
P2324 Ignition Coil I Primary Control Circuit Low
P2325 Ignition Coil I Primary Control Circuit High
P2326 Ignition Coil I Secondary Circuit
P2327 Ignition Coil J Primary Control Circuit Low
P2328 Ignition Coil J Primary Control Circuit High
P2329 Ignition Coil J Secondary Circuit
P2330 Ignition Coil K Primary Control Circuit Low
P2331 Ignition Coil K Primary Control Circuit High
P2332 Ignition Coil K Secondary Circuit
P2333 Ignition Coil L Primary Control Circuit Low
P2334 Ignition Coil L Primary Control Circuit High
P2335 Ignition Coil L Secondary Circuit
P2336 Cylinder #1 Above Knock Threshold
P2337 Cylinder #2 Above Knock Threshold
P2338 Cylinder #3 Above Knock Threshold
P2339 Cylinder #4 Above Knock Threshold
P2340 Cylinder #5 Above Knock Threshold
P2341 Cylinder #6 Above Knock Threshold
P2342 Cylinder #7 Above Knock Threshold
P2343 Cylinder #8 Above Knock Threshold
P2344 Cylinder #9 Above Knock Threshold
P2345 Cylinder #10 Above Knock Threshold
P2346 Cylinder #11 Above Knock Threshold
P2347 Cylinder #12 Above Knock Threshold
P2400 Evaporative Emission System Leak Detection Pump Control Circuit / Open
P2401 Evaporative Emission System Leak Detection Pump Control Circuit Low
P2402 Evaporative Emission System Leak Detection Pump Control Circuit High
P2403 Evaporative Emission System Leak Detection Pump Sense Circuit / Open
P2404 Evaporative Emission System Leak Detection Pump Sense Circuit Range/Performance
P2405 Evaporative Emission System Leak Detection Pump Sense Circuit Low
P2406 Evaporative Emission System Leak Detection Pump Sense Circuit High
P2407 Evaporative Emission System Leak Detection Pump Sense Circuit Intermittent/Erratic
P2408 Fuel Cap Sensor/Switch Circuit
P2409 Fuel Cap Sensor/Switch Circuit Range/Performance
P2410 Fuel Cap Sensor/Switch Circuit Low
P2411 Fuel Cap Sensor/Switch Circuit High
P2412 Fuel Cap Sensor/Switch Circuit Intermittent/Erratic
P2413 Exhaust Gas Recirculation System Performance
P2414 O2 Sensor Exhaust Sample Error Bank 1, Sensor 1
P2415 O2 Sensor Exhaust Sample Error Bank 2, Sensor 1
P2416 Oxygen Sensor Signals Swapped Bank 1 Sensor 2 / Bank 1 Sensor 3
P2417 Oxygen Sensor Signals Swapped Bank 2 Sensor 2 / Bank 2 Sensor 3
P2418 Evaporative Emission Control System Switching Valve Control Circuit / Open
P2419 Evaporative Emission Control System Switching Valve Control Circuit Low
P2420 Evaporative Emission Control System Switching Valve Control Circuit High
P2421 Evaporative Emission Control System Vent Valve Stuck Open
P2422 Evaporative Emission Control System Vent Valve Stuck Closed
P2423 HC Adsorbtion Catalyst Efficiency Below Threshold Bank 1
P2424 HC Adsorbtion Catalyst Efficiency Below Threshold Bank 2
P2425 Exhaust Gas Recirculation Cooling Valve Control Circuit / Open
P2426 Exhaust Gas Recirculation Cooling Valve Control Circuit Low
P2427 Exhaust Gas Recirculation Cooling Valve Control Circuit High
P2428 Exhaust Gas Temperature Too High Bank 1
P2429 Exhaust Gas Temperature Too High Bank 2
P2430 Secondary Air Injection System Air Flow/Pressure Sensor Circuit Bank 1
P2431 Secondary Air Injection System Air Flow/Pressure Sensor Circuit Range/Performance Bank 1
P2432 Secondary Air Injection System Air Flow/Pressure Sensor Circuit Low Input Bank 1
P2433 Secondary Air Injection System Air Flow/Pressure Sensor Circuit High Input Bank 1
P2434 Secondary Air Injection System Air Flow/Pressure Sensor Circuit Intermittent High Input Bank 1
P2435 Secondary Air Injection System Air Flow/Pressure Sensor Circuit Bank 2
P2436 Secondary Air Injection System Air Flow/Pressure Sensor Circuit Range/Performance Bank 2
P2437 Secondary Air Injection System Air Flow/Pressure Sensor Circuit Low Input Bank 2
P2438 Secondary Air Injection System Air Flow/Pressure Sensor Circuit High Input Bank 2
P2439 Secondary Air Injection System Air Flow/Pressure Sensor Circuit Intermittent High Input Bank 2
P2440 Secondary Air Injection System Switching Valve Stuck Open Bank 1
P2441 Secondary Air Injection System Switching Valve Stuck Closed Bank 1
P2442 Secondary Air Injection System Switching Valve Stuck Open Bank 2
P2443 Secondary Air Injection System Switching Valve Stuck Closed Bank 2
P2444 Secondary Air Injection System Pump Stuck On Bank 1
P2445 Secondary Air Injection System Pump Stuck Off Bank 1
P2446 Secondary Air Injection System Pump Stuck On Bank 2
P2447 Secondary Air Injection System Pump Stuck Off Bank 2
P2448 Secondary Air Injection System High Airflow Bank 1
P2449 Secondary Air Injection System High Airflow Bank 2
P2450 Evaporative Emission Control System Switching Valve Performance or Stuck Open
P2451 Evaporative Emission Control System Switching Valve Stuck Closed
P2500 Generator Lamp Terminal Circuit Low
P2501 Generator Lamp Terminal Circuit High
P2502 Charging System Voltage
P2503 Charging System Voltage Low
P2504 Charging System Voltage High
P2505 ECM / PCM Power Input Signal
P2506 ECM / PCM Power Input Signal Range/Performance
P2507 ECM / PCM Power Input Signal Low
P2508 ECM / PCM Power Input Signal High
P2509 ECM / PCM Power Input Signal Intermittent
P2510 ECM / PCM Power Relay Sense Circuit Range/Performance
P2511 ECM / PCM Power Relay Sense Circuit Intermittent
P2512 Event Data Recorder Request Circuit / Open
P2513 Event Data Recorder Request Circuit Low
P2514 Event Data Recorder Request Circuit High
P2515 A/C Refrigerant Pressure Sensor B Circuit
P2516 A/C Refrigerant Pressure Sensor B Circuit Range/Performance
P2517 A/C Refrigerant Pressure Sensor B Circuit Low Input
P2518 A/C Refrigerant Pressure Sensor B Circuit High Input
P2519 A/C Request A Circuit
P2520 A/C Request A Circuit Low
P2521 A/C Request A Circuit High
P2522 A/C Request B Circuit
P2523 A/C Request B Circuit Low
P2524 A/C Request B Circuit High
P2525 Vacuum Reservoir Pressure Sensor Circuit
P2526 Vacuum Reservoir Pressure Sensor Circuit Range/Performance
P2527 Vacuum Reservoir Pressure Sensor Circuit Low
P2528 Vacuum Reservoir Pressure Sensor Circuit High
P2529 Vacuum Reservoir Pressure Sensor Circuit Intermittent
P2530 Ignition Switch Run Position Circuit
P2531 Ignition Switch Run Position Circuit Low
P2532 Ignition Switch Run Position Circuit High
P2533 Ignition Switch Run/Start Position Circuit
P2534 Ignition Switch Run/Start Position Circuit Low
P2535 Ignition Switch Run/Start Position Circuit High
