I have a 96 Dodge Avenger and the rear shock mount ripped right out of its housing. Does anyone know what that piece is called that holds the shock mount on the rear. If you pull the backseat down it is right under the rear deck. It has 2 nuts and in the middle the rear shock is held. If anyone does know what this is what do I need to do to replace it. I am sure I will have to pull the spring out. But will I need a spring compressor to pull the shock out to replace it? :help:
