1 - 7 of 7 Posts
Just Got A Brand New 06 1500 Hemi Q/c, With 4wd Selector Knob, It Features 2hi, 4lock And 4lo. I've Just Read Somewhere Else That It Is An Awd Truck, Is That Right?
If only I had more $$$
On my 06 1500 hemi I have main 2wd, then also on selector auto, 4 hi 4 low. Not sure what you mean by 4lock other than 4wd, or 4hi as you didnpt mention it..
Awd
Yeah I Know It's Weird But It Has Only 3 Cases, 2hi, 4lock And 4 Lo, So I Guess They Mean 4hi By "4lock"
It's only AWD if it has the "Auto" setting on the transfer case selector switch. My '07 has "2HI" (rear wheel drive) "Auto" (four wheel drive with the differential in the transfer case open) "4Lock" (four wheel drive with the transfer case locked, ie, both front and rear drive shafts locked together and spinning at the same speed) and "4LO" which is what it says.
If you haven't got the "Auto" option in your transfer case, it's a Part Time 4WD truck.
r
My 04 Laramie is AWD. The Transfer case control reads AWD-4HI-4LO
owners manual should have the info.
Wifes durango is awd... awd . 4 lock . 4 low
1 - 7 of 7 Posts