P2536 Ignition Switch Accessory Position Circuit
P2537 Ignition Switch Accessory Position Circuit Low
P2538 Ignition Switch Accessory Position Circuit High
P2539 Low Pressure Fuel System Sensor Circuit
P2540 Low Pressure Fuel System Sensor Circuit Range / Performance
P2541 Low Pressure Fuel System Sensor Circuit Low Input
P2542 Low Pressure Fuel System Sensor Circuit High Input
P2543 Low Pressure Fuel System Sensor Circuit Intermittent
P2544 Torque Management Request Input Signal A
P2545 Torque Management Request Input Signal A Range / Performance
P2546 Torque Management Request Input Signal A Low
P2547 Torque Management Request Input Signal A High
P2548 Torque Management Request Input Signal B
P2549 Torque Management Request Input Signal B Range / Performance
P2550 Torque Management Request Input Signal B Low
P2551 Torque Management Request Input Signal B High
P2552 Throttle/Fuel Inhibit Circuit / Open
P2553 Throttle/Fuel Inhibit Circuit Range / Performance
P2554 Throttle/Fuel Inhibit Circuit Low
P2555 Throttle/Fuel Inhibit Circuit High
P2556 Engine Coolant Level Sensor/Switch Circuit
P2557 Engine Coolant Level Sensor/Switch Circuit Range / Performance
P2558 Engine Coolant Level Sensor/Switch Circuit Low
P2559 Engine Coolant Level Sensor/Switch Circuit High
P2560 Engine Coolant Level Low
P2561 A/C Control Module Requested MIL Illumination
P2562 Turbocharger Boost Control Position Sensor Circuit
P2563 Turbocharger Boost Control Position Sensor Circuit Range/Performance
P2564 Turbocharger Boost Control Position Sensor Circuit Low
P2565 Turbocharger Boost Control Position Sensor Circuit High
P2566 Turbocharger Boost Control Position Sensor Circuit Intermittent
P2567 Direct Ozone Reduction Catalyst Temperature Sensor Circuit
P2568 Direct Ozone Reduction Catalyst Temperature Sensor Circuit Range/Performance
P2569 Direct Ozone Reduction Catalyst Temperature Sensor Circuit Low
P2570 Direct Ozone Reduction Catalyst Temperature Sensor Circuit High
P2571 Direct Ozone Reduction Catalyst Temperature Sensor Circuit Intermittent/Erratic
P2572 Direct Ozone Reduction Catalyst Deterioration Sensor Circuit
P2573 Direct Ozone Reduction Catalyst Deterioration Sensor Circuit Range/Performance
P2574 Direct Ozone Reduction Catalyst Deterioration Sensor Circuit Low
P2575 Direct Ozone Reduction Catalyst Deterioration Sensor Circuit High
P2576 Direct Ozone Reduction Catalyst Deterioration Sensor Circuit Intermittent/Erratic
P2577 Direct Ozone Reduction Catalyst Efficiency Below Threshold
P2600 Coolant Pump Control Circuit / Open
P2601 Coolant Pump Control Circuit Range/Performance
P2602 Coolant Pump Control Circuit Low
P2603 Coolant Pump Control Circuit High
P2604 Intake Air Heater A Circuit Range/Performance
P2605 Intake Air Heater B Circuit / Open
P2606 Intake Air Heater B Circuit Range/Performance
P2607 Intake Air Heater B Circuit Low
P2608 Intake Air Heater B Circuit High
P2609 Intake Air Heater System Performance
P2610 ECM/PCM Internal Engine Off Timer Performance
P2611 A/C Refrigerant Distribution Valve Control Circuit / Open
P2612 A/C Refrigerant Distribution Valve Control Circuit Low
P2613 A/C Refrigerant Distribution Valve Control Circuit High
P2614 Camshaft Position Output Circuit / Open
P2615 Camshaft Position Output Circuit Low
P2616 Camshaft Position Output Circuit high
P2617 Crankshaft Position Output Circuit / Open
P2618 Crankshaft Position Output Circuit Low
P2619 Crankshaft Position Output Circuit high
P2620 Throttle Position Output Circuit / Open
P2621 Throttle Position Output Circuit Low
P2622 Throttle Position Output Circuit high
P2623 Injector Control Pressure Regulator / Open
P2624 Injector Control Pressure Regulator Low
P2625 Injector Control Pressure Regulator High
P2626 O2 Sensor Positive Current Trim Circuit / Open Bank 1 Sensor 1
P2627 O2 Sensor Positive Current Trim Circuit Low Bank 1, Sensor 1
P2628 O2 Sensor Positive Current Trim Circuit High Bank 1, Sensor 1
P2629 O2 Sensor Positive Current Trim Circuit / Open Bank 2 Sensor 1
P2630 O2 Sensor Positive Current Trim Circuit Low Bank 2, Sensor 1
P2631 O2 Sensor Positive Current Trim Circuit High Bank 2, Sensor 1
P2632 Fuel Pump B Control Circuit / Open
P2633 Fuel Pump B Control Circuit Low
P2634 Fuel Pump B Control Circuit High
P2635 Fuel Pump A Low Flow / Performance
P2636 Fuel Pump B Low Flow / Performance
P2637 Torque Management Feedback Signal A
P2638 Torque Management Feedback Signal A Range / Performance
P2639 Torque Management Feedback Signal A Low
P2640 Torque Management Feedback Signal A High
P2641 Torque Management Feedback Signal B
P2642 Torque Management Feedback Signal B Range / Performance
P2643 Torque Management Feedback Signal B Low
P2644 Torque Management Feedback Signal B High
P2645 A Rocker Arm Actuator Control Circuit / Open Bank 1
P2646 A Rocker Arm Actuator Control System Performance or Stuck Off Bank 1
P2647 A Rocker Arm Actuator Control System Stuck On Bank 1
P2648 A Rocker Arm Actuator Control Circuit Low Bank 1
P2649 A Rocker Arm Actuator Control Circuit High Bank 1
P2650 B Rocker Arm Actuator Control Circuit / Open Bank 1
P2651 B Rocker Arm Actuator Control System Performance or Stuck Off Bank 1
P2652 B Rocker Arm Actuator Control System Stuck On Bank 1
P2653 B Rocker Arm Actuator Control Circuit Low Bank 1
P2654 B Rocker Arm Actuator Control Circuit High Bank 1
P2655 A Rocker Arm Actuator Control Circuit / Open Bank 2
P2656 A Rocker Arm Actuator Control System Performance or Stuck Off Bank 2
P2657 A Rocker Arm Actuator Control System Stuck On Bank 2
P2658 A Rocker Arm Actuator Control Circuit Low Bank 2
P2659 A Rocker Arm Actuator Control Circuit High Bank 2
P2660 B Rocker Arm Actuator Control Circuit / Open Bank 2
P2661 B Rocker Arm Actuator Control System Performance or Stuck Off Bank 2
P2662 B Rocker Arm Actuator Control System Stuck On Bank 2
P2663 B Rocker Arm Actuator Control Circuit Low Bank 2
P2664 B Rocker Arm Actuator Control Circuit High Bank 2
P2665 Fuel Shutoff Valve B Control Circuit / Open
P2666 Fuel Shutoff Valve B Control Circuit Low
P2667 Fuel Shutoff Valve B Control Circuit High
P2668 Fuel Indicator Lamp Control Circuit
P2669 Actuator Supply Voltage B Circuit / Open
P2670 Actuator Supply Voltage B Circuit Low
P2671 Actuator Supply Voltage B Circuit High
P2700 Transmission Friction Element A Apply Time Range/Performance
