Vendor
From manufactured off-road trailers to DIY campers, Timbren Axle-Less Trailer Suspension has been the go-to suspension for the off-road trailer industry.
628755
Here is a bit more about it: Axle-Less Trailer Suspension - Timbren Industries Inc. Suspension Products
This award-winning product turns the traditional idea of trailer suspensions on its head. The most exciting feature about the Axle-Less suspension is the fact that it requires no axle!
Think about the possibilities. Imagine the freedom to go anywhere – without the usual restrictions of an axle. Experience a smooth, quiet ride made possible with Timbren’s rubber spring technology.
Features
The Axle-Less trailer suspension is unique and will take you on new adventures.
  • Maximize Ground Clearance
  • Progressive Jounce Spring
  • Rebound Spring For Constant Tension
  • Easy Bolt-On Installation
  • Urethane Bushings For Quiet Operation
Steel Components
All of our steel brackets & disks are laser cut before they are painted with a durable, long-lasting powder coat finish to ensure protection and long life.
Bushings
We use premium urethane bushings in the design of the Axle-Less suspension. Small grooves have been machined into the bushings allowing grease to lubricate the pivot point. This provides added quiteness to the suspension.
Rebound Spring
This spring plays an important role in the operation of the suspension. It creates constant tension on the jounce spring when the trailer is empty. This means that full or empty the trailer will always have a smooth ride and will never bounce around like a typical trailer suspension.
Anything But Ordinary
Ordinary solutions solve ordinary problems. But when the problem is anything-but-ordinary, an extraordinary solution is required. Watch how the extraordinary Axle-Less suspension can solve off-road problems…
HD Models
The Axle-Less HD editions are designed to take the abuse seen on any off-road expedition. We use thicker steel for added strength and a softer Aeon® spring for more suspension travel. This suspension will take your expedition to new places.
Off-Road & Overland
Maintain the same ground clearance on your trailer as you have on your tow vehicle… and stop worrying about axle hang-ups!
Work Trailers
Whether you use your trailer to haul fire wood or run a landscaping business, the Axle-Less trailer suspension will enable you to get the job done.
Boat Trailers
The Axle-Less design allows for a lower centre of gravity on boat trailers. This unique characteristic paves the way for improved handling at high speeds.
628756
