I have a 2005 Grand Caravan with 45,000 miles. I just replaced the sway-bar links with a pair of Moog links, HUGE difference. While I was replacing them, I noticed there's some play in the front-end. Meaning, if I grab the rotor I can wiggle it back & forth. At first I thought it was the wheel bearings, but on closer inspection, the play is not at the rotor/spindle area. It appears that the whole wheel/strut assembly is moving. I thought maybe the links would fix it, but they didn't.
The result is front-end vibration. This is not the noise/vibration under acceleration that's typical when CV joints go bad. I mostly notice it under braking and it feels a lot like a warped rotor.
Any ideas on what else it could be?
Thanks,
E-
Thanks,
E-