P2701 Transmission Friction Element B Apply Time Range/Performance
P2702 Transmission Friction Element C Apply Time Range/Performance
P2703 Transmission Friction Element D Apply Time Range/Performance
P2704 Transmission Friction Element E Apply Time Range/Performance
P2705 Transmission Friction Element F Apply Time Range/Performance
P2706 Shift Solenoid F
P2707 Shift Solenoid F Performance or Stuck Off
P2708 Shift Solenoid F Stuck On
P2709 Shift Solenoid F Electrical
P2710 Shift Solenoid F Intermittent
P2711 Unexpected Mechanical Gear Disengagement
P2712 Hydraulic Pressure Unit Leakage
P2713 Pressure Control Solenoid D
P2714 Pressure Control Solenoid D Performance or Stuck Off
P2715 Pressure Control Solenoid D Stuck On
P2716 Pressure Control Solenoid D Electrical
P2717 Pressure Control Solenoid D Intermittent
P2718 Pressure Control Solenoid D Control Circuit / Open
P2719 Pressure Control Solenoid D Control Circuit Range/Performance
P2720 Pressure Control Solenoid D Control Circuit Low
P2721 Pressure Control Solenoid D Control Circuit High
P2722 Pressure Control Solenoid E
P2723 Pressure Control Solenoid E Performance or Stuck Off
P2724 Pressure Control Solenoid E Stuck On
P2725 Pressure Control Solenoid E Electrical
P2726 Pressure Control Solenoid E Intermittent
P2727 Pressure Control Solenoid E Control Circuit / Open
P2728 Pressure Control Solenoid E Control Circuit Range/Performance
P2729 Pressure Control Solenoid E Control Circuit Low
P2730 Pressure Control Solenoid E Control Circuit High
P2731 Pressure Control Solenoid F
P2732 Pressure Control Solenoid F Performance or Stuck Off
P2733 Pressure Control Solenoid F Stuck On
P2734 Pressure Control Solenoid F Electrical
P2735 Pressure Control Solenoid F Intermittent
P2736 Pressure Control Solenoid F Control Circuit / Open
P2737 Pressure Control Solenoid F Control Circuit Range/Performance
P2738 Pressure Control Solenoid F Control Circuit Low
P2739 Pressure Control Solenoid F Control Circuit High
P2740 Transmission Fluid Temperature Sensor B Circuit
P2741 Transmission Fluid Temperature Sensor B Circuit Range/Performance
P2742 Transmission Fluid Temperature Sensor B Circuit Low Input
P2743 Transmission Fluid Temperature Sensor B Circuit High Input
P2744 Transmission Fluid Temperature Sensor B Circuit Intermittent
P2745 Intermediate Shaft Speed Sensor B Circuit
P2746 Intermediate Shaft Speed Sensor B Circuit Range/Performance
P2747 Intermediate Shaft Speed Sensor B Circuit No Signal
P2748 Intermediate Shaft Speed Sensor B Circuit Intermittent
P2749 Intermediate Shaft Speed Sensor C Circuit
P2750 Intermediate Shaft Speed Sensor C Circuit Range/Performance
P2751 Intermediate Shaft Speed Sensor C Circuit No Signal
P2752 Intermediate Shaft Speed Sensor C Circuit Intermittent
P2753 Transmission Fluid Cooler Control Circuit / Open
P2754 Transmission Fluid Cooler Control Circuit Low
P2755 Transmission Fluid Cooler Control Circuit High
P2756 Torque Converter Clutch Pressure Control Solenoid
P2757 Torque Converter Clutch Pressure Control Solenoid Control Circuit Perf or Stuck Off
P2758 Torque Converter Clutch Pressure Control Solenoid Stuck On
P2759 Torque Converter Clutch Pressure Control Solenoid Electrical
P2760 Torque Converter Clutch Pressure Control Solenoid Intermittent
P2761 Torque Converter Clutch Pressure Control Solenoid Control Circuit / Open
P2762 Torque Converter Clutch Pressure Control Solenoid Control Circuit Range / Perf
P2763 Torque Converter Clutch Pressure Control Solenoid Control Circuit High
P2764 Torque Converter Clutch Pressure Control Solenoid Control Circuit Low
P2765 Input / Turbine Speed Sensor B Circuit
P2766 Input / Turbine Speed Sensor B Circuit Range / Performance
P2767 Input / Turbine Speed Sensor B Circuit No Signal
P2768 Input / Turbine Speed Sensor B Circuit Intermittent
P2769 Torque Converter Clutch Circuit Low
P2770 Torque Converter Clutch Circuit High
P2771 Four wheel Drive (4WD) Low Switch Circuit
P2772 Four Wheel Drive (4WD) Low Switch Circuit Range/Performance
P2773 Four Wheel Drive (4WD) Low Switch Circuit Low
P2774 Four Wheel Drive (4WD) Low Switch Circuit High
P2775 Upshift Switch Circuit Range/Performance
P2776 Upshift Switch Circuit Low
P2777 Upshift Switch Circuit High
P2778 Upshift Switch Circuit Intermittent/Erratic
P2779 Downshift Switch Circuit Range/Performance
P2780 Downshift Switch Circuit Low
P2781 Downshift Switch Circuit High
P2782 Downshift Switch Circuit Intermittent/Erratic
P2783 Torque Converter Temperature Too High
P2784 Input / Turbine Speed Sensor A / B Correlation
P2785 Clutch Actuator Temperature Too High
P2786 Gear Shift Actuator Temperature Too High
P2787 Clutch Temperature Too High
P2788 Auto Shift Manual Adaptive Learning at Limit
P2789 Clutch Adaptive Learning at Limit
P2790 Gate Select Direction Circuit
P2791 Gate Select Direction Circuit Low
P2792 Gate Select Direction Circuit High
P2793 Gear Shift Direction Circuit
P2794 Gear Shift Direction Circuit Low
P2795 Gear Shift Direction Circuit High
P2796 Auxiliary Transmission Fluid Pump Control Circuit
P2797 Auxiliary Transmission Fluid Pump Circuit Performance
P2798 Auxiliary Transmission Fluid Pump Control Circuit Low
P2799 Auxiliary Transmission Fluid Pump Coontrol Circuit High
P2800 Transmission Range Sensor B Circuit (PRNDL Input)
P2801 Transmission Range Sensor B Circuit Range/Performance
P2802 Transmission Range Sensor B Circuit Low Input
P2803 Transmission Range Sensor B Circuit High Input
P2804 Transmission Range Sensor B Circuit Intermittent
P2805 Transmission Range Sensor A / B Correlation
P2806 Transmission Range Sensor Alignment
P2A00 O2 Circuit Range / Performance (Bank 1, Sensor 1)
P2A01 O2 Circuit Range / Performance (Bank 1, Sensor 2)
P2A02 O2 Circuit Range / Performance (Bank 1, Sensor 3)
P2A03 O2 Circuit Range / Performance (Bank 2, Sensor 1)
P2A04 O2 Circuit Range / Performance (Bank 2, Sensor 2)
P2A05 O2 Circuit Range / Performance (Bank 2, Sensor 3)
P2A06 O2 Circuit Negative Voltage (Bank 1, Sensor 1)
P2A07 O2 Circuit Negative Voltage (Bank 1, Sensor 2)
P2A08 O2 Circuit Negative Voltage (Bank 1, Sensor 3)
P2A09 O2 Circuit Negative Voltage (Bank 2, Sensor 1)
P2A10 O2 Circuit Negative Voltage (Bank 2, Sensor 2)
P2A11 O2 Circuit Negative Voltage (Bank 2, Sensor 3)
P3400 Cylinder Deactivation System Bank 1
