1 - 10 of 10 Posts
5 Years... 6 Dodges
Ok, I asked about one of these in my other thread, but my stuff always seems to get skipped, so I'll ask here. lol Anyhow, here's what I'm wondering:
Ok, so a 4 channel amp can either be used as 4 channels, bridged for 2 channels and even bridged to 1 channel right? Well, is it possible to bridge it to 2 channels to run my subs and still use the 4 channels by themselves for the doors? I'm looking at getting an Audiobahn A4125HCT amp and it's rated at 125x4 @ 4 ohms 500x2 @ 2 ohms. If it can be done... then that'd be great for my system.
The other hitng... I know door speakers are setup at 4 ohms, but is there a way to get them down to 2 ohms? This really only applies if the above setup doesn't work and I look at getting another amp that is 75x4 @ 4 phms or 150x4 @ 2 ohms. Obviously since they're the door speakers and there's four of them, I don't want to bridge or wire them together as I'd like to have the speakers independant of each other.
4 channel amp can be 4 channels or 2 channels.......bu it can not be one channel.
yes you can use it to run subs and all four, you will need a high pass PASSIVE crossover to the left and right speakers and a low pass PASSIVE crossover to the bridged sub......go here to learn more click----->basic car audio
Orion used to make 2 ohm speakers, HCCA line of seperates.......but IMHO you do not need to do this.......
I would use the deck to power your interior speakers... most are 18 watts or more x4 with 50 watts max x4... That would run it fine. I would reccomend getting a 2 channel amp and bridging the channels... When you bridge a 2 channel the watts almost triple... The rockford fosgate P6000 is 200watts x2 but when bridged it is 600watts x1. I would run your subs in mono from a dedicated amp. Your door speakers dont need that much power because the subs will be taking care of the low end wattage. Check my signature for my setup... I got my system for less than half the price I was quoted from a shop by going ebay...
Hemi Power
If you want any kind of sound quality, DO NOT use the amp in a deck. Amp's are too cheap nowadays to even consider such a silly thing. Hell, you can get a decent 2-channel amp for less than $100...
I'll have to agree with that.
Ditto.......not a good sound quality idea at all
my alpine does 50w max per channel, it will work fine on my type s's
Hemi Power
viper24, it MIGHT do 50w max. Maybe. That's about 20w rms MAYBE. A separate amplifier is the way to go. But, hey, do what you want...
5 Years... 6 Dodges
Discussion Starter · #9 ·
I can't recall off the top of my head what my MB Quartz are, but they were either 130 or so RMS or max which is why I wanted to run them off an amp.
SO, I just need to get a high pass passive and a low pass passive (or 2?) crossover?
Also, here's how I was planning on setting it up...
125 x 4 @ 4 ohms
500 x 2 @ 2 ohms
Subs are DVC 4 ohms which can be wired to 2 ohm loads individually which is why the 2 channels are used.
I agree also...Run your doors and a seperate amp...
1 - 10 of 10 Posts
