1993 Caravan LE with the 3.3 engine and 41TE transmission-
A couple of weeks ago it dropped into neutral while cruising at 65 on the highway. I moved the gear selector into "N" and coasted to a stop, put the selector into park, turned off the engine, restarted, and went on my way again with no other issues. A week and a few hundred miles later the same thing happened, in the same order. Since I have had mysterious problems with the cruise control dropping out (and because it did not cost much money) I went ahead and replaced the input and output speed sensors. Since then, I can only drive it a couple of miles before it drops into limp mode and will not come out. When I turn it off and restart it tries to go into first but seems to slip a little, and then bangs into limp mode. When it does work, though, it is perfect, with no bad symptoms.
The trans was rebuilt about 45K miles ago, and at that time I also added a large cooler in front of the radiator- bypassing the one built into the radiator. The fluid looks perfect (has been changed twice since rebuild) and there were no metal shavings on either of the speed sensors. I have not dropped the pan yet to see what is in there.
Should I go ahead and replace the solenoid pack and see if that fixes it? It is about 40 miles to a dealership to get the codes scanned, and I don't trust any of the repair shops around here to give me the actual codes. I don't really have any experience with this trans, but have a lot of general mechanic experience.
Thanks for any advice!!