P3401 Cylinder 1 Deactivation/Intake Valve Control Circuit / Open
P3402 Cylinder 1 Deactivation/Intake Valve Control Circuit Performance
P3403 Cylinder 1 Deactivation/Intake Valve Control Circuit Low
P3404 Cylinder 1 Deactivation/Intake Valve Control Circuit High
P3405 Cylinder 1 Exhaust Valve Control Circuit
P3406 Cylinder 1 Exhaust Valve Control Circuit Performance
P3407 Cylinder 1 Exhaust Valve Control Circuit Low
P3408 Cylinder 1 Exhaust Valve Control Circuit High
P3409 Cylinder 2 Deactivation/Intake Valve Control Circuit / Open
P3410 Cylinder 2 Deactivation/Intake Valve Control Circuit Performance
P3411 Cylinder 2 Deactivation/Intake Valve Control Circuit Low
P3412 Cylinder 2 Deactivation/Intake Valve Control Circuit High
P3413 Cylinder 2 Exhaust Valve Control Circuit
P3414 Cylinder 2 Exhaust Valve Control Circuit Performance
P3415 Cylinder 2 Exhaust Valve Control Circuit Low
P3416 Cylinder 2 Exhaust Valve Control Circuit High
P3417 Cylinder 3 Deactivation/Intake Valve Control Circuit / Open
P3418 Cylinder 3 Deactivation/Intake Valve Control Circuit Performance
P3419 Cylinder 3 Deactivation/Intake Valve Control Circuit Low
P3420 Cylinder 3 Deactivation/Intake Valve Control Circuit High
P3421 Cylinder 3 Exhaust Valve Control Circuit
P3422 Cylinder 3 Exhaust Valve Control Circuit Performance
P3423 Cylinder 3 Exhaust Valve Control Circuit Low
P3424 Cylinder 3 Exhaust Valve Control Circuit High
P3425 Cylinder 4 Deactivation/Intake Valve Control Circuit / Open
P3426 Cylinder 4 Deactivation/Intake Valve Control Circuit Performance
P3427 Cylinder 4 Deactivation/Intake Valve Control Circuit Low
P3428 Cylinder 4 Deactivation/Intake Valve Control Circuit High
P3429 Cylinder 4 Exhaust Valve Control Circuit
P3430 Cylinder 4 Exhaust Valve Control Circuit Performance
P3431 Cylinder 4 Exhaust Valve Control Circuit Low
P3432 Cylinder 4 Exhaust Valve Control Circuit High
P3433 Cylinder 5 Deactivation/Intake Valve Control Circuit / Open
P3434 Cylinder 5 Deactivation/Intake Valve Control Circuit Performance
P3435 Cylinder 5 Deactivation/Intake Valve Control Circuit Low
P3436 Cylinder 5 Deactivation/Intake Valve Control Circuit High
P3437 Cylinder 5 Exhaust Valve Control Circuit
P3438 Cylinder 5 Exhaust Valve Control Circuit Performance
P3439 Cylinder 5 Exhaust Valve Control Circuit Low
P3440 Cylinder 5 Exhaust Valve Control Circuit High
P3441 Cylinder 6 Deactivation/Intake Valve Control Circuit / Open
P3442 Cylinder 6 Deactivation/Intake Valve Control Circuit Performance
P3443 Cylinder 6 Deactivation/Intake Valve Control Circuit Low
P3444 Cylinder 6 Deactivation/Intake Valve Control Circuit High
P3445 Cylinder 6 Exhaust Valve Control Circuit
P3446 Cylinder 6 Exhaust Valve Control Circuit Performance
P3447 Cylinder 6 Exhaust Valve Control Circuit Low
P3448 Cylinder 6 Exhaust Valve Control Circuit High
P3449 Cylinder 7 Deactivation/Intake Valve Control Circuit / Open
P3450 Cylinder 7 Deactivation/Intake Valve Control Circuit Performance
P3451 Cylinder 7 Deactivation/Intake Valve Control Circuit Low
P3452 Cylinder 7 Deactivation/Intake Valve Control Circuit High
P3453 Cylinder 7 Exhaust Valve Control Circuit
P3454 Cylinder 7 Exhaust Valve Control Circuit Performance
P3455 Cylinder 7 Exhaust Valve Control Circuit Low
P3456 Cylinder 7 Exhaust Valve Control Circuit High
P3457 Cylinder 8 Deactivation/Intake Valve Control Circuit / Open
P3458 Cylinder 8 Deactivation/Intake Valve Control Circuit Performance
P3459 Cylinder 8 Deactivation/Intake Valve Control Circuit Low
P3460 Cylinder 8 Deactivation/Intake Valve Control Circuit High
P3461 Cylinder 8 Exhaust Valve Control Circuit
P3462 Cylinder 8 Exhaust Valve Control Circuit Performance
P3463 Cylinder 8 Exhaust Valve Control Circuit Low
P3464 Cylinder 8 Exhaust Valve Control Circuit High
P3465 Cylinder 9 Deactivation/Intake Valve Control Circuit / Open
P3466 Cylinder 9 Deactivation/Intake Valve Control Circuit Performance
P3467 Cylinder 9 Deactivation/Intake Valve Control Circuit Low
P3468 Cylinder 9 Deactivation/Intake Valve Control Circuit High
P3469 Cylinder 9 Exhaust Valve Control Circuit
P3470 Cylinder 9 Exhaust Valve Control Circuit Performance
P3471 Cylinder 9 Exhaust Valve Control Circuit Low
P3472 Cylinder 9 Exhaust Valve Control Circuit High
P3473 Cylinder 10 Deactivation/Intake Valve Control Circuit / Open
P3474 Cylinder 10 Deactivation/Intake Valve Control Circuit Performance
P3475 Cylinder 10 Deactivation/Intake Valve Control Circuit Low
P3476 Cylinder 10 Deactivation/Intake Valve Control Circuit High
P3477 Cylinder 10 Exhaust Valve Control Circuit
P3478 Cylinder 10 Exhaust Valve Control Circuit Performance
P3479 Cylinder 10 Exhaust Valve Control Circuit Low
P3480 Cylinder 10 Exhaust Valve Control Circuit High
P3481 Cylinder 11 Deactivation/Intake Valve Control Circuit / Open
P3482 Cylinder 11 Deactivation/Intake Valve Control Circuit Performance
P3483 Cylinder 11 Deactivation/Intake Valve Control Circuit Low
P3484 Cylinder 11 Deactivation/Intake Valve Control Circuit High
P3485 Cylinder 11 Exhaust Valve Control Circuit
P3486 Cylinder 11 Exhaust Valve Control Circuit Performance
P3487 Cylinder 11 Exhaust Valve Control Circuit Low
P3488 Cylinder 11 Exhaust Valve Control Circuit High
P3489 Cylinder 12 Deactivation/Intake Valve Control Circuit / Open
P3490 Cylinder 12 Deactivation/Intake Valve Control Circuit Performance
P3491 Cylinder 12 Deactivation/Intake Valve Control Circuit Low
P3492 Cylinder 12 Deactivation/Intake Valve Control Circuit High
P3493 Cylinder 12 Exhaust Valve Control Circuit
P3494 Cylinder 12 Exhaust Valve Control Circuit Performance
P3495 Cylinder 12 Exhaust Valve Control Circuit Low
P3496 Cylinder 12 Exhaust Valve Control Circuit High
P3497 Cylinder Deactivation System Bank 2
P0A00 Motor Electronics Coolant Temperature Sensor Circuit
P0A01 Motor Electronics Coolant Temperature Sensor Circuit Range/Performance
P0A02 Motor Electronics Coolant Temperature Sensor Circuit Low
P0A03 Motor Electronics Coolant Temperature Sensor Circuit High
P0A04 Motor Electronics Coolant Temperature Sensor Circuit Intermittent
P0A05 Motor Electronics Coolant Pump Control Circuit / Open
P0A06 Motor Electronics Coolant Pump Control Circuit Low
P0A07 Motor Electronics Coolant Pump Control Circuit High
P0A08 DC/DC Converter Fault Circuit / Open
P0A09 DC/DC Converter Fault Circuit Low
