1 - 2 of 2 Posts
Hey, my ball joints are pretty worn and ruining my tires and I've also got a hub on the way out. I'm planning to replace all ball joints on both sides, tie rod ends, both wheel bearings, shocks, and the bushings for mounting the shocks. Is there anything else I should replace while I'm in there? Mostly thinking preventative maintenance and saving time while I've got it all torn apart. Brakes are still mint so that's not a worry.
Also, my front axle seal is a little leaky so I might have do that at the same time too, even though I just did them 25k ago :/ Is it worth replacing the bearings for the front stub axle as well? I really don't want to tear into the front diff too much but if I gotta open it up I want to do everything now.
This is for a 2004 ram 1500 5.7 4x4 automatic
1 - 2 of 2 Posts
