ok I installed a new power acoustik amp and two new 10" cadence SVC 2ohm subs wired to show 1ohm. The problem is when i turn the ignition on and the radio is playing the amp is on and has power according to the LED's yet i get no sound from the subs. Im pretty sure the wiring is correct on the subs but another weird problem from this is that the amp stays on lond after the ignition is tunred off. It seems the remote turn on lead is supplying the amp with continuous power. Does this sound like the problem is in the sub box wiring? thanks in advance-
Brannon
Brannon