P0A0A High Voltage System Inter-lock Circuit
P0A0B High Voltage System Inter-lock Circuit Performance
P0A0C High Voltage System Inter-lock Circuit Low
P0A0D High Voltage System Inter-lock Circuit High
P0A0E High Voltage System Inter-lock Circuit Intermittent
P0A0F Engine Failed to Start
P0A10 DC/DC Converter Fault Circuit High
P0A11 DC/DC Converter Enable Circuit / Open
P0A12 DC/DC Converter Enable Circuit Low
P0A13 DC/DC Converter Enable Circuit High
P0A14 Engine Mount Control Circuit / Open
P0A15 Engine Mount Control Circuit Low
P0A16 Engine Mount Control Circuit High
P0A17 Motor Torque Sensor Circuit
P0A18 Motor Torque Sensor Circuit Range/Performance
P0A19 Motor Torque Sensor Circuit Low
P0A1A Generator Control Module
P0A1B Drive Motor "A" Control Module
P0A1C Drive Motor "B" Control Module
P0A1D Hybrid Powertrain Control Module
P0A1E Starter/Generator Control Module
P0A1F Battery Energy Control Module
P0A20 Motor Torque Sensor Circuit High
P0A21 Motor Torque Sensor Circuit Intermittent
P0A22 Generator Torque Sensor Circuit
P0A23 Generator Torque Sensor Circuit Range/Performance
P0A24 Generator Torque Sensor Circuit Low
P0A25 Generator Torque Sensor Circuit High
P0A26 Generator Torque Sensor Circuit Intermittent
P0A27 Hybrid Battery Power Off Circuit
P0A28 Hybrid Battery Power Off Circuit Low
P0A29 Hybrid Battery Power Off Circuit High
P0A2A Drive Motor "A" Temperature Sensor Circuit
P0A2B Drive Motor "A" Temperature Sensor Circuit Range/Performance
P0A2C Drive Motor "A" Temperature Sensor Circuit Low
P0A2D Drive Motor "A" Temperature Sensor Circuit High
P0A2E Drive Motor "A" Temperature Sensor Circuit Intermittent
P0A2F Drive Motor "A" Over Temperature
P0A30 Drive Motor "B" Temperature Sensor Circuit
P0A31 Drive Motor "B" Temperature Sensor Circuit Range/Performance
P0A32 Drive Motor "B" Temperature Sensor Circuit Low
P0A33 Drive Motor "B" Temperature Sensor Circuit High
P0A34 Drive Motor "B" Temperature Sensor Circuit Intermittent
P0A35 Drive Motor "B" Over Temperature
P0A36 Generator Temperature Sensor Circuit
P0A37 Generator Temperature Sensor Circuit Range/Performance
P0A38 Generator Temperature Sensor Circuit Low
P0A39 Generator Temperature Sensor Circuit High
P0A3A Generator Temperature Sensor Circuit Intermittent
P0A3B Generator Over Temperature
P0A3C Drive Motor "A" Inverter Over Temperature
P0A3D Drive Motor "B" Inverter Over Temperature
P0A3E Generator Inverter Over Temperature
P0A3F Drive Motor "A" Position Sensor Circuit
P0A40 Drive Motor "A" Position Sensor Circuit Range/Performance
P0A41 Drive Motor "A" Position Sensor Circuit Low
P0A42 Drive Motor "A" Position Sensor Circuit High
P0A43 Drive Motor "A" Position Sensor Circuit Intermittent
P0A44 Drive Motor "A" Position Sensor Circuit Overspeed
P0A45 Drive Motor "B" Position Sensor Circuit
P0A46 Drive Motor "B" Position Sensor Circuit Range/Performance
P0A47 Drive Motor "B" Position Sensor Circuit Low
P0A48 Drive Motor "B" Position Sensor Circuit High
P0A49 Drive Motor "B" Position Sensor Circuit Intermittent
P0A4A Drive Motor "B" Position Sensor Circuit Overspeed
P0A4B Generator Position Sensor Circuit
P0A4C Generator Position Sensor Circuit Range/Performance
P0A4D Generator Position Sensor Circuit Low
P0A4E Generator Position Sensor Circuit High
P0A4F Generator Position Sensor Circuit Intermittent
P0A50 Generator Position Sensor Circuit Overspeed
P0A51 Drive Motor "A" Current Sensor Circuit
P0A52 Drive Motor "A" Current Sensor Circuit Range/Performance
P0A53 Drive Motor "A" Current Sensor Circuit Low
P0A54 Drive Motor "A" Current Sensor Circuit High
P0A55 Drive Motor "B" Current Sensor Circuit
P0A56 Drive Motor "B" Current Sensor Circuit Range/Performance
P0A57 Drive Motor "B" Current Sensor Circuit Low
P0A58 Drive Motor "B" Current Sensor Circuit High
P0A59 Generator Current Sensor Circuit
P0A5A Generator Current Sensor Circuit Range/Performance
P0A5B Generator Current Sensor Circuit Low
P0A5C Generator Current Sensor Circuit High
P0A5D Drive Motor "A" Phase U Current
P0A5E Drive Motor "A" Phase U Current Low
P0A5F Drive Motor "A" Phase U Current High
P0A60 Drive Motor "A" Phase V Current
P0A61 Drive Motor "A" Phase V Current Low
P0A62 Drive Motor "A" Phase V Current High
P0A63 Drive Motor "A" Phase W Current
P0A64 Drive Motor "A" Phase W Current Low
P0A65 Drive Motor "A" Phase W Current High
P0A66 Drive Motor "B" Phase U Current
P0A67 Drive Motor "B" Phase U Current Low
P0A68 Drive Motor "B" Phase U Current High
P0A69 Drive Motor "B" Phase V Current
P0A6A Drive Motor "B" Phase V Current Low
P0A6B Drive Motor "B" Phase V Current High
P0A6C Drive Motor "B" Phase W Current
P0A6D Drive Motor "B" Phase W Current Low
P0A6E Drive Motor "B" Phase W Current High
P0A6F Generator Phase U Current
P0A70 Generator Phase U Current Low
P0A71 Generator Phase U Current High
P0A72 Generator Phase V Current
P0A73 Generator Phase V Current Low
P0A74 Generator Phase V Current High
P0A75 Generator Phase W Current
P0A76 Generator Phase W Current Low
P0A77 Generator Phase W Current High
P0A78 Drive Motor "A" Inverter Performance
P0A79 Drive Motor "B" Inverter Performance
P0A7A Generator Inverter Performance
P0A7B Battery Energy Control Module Requested MIL Illumination
P0A7C Motor Electronic Over Temperature
P0A7D Hybrid Battery Pack State of Charge Low
P0A7E Hybrid Battery Pack Over Temperature
P0A7F Replace Hybrid Battery Pack Deterioration
P0A80 Replace Hybrid Battery Pack
P0A81 Hybrid Battery Pack Cooling Fan Control Circuit
P0A82 Hybrid Battery Pack Cooling Fan Performance or Stuck Off
P0A83 Hybrid Battery Pack Cooling Fan Stuck On
P0A84 Hybrid Battery Pack Cooling Fan Control Circuit Low
P0A85 Hybrid Battery Pack Cooling Fan Control Circuit High
P0A86 14 Volt Power Module Current Sensor Circuit
P0A87 14 Volt Power Module Current Sensor Circuit Range/Performance
P0A88 14 Volt Power Module Current Sensor Circuit Low
P0A89 14 Volt Power Module Current Sensor Circuit High
P0A8A 14 Volt Power Module Current Sensor Circuit Intermittent
P0A8B 14 Volt Power Module System Voltage
P0A8C 14 Volt Power Module System Voltage Unstable
P0A8D 14 Volt Power Module System Voltage Low
P0A8E 14 Volt Power Module System Voltage High
P0A8F 14 Volt Power Module System Voltage Performance
P0A90 Drive Motor "A" Performance
P0A91 Drive Motor "B" Performance
P0A92 Hybrid Generator Performance
