1 - 12 of 12 Posts
LivetoRide
I am wondering what people do with their sirius/xm antennas when going out the 3rd brake hole, do you just let the wire site under the stripping on the light and then tighten it down? leaks/no leaks? I want to put mine out there in the middle of the roof so it looks clean/out of the way. Thanks!
I put new silicon sealant around the light when I put my antenna through....no leaks.
LivetoRide
cool thanks for the replys, I am gonna try it for abit with the wire routed sorta around the light and through the stripping on the bottom and see how that does, I might end up throwin a bead of sealant around if I get paranoid
Tank Mech
That's where mine is. I snuck it around the seal and brought it in from the bottom. No leaks.
I did the exact same thing. No leaks and not sealants.
Dan
I never had a problem in the rain with water....it was usually when I went through a carwash or used the powerjet and the do-it-yourself carwash.
1 - 12 of 12 Posts
