1 - 10 of 10 Posts
Hummer Recovery Vehicle
the 360 rt motor from what i know is the same as every other 360 placed in the durango. however, on a few years, they had a different pcm. all years have a "high flow" exhaust. that's where they get the extra power from. there is honostly really not that big of difference between an slt with a 360 and the rt
You can buy RT heads from mopar but were never stock
Stock R/T Durangos anf Dakotas have the exact same engine as every other 5.9. The 2000-early 01 Durango R/T's had 5 more HP due to a unique PCM. 01-03 has the SLT PCM and the same HP. As mentioned above, Mopar has heads that are called "R/T" for the Magnum engine but they are strictly aftermarket.
"TRUCKIN"
would you gain power if you switched to a 5.9 head on a 5.2 block?
ehh.. are they even compatible with different intake/exhaust valves? would there be a clearance issue? they 're the same block aren't they? maybe not. i'm not sure seeing as i have the 4.7, but they may be. I dont know if you'd gain more power. By the time you put those heads on, even if they did give a little more power. . . for the cost, you chould cam your 318 and have more power.
5.2 and 5.9 use the same heads.
"TRUCKIN"
but isnt the bore bigger on the 5.9? its a bigger motor.
Platinum 2K R/T
I don't think the 5.2L heads will fit on the 5.9L:
http://autos.msn.com/research/vip/spec_engines.aspx?modelid=3114&trimid=-1&src=VIP&tab=2&sub=1
The bore is wider by 0.9in and the stroke is 0.27in longer. If the bores were the same I'm sure the head would fit without any machining. Most engines are manufactuered with tolerances of 1/1000th of an inch. 0.09" is fairly large.
I doubt the 5.9L heads will give the 5.2L more power/performance. Magnum is the manufacturer of the heads on all the V8 engines. There is no difference except for the size (if ever so slight), to give any noticeable performance.
The R/T PCM also requires premium fuel!! Oh goodie.
Here are the above mentioned Mopar "R/T" heads. The same heads fit 5.2 and 5.9
Magnum R/T cast iron cylinder heads
The new cylinder heads for the V8 magnum
engines to fit 1992-02 5.2L and 5.9L
versions and all magnum crate motors.
Uses production valve gear(rocker arms,
valves,valve springs,keepers and retainers)
works with factory and MP magnum engines
and stock intake manifolds,exhaust manifolds,
and valve covers.
MAGNUM CAST IRON CYLINDER HEADS
Cast iron 1992–02 5.2L/1993–03 5.9L Magnum cylinder heads fit right
out of the box with no modifications on all Magnum crate engines
and Magnum engines. These heads feature:
• Higher airflow and performance over the
stock 360 (pre-Magnum) cast iron heads
• Economical Magnum valve gear options
• Vertical-style intake manifold attachment
• 10-bolt valve cover design
*P4876256 NEW! Magnum 5.2L/5.9L Bare
Machined Production Cylinder Head — for
use with 1.92" intake / 1.625" exhaust valves
1 - 10 of 10 Posts