P0A93 Inverter Cooling System Performance
P0A94 DC/DC Converter Performance
P0A95 High Voltage Fuse
P0B00 Reserved by SAE
P0C00 Reserved by SAE
P0D00 Reserved by SAE
P0E00 Reserved by SAE
P0F00 Reserved by SAE
U0001 High Speed CAN Communication Bus
U0002 High Speed CAN Communication Bus Performance
U0003 High Speed CAN Communication Bus (+) Open
U0004 High Speed CAN Communication Bus (+) Low
U0005 High Speed CAN Communication Bus (+) High
U0006 High Speed CAN Communication Bus (�) Open
U0007 High Speed CAN Communication Bus (�) Low
U0008 High Speed CAN Communication Bus (�) High
U0009 High Speed CAN Communication Bus (�) shorted to Bus (+)
U0010 Medium Speed CAN Communication Bus
U0011 Medium Speed CAN Communication Bus Performance
U0012 Medium Speed CAN Communication Bus (+) Open
U0013 Medium Speed CAN Communication Bus (+) Low
U0014 Medium Speed CAN Communication Bus (+) High
U0015 Medium Speed CAN Communication Bus (�) Open
U0016 Medium Speed CAN Communication Bus (�) Low
U0017 Medium Speed CAN Communication Bus (�) High
U0018 Medium Speed CAN Communication Bus (�) shorted to Bus (+)
U0019 Low Speed CAN Communication Bus
U0020 Low Speed CAN Communication Bus Performance
U0021 Low Speed CAN Communication Bus (+) Open
U0022 Low Speed CAN Communication Bus (+) Low
U0023 Low Speed CAN Communication Bus (+) High
U0024 Low Speed CAN Communication Bus (�) Open
U0025 Low Speed CAN Communication Bus (�) Low
U0026 Low Speed CAN Communication Bus (�) High
U0027 Low Speed CAN Communication Bus (�) shorted to Bus (+)
U0028 Vehicle Communication Bus A
U0029 Vehicle Communication Bus A Performance
U0030 Vehicle Communication Bus A (+) Open
U0031 Vehicle Communication Bus A (+) Low
U0032 Vehicle Communication Bus A (+) High
U0033 Vehicle Communication Bus A (�) Open
U0034 Vehicle Communication Bus A (�) Low
U0035 Vehicle Communication Bus A (�) High
U0036 Vehicle Communication Bus A (�) shorted to Bus A (+)
U0037 Vehicle Communication Bus B
U0038 Vehicle Communication Bus B Performance
U0039 Vehicle Communication Bus B (+) Open
U0040 Vehicle Communication Bus B (+) Low
U0041 Vehicle Communication Bus B (+) High
U0042 Vehicle Communication Bus B (�) Open
U0043 Vehicle Communication Bus B (�) Low
U0044 Vehicle Communication Bus B (�) High
U0045 Vehicle Communication Bus B (�) shorted to Bus B (+)
U0046 Vehicle Communication Bus C
U0047 Vehicle Communication Bus C Performance
U0048 Vehicle Communication Bus C (+) Open
U0049 Vehicle Communication Bus C (+) Low
U0050 Vehicle Communication Bus C (+) High
U0051 Vehicle Communication Bus C (�) Open
U0052 Vehicle Communication Bus C (�) Low
U0053 Vehicle Communication Bus C (�) High
U0054 Vehicle Communication Bus C (�) shorted to Bus C (+)
U0055 Vehicle Communication Bus D
U0056 Vehicle Communication Bus D Performance
U0057 Vehicle Communication Bus D (+) Open
U0058 Vehicle Communication Bus D (+) Low
U0059 Vehicle Communication Bus D (+) High
U0060 Vehicle Communication Bus D (�) Open
U0061 Vehicle Communication Bus D (�) Low
U0062 Vehicle Communication Bus D (�) High
U0063 Vehicle Communication Bus D (�) shorted to Bus D (+)
U0064 Vehicle Communication Bus E
U0065 Vehicle Communication Bus E Performance
U0066 Vehicle Communication Bus E (+) Open
U0067 Vehicle Communication Bus E (+) Low
U0068 Vehicle Communication Bus E (+) High
U0069 Vehicle Communication Bus E (�) Open
U0070 Vehicle Communication Bus E (�) Low
U0071 Vehicle Communication Bus E (�) High
U0072 Vehicle Communication Bus E (�) shorted to Bus E (+)
U0073 Control Module Communication Bus Off
U0100 Lost Communication With ECM / PCM A
U0101 Lost Communication with TCM
U0102 Lost Communication with Transfer Case Control Module
U0103 Lost Communication With Gear Shift Module
U0104 Lost Communication With Cruise Control Module
U0105 Lost Communication With Fuel Injector Control Module
U0106 Lost Communication With Glow Plug Control Module
U0107 Lost Communication With Throttle Actuator Control Module
U0108 Lost Communication With Alternative Fuel Control Module
U0109 Lost Communication With Fuel Pump Control Module
U0110 Lost Communication With Drive Motor Control Module
U0111 Lost Communication With Battery Energy Control Module A
U0112 Lost Communication With Battery Energy Control Module B
U0113 Lost Communication With Emissions Critical Control Information
U0114 Lost Communication with Four-wheel Drive Clutch Control Module
U0115 Lost Communication With ECM / PCM B
U0116 Lost Communication With Coolant Temperature Control Module
U0117 Lost Communication With Electrical PTO Control Module
U0118 Lost Communication With Fuel Additive Control Module
U0119 Lost Communication With Fuel Cell Control Module
U0120 Lost Communication With Starter / Generator Control Module
U0121 Lost Communication With Anti-Lock Brake System (ABS) Control Module
U0122 Lost Communication With Vehicle Dynamics Control Module
U0123 Lost Communication With Yaw Rate Sensor Module
U0124 Lost Communication With Lateral Acceleration Sensor Module
U0125 Lost Communication With Multi-axis Acceleration Sensor Module
U0126 Lost Communication With Steering Angle Sensor Module
U0127 Lost Communication With Tire Pressure Monitor Module
U0128 Lost Communication With Park Brake Control Module
U0129 Lost Communication With Brake System Control Module
U0130 Lost Communication With Steering Effort Control Module
U0131 Lost Communication With Power Steering Control Module
U0132 Lost Communication With Ride Level Control Module
U0133 Lost Communication With Active Roll Control Module
U0134 Lost Communication With Power Steering Control Module - Rear
U0135 Lost Communication With Differential Control Module - Front
U0136 Lost Communication With Differential Control Module - Rear
U0137 Lost Communication With Trailer Brake Control Module
U0138 Reserved by Document
U0139 Reserved by Document
U0140 Lost Communication With Body Control Module
U0141 Lost Communication With Body Control Module "A"
U0142 Lost Communication With Body Control Module "B"
U0143 Lost Communication With Body Control Module "C"
U0144 Lost Communication With Body Control Module "D"
U0145 Lost Communication With Body Control Module "E"
U0146 Lost Communication With Gateway "A"
U0147 Lost Communication With Gateway "B"
U0148 Lost Communication With Gateway "C"
U0149 Lost Communication With Gateway "D"
