1 - 20 of 24 Posts
Administrator
I decided to try and flip my overloads this weekend since Dodge decided to put them in upside down. It was super easy and when I got everything back together, I got roughly 1" of lift. The ride is just slightly stiffer in the rear and does not feel like it's bottoming out when hitting a bump. Hopefully now when I have a load in the bed or a trailer hooked up the rear will not sag so much.
Anyone else done this?
Power Wagon #1605
never even thought about it
Double Rammin'
I did the ones on my 02 before I got it back on the road again, and like you said a fairly easy mod. What did you torque your U-bolts down to? I have had to re-torque mine a couple of times now (used new u-bolts since the originals were bent in the accident) and I'm going to 100 ft-lbs. I haven't noticed any stiffer of a ride, but I know with some weight in the bed the spring rate is higher with less travel needed.
Administrator
Somewhere between tight and very tight. :D
Double Rammin'
I have been thinking about doing mine. You have any before and after pics?
I thought about it, I have 2" lift blocks and never got around to finding longer u-bolts
Administrator
Discussion Starter · #9 ·
Do you want pics of the whole truck or just the overloads? I have before pics in my gallery and will try and take new ones tonight.
Of the whole truck, thanks
Administrator
Discussion Starter · #11 ·
I finally have pics of my flipped overloads. I got about 3/4" lift from doing this and the ride quality has not changed. With the 2" front level, the truck sits 1" taller in the rear.
You've been Hijacked
looks good man
Registered MOPAR User
I did it to my QC LB with shell and carpet kit, it does make it bounce a little more on the bad portions of the freeway. looking to add airshock on top of the Ranchos to help the backend hop.
Im going to want to do this now
Former F150 guy
Now that you have been driving it for a while, any regrets at all? Have you pulled a trailer yet? Is it still riding as smooth as stock?
-Arana-
Thats a nice truck
Administrator
Discussion Starter · #20 ·
Nice job Morgan... You live in south Broken Arrow huh?
Thanks, it was a good excuse to get out in the garage for a while. Getting married in a few weeks and need all the wedding planning breaks I can get.
I am actually in south Tulsa, just a little west of BA.
1 - 20 of 24 Posts
