I was feeling great today after installing a new coil, ignitor, and pretty much all the wiring in the ignition circuit (been meaning to do that all year). Fired it up and while it didn't sound any different at idle, or drive dramatically different, I thought it might have had a little extra pep under acceleration--then again I could've been imagining it. Well at least I don't have to worry about some corroded connection or bad part causing an issue some rainy night. Proactive maintenance, right?
On the way home I noticed my ammeter reading almost half into the discharge zone (lights were on). Hmmmm...what's up with that? I turned a corner and the needle jumped up into the charge zone momentarily, then back in D. OK, I thought, must be that maine BATT output stud that spun a bit when I threaded the nut on holding the ring terminal. Must be an intermittent connection there? The alternator repair kit just arrived a few days ago...guess what task just jumped to the top of my "to do" list?
So after getting home I pull the alternator to get it ready for the overhaul. What do I see but a big crack in the housing--well, so much for repair, may as well replace the whole thing (which I bought for $80 at NAPA seven years ago). Wonder how it cracked? I always use an old axe handle to adjust the belt tension, wouldn't think that would have the force to crack the (aluminum?) housing.
Did a quick survey of the alternators available at NAPA and Rock. Inclined to go with Rock this time--but which brand is the most reliable? They're all remanufactured, that's fine, I just want something I'm not going to have to worry about for many years. The Bosch ones seem like a good bet, but I really don't know the first thing about remanufactured alternators. Any tips appreciated.
Any other thoughts on ammeter reading? Am I missing something? I suppose I should double check the voltage regulator connection also...but in any case I want to replace the cracked alternator whether it works or not.