U0150 Lost Communication With Gateway "E"
U0151 Lost Communication With Restraints Control Module
U0152 Lost Communication With Side Restraints Control Module - Left
U0153 Lost Communication With Side Restraints Control Module - Right
U0154 Lost Communication With Restraints Occupant Sensing Control Module
U0155 Lost Communication With Instrument Panel Cluster (IPC) Control Module
U0156 Lost Communication With Information Center "A"
U0157 Lost Communication With Information Center "B"
U0158 Lost Communication With Head Up Display
U0159 Lost Communication With Parking Assist Control Module A
U0160 Lost Communication With Audible Alert Control Module
U0161 Lost Communication With Compass Module
U0162 Lost Communication With Navigation Display Module
U0163 Lost Communication With Navigation Control Module
U0164 Lost Communication With HVAC Control Module
U0165 Lost Communication With HVAC Control Module - Rear
U0166 Lost Communication With Auxiliary Heater Control Module
U0167 Lost Communication With Vehicle Immobilizer Control Module
U0168 Lost Communication With Vehicle Security Control Module
U0169 Lost Communication With sunroof Control Module
U0170 Lost Communication With "Restraints System Sensor A"
U0171 Lost Communication With "Restraints System Sensor B"
U0172 Lost Communication With "Restraints System Sensor C"
U0173 Lost Communication With "Restraints System Sensor D"
U0174 Lost Communication With "Restraints System Sensor E"
U0175 Lost Communication With "Restraints System Sensor F"
U0176 Lost Communication With "Restraints System Sensor G"
U0177 Lost Communication With "Restraints System Sensor H"
U0178 Lost Communication With "Restraints System Sensor I"
U0179 Lost Communication With "Restraints System Sensor J"
U0180 Lost Communication With Automatic lighting Control Module
U0181 Lost Communication With Headlamp Leveling Control Module
U0182 Lost Communication With Lighting Control Module - Front
U0183 Lost Communication With Lighting Control Module - Rear
U0184 Lost Communication With Radio
U0185 Lost Communication With Antenna Control Module
U0186 Lost Communication With Audio Amplifier
U0187 Lost Communication With Digital Disc Player/Changer Module A
U0188 Lost Communication With Digital Disc Player/Changer Module B
U0189 Lost Communication With Digital Disc Player/Changer Module C
U0190 Lost Communication With Digital Disc Player/Changer Module D
U0191 Lost Communication With Television
U0192 Lost Communication With Personal Computer
U0193 Lost Communication With "Digital Audio Control Module A"
U0194 Lost Communication With "Digital Audio Control Module B"
U0195 Lost Communication With Subscription Entertainment Receiver Module
U0196 Lost Communication With Entertainment Control Module - Rear
U0197 Lost Communication With Telephone Control Module
U0198 Lost Communication With Telematic Control Module
U0199 Lost Communication With Door Control Module A
U0200 Lost Communication With Door Control Module B
U0201 Lost Communication With Door Control Module C
U0202 Lost Communication With Door Control Module D
U0203 Lost Communication With Door Control Module E
U0204 Lost Communication With Door Control Module F
U0205 Lost Communication With Door Control Module G
U0206 Lost Communication With Folding Top Control Module
U0207 Lost Communication With Moveable Roof Control Module
U0208 Lost Communication With Seat Control Module A
U0209 Lost Communication With Seat Control Module B
U0210 Lost Communication With Seat Control Module C
U0211 Lost Communication With Seat Control Module D
U0212 Lost Communication With Steering Column Control Module
U0213 Lost Communication With Mirror Control Module A
U0214 Lost Communication With Remote Function Actuation
U0215 Lost Communication With Door Switch A
U0216 Lost Communication With Door Switch B
U0217 Lost Communication With Door Switch C
U0218 Lost Communication With Door Switch D
U0219 Lost Communication With Door Switch E
U0220 Lost Communication With Door Switch F
U0221 Lost Communication With Door Switch G
U0222 Lost Communication With Door Window Motor A
U0223 Lost Communication With Door Window Motor B
U0224 Lost Communication With Door Window Motor C
U0225 Lost Communication With Door Window Motor D
U0226 Lost Communication With Door Window Motor E
U0227 Lost Communication With Door Window Motor F
U0228 Lost Communication With Door Window Motor G
U0229 Lost Communication With Heated steering wheel Module
U0230 Lost Communication With Rear Gate Module
U0231 Lost Communication With Rain Sensing Module
U0232 Lost Communication With Side Obstacle Detection Control Module - Left
U0233 Lost Communication With Side Obstacle Detection Control Module - Right
U0234 Lost Communication With Convenience Recall Module
U0235 Lost Communication With Cruise Control Front Distance Range Sensor
U0236 Lost Communication With Column Lock Module
U0237 Lost Communication With Digital Audio Control Module C
U0238 Lost Communication With Digital Audio Control Module D
U0239 Lost Communication With Entrapment Control Module A
U0240 Lost Communication With Entrapment Control Module B
U0241 Lost Communication With Headlamp Control Module A
U0242 Lost Communication With Headlamp Control Module B
U0243 Lost Communication With Parking Assist Control Module B
U0244 Lost Communication With Running Board Control Module
U0245 Lost Communication With Entertainment Control Module - Front
U0246 Lost Communication With Seat Control Module E
U0247 Lost Communication With Seat Control Module F
U0293 Lost Communication with Hybrid Powertrain Control Module
U0294 Lost Communication with Powertrain Control Monitor Module
U0295 Lost Communication with AC to AC Converter Control Module
U0296 Lost Communication with AC to DC Converter Control Module A
U0297 Lost Communication with AC to DC Converter Control Module B
U0298 Lost Communication with DC to DC Converter Control Module A
U0299 Lost Communication with DC to DC Converter Control Module B
U0300 Internal Control Module Software Incompatibility
U0301 Software Incompatibility with Engine/Powertrain Control Module
U0302 Software Incompatibility with Transmission Control Module
U0303 Software Incompatibility with Transfer Case Control Module
U0304 Software Incompatibility with Gear Shift Control Module
U0305 Software Incompatibility with Cruise Control Module
