You may remember quite a while back I was have some problems with the way my 2000 Ram Van was running
to review:
Its a V6 3.9L
I have no codes
occassionally it will run rich after I start it up
I have changed everything I could think of, including a complete tune up (plugs, wires, cap, rotor, pcv valve)
I have a clean K&N drop in the stock air box air filter
All the fluids are regularly changed
Nothing wrong with the cat converter
and when I have this problem, it seems like I have a HUGE racing cam in it, because - you know the sound of an old muscle car with a huge cam in it while its idling ? Sounds like it just barely turns over before it stalls out ?
Thats what its been doing
but just occassionally, which has been hard as heck to duplicate in front of a mechanic
but here's the info because a Mopar tech FINALLY got it figured out:
I have 1 bad fuel injector
it is basically just slowly leaking fuel down into the cylinder while it sits for a while.
Then when I fire it up, I get that race cam at idle kinda feel because that one cylinder is struggling to burn thru the fuel that is pooled up in there = thus the rich smell
Because the way I have "fixed" it when it happens was: I just rev'ved up the engine until it cleared
Well, thats what they say anyway
I haven't got it fixed yet ... can you imagine what the labor cost will be to dig under there, somewhere between under the hood and doghouse ...
I will eventually get it fixed
but I thought I'd let you guys know what the Mopar tech found out ...
FYI
to review:
Its a V6 3.9L
I have no codes
FYI
