1 - 15 of 15 Posts
Keystoner
Just went to NJ over the weekend. Got home and got a lil surprise. Water pump leaking. I guess it could have been a lot worse. I'll be using my next 3 days off to fix it. I got all the warning signs. Whine'n noise when turning left and a lil fluid on the ground. I've done a search and I'll be change'n it myself. Can't see dishing out all that $$$$ with the holidays coming. Any and I mean any tips please hook a brotha up LOL
rock
Keystoner
Discussion Starter · #2 ·
Bummer, dude...
Hummer Recovery Vehicle
hey rock - that is a really simple swap out. if you need any help , let me know. definately best to do that job on your own if you have any mechanical skills whatsoever.
Keystoner
I think I can pull it off. I'm gonna make sure I have the tools today. Then price'n the pump. Napa/on line/dealer......
Keystoner
Discussion Starter · #7 · (Edited)
I'll take some pics and write down some nut sizes as I go. What's up with the damn heater tube? that's kicking my ass right now....won't come out of the old pump
Keystoner
Discussion Starter · #8 ·
dealer wanted $135 for water pump. advance was $74 with a life time warranty. when removing the heater hose tube do not twist it. it pulls straight out. replace O-ring if bad ($3). wet seal all hose fitting with RTV. if you mess the heater tube up it's $29. radiator shroud is 10mm, water pump bolts 9/16 (center bolt is a torx T47) and belt tensioner nut 9/32. when installing pump torq water pump bolts to 20ft lbs. heater tube goes in last. good time also to change lower radiator hose, timing belt, t-stat & fluid of course. pics are coming just need to download em
I've read a few posts that have indicated that it easier to just replace the tube.
Keystoner
Discussion Starter · #10 ·
here's some install pics....
pic 1 big frigg'n screw driver to keep pulley from spinning.
pic 2 heater tube that pulls straight out when swapping to new
pic 3 bypass hose. a biautch to get to
pic 3 just a lil some'n to help remember what goes where.
pic 4 bypass bung wet dipped
Keystoner
Discussion Starter · #11 ·
pic 1 old vs new
pic 2 back together
pic 3 heater tube hole
hope that helps anyone need'n to do this job. you'll save by doing it yourself.
WORLD'S GREATEST TRUCK
Nice job, did you do the timing chain?
Keystoner
Discussion Starter · #13 ·
nah.....thought about it lol
Patriot....
I swapped my WP on my old 5.2L Dak - the AutoZone water pump heater hose outlet was not perfectly round so it would leak. They replaced the pump for free so I got to do the job twice.
Good pics!
Northeast DDRC Webmaster
Good pics!
LOL
:thatfunny ...I'm not laughing at you bro, just at the way you said it in the last sentence. Sucks though.
1 - 15 of 15 Posts