U0306 Software Incompatibility with Fuel Injector Control Module
U0307 Software Incompatibility with Glow Plug Control Module
U0308 Software Incompatibility with Throttle Actuator Control Module
U0309 Software Incompatibility with Alternative Fuel Control Module
U0310 Software Incompatibility with Fuel Pump Control Module
U0311 Software Incompatibility with Drive Motor Control Module
U0312 Software Incompatibility with Battery Energy Control Module A
U0313 Software Incompatibility with Battery Energy Control Module B
U0314 Software Incompatibility with For-Wheel Drive Clutch Control Module
U0315 Software Incompatibility with Anti-Lock Brake System Control Module
U0316 Software Incompatibility with Vehicle Dynamics Control Module
U0317 Software Incompatibility with Park Brake Control Module
U0318 Software Incompatibility with Brake System Control Module
U0319 Software Incompatibility with Steering Effort Control Module
U0320 Software Incompatibility with Power Steering Control Module
U0321 Software Incompatibility with Ride Level Control Module
U0322 Software Incompatibility with Body Control Module
U0323 Software Incompatibility with Instrument Panel Control Module
U0324 Software Incompatibility with HVAC Control Module
U0325 Software Incompatibility with Auxiliary Heater Control Module
U0326 Software Incompatibility with Vehicle Immobilizer Control Module
U0327 Software Incompatibility with Vehicle Security Control Module
U0328 Software Incompatibility with Steering Angle Sensor Module
U0329 Software Incompatibility with Steering Column Control Module
U0330 Software Incompatibility with Tire Pressure Monitor Module
U0331 Software Incompatibility with Body Control Module A
U0332 Software Incompatibility with Mulit-axis Acceleration Sensor Module
U0400 Invalid Network Data Received
U0401 Invalid Data Received from Engine/Powertrain Control Module
U0402 Invalid Data Received from Transmission Control Module
U0403 Invalid Data Received from Transfer Case Control Module
U0404 Invalid Data Received from Gear Shift Control Module
U0405 Invalid Data Received from Cruise Control Module
U0406 Invalid Data Received from Fuel Injector Control Module
U0407 Invalid Data Received from Glow Plug Control Module
U0408 Invalid Data Received from Throttle Actuator Control Module
U0409 Invalid Data Received from Alternative Fuel Control Module
U0410 Invalid Data Received from Fuel Pump Control Module
U0411 Invalid Data Received from Drive Motor Control Module
U0412 Invalid Data Received from Battery Energy Control Module A
U0413 Invalid Data Received from Battery Energy Control Module B
U0414 Invalid Data Received from For-Wheel Drive Clutch Control Module
U0415 Invalid Data Received from Anti-Lock Brake System Control Module
U0416 Invalid Data Received from Vehicle Dynamics Control Module
U0417 Invalid Data Received from Park Brake Control Module
U0418 Invalid Data Received from Brake System Control Module
U0419 Invalid Data Received from Steering Effort Control Module
U0420 Invalid Data Received from Power Steering Control Module
U0421 Invalid Data Received from Ride Level Control Module
U0422 Invalid Data Received from Body Control Module
U0423 Invalid Data Received from Instrument Panel Control Module
U0424 Invalid Data Received from HVAC Control Module
U0425 Invalid Data Received from Auxiliary Heater Control Module
U0426 Invalid Data Received from Vehicle Immobilizer Control Module
U0427 Invalid Data Received from Vehicle Security Control Module
U0428 Invalid Data Received from Steering Angle Sensor Module
U0429 Invalid Data Received from Steering Column Control Module
U0430 Invalid Data Received from Tire Pressure Monitor Module
U0431 Invalid Data Received from Body Control Module A
U0432 Invalid Data Received from Multi-axis Acceleration Sensor Module
Motörhead For Life!
INSTRUMENT CLUSTER FAILURE MESSAGE
Fault Code Description Correction
01 Airbag warning indicator output circuit shorted.
02 Airbag warning indicator output circuit open.
03 ABS indicator output circuit shorted.
04 ABS indicator output circuit open.
05 MIL indicator output circuit shorted.
06 MIL indicator output circuit open.
07 Wait to start indicator circuit shorted.
08 Wait to start indicator circuit open.
0B BTSI output circuit shorted or open.
22 Headlamp switch input circuit shorted.
23 Headlamp switch input circuit open.
24 Turn hazard switch input circuit shorted.
25 Turn hazard swiitch inpot circuit open.
27 Courtesy/dome output circuit shorted or open.
28 Glovebox/map lamp output circuit shorted or open.
29 Cargo lamp output circuit shorted or open.
40 Wiper switch input circuit shorted.
41 Wiper switch input circuit open.
42 Wash/beam input circuit shorted.
60 Passenger door lock switch input circuit shorted.
61 Passenger door lock switch input circuit open.
62 Passenger door lock switch input circuit stuck.
63 Driver door lock switch input circuit shorted.
64 Driver door lock switch input circuit open.
65 Driver door lock switch input circuit stuck.
66 All door lock output circuit shorted to ground or voltage.
67 All door unlock output circuit shorted to ground or voltage.
68 Driver door unlock output circuit shorted to ground or voltage.
6C Driver cylinder lock switch input circuit shorted.
6E Driver cylinder lock switch input circuit stuck.
80 Incorrect odometer value found.
81 Remote radio switch input circuit high.
82 Remote radio switch stuck.
A0 Internal module FLASH memory checksum failure.
A1 Internal module bootloader failure.
A3 Battery voltage open.
A5 TCCM messages not received.
A7 VIN checksum error.
A8 VIN previously stored.
A9 PCI bus internal failure.
AA PCM messages not received.
AB TCM messages not received.
AC ABS messages not received.
AD FCM messages not received.
AE ACM messages not received.
AF SKIM messages not received.
B0 RKE fob batteries low.
B1 RKE module communication link.
00 Done
Tricked out Ram
Discussion Starter #33
Tricked out Ram
Discussion Starter #35
Thats true. And we all know how many threads we see with codes in the titles
This is EXCELLENT information Found my code 0127f
THANKS
Tricked out Ram
Discussion Starter #40
I too tried to download and AVG found 2 virus's.
Thanks for trying!
There are no viruses in these I promise. There are simple PDF files with no .exe's.
21 - 40 of 46 Posts
