1 - 3 of 3 Posts
After installing a leveling kit (2'') on my 04 2500 4x4 I had the front end aligned at my local dodge dealer {hoping that would eliminate my death wobble and steering wheel twitching problem } (these problems occured after the lift) Anyway after looking under the truck , I noticed the only thing they changed was the toe and centered the steering wheel. The caster was not adjusted (i could tell this from dirt on the bolt head. Shouldn't the caster be adjusted with the lift? Guess what still has dw and the twitches not to mention the brutal crunching noise after hitting a good pot hole. THe truck is all stock except for the tc kit. I would greatly appreciate any hints
thank you
1 - 3 of 3 Posts
