im not sure i rigged mine but its not right and the saftey strap wont fit.... so im also interested i have the metal l bracket on the top i couldnt get it to fit on the bottom...
In many of our older AIR RAM systems we had installed air temperature sensors... if yours has one then all you need to do is plug the "PLUG END" of the POWER WIRE into the sensor and then the to prong ends into the grey plug... real simple. If your going from a 5.7L to a 4.7L or vise versa then you will need approximately 6" of 1/2" heater hose, 6" of 5/8's heater hose and a 1/2 to 5/8th adaptor... all can be found at Auto bone or most auto parts stores.PatriotBlueHemi said:Hi Nick,
I have the "L" bracket, but can not figure out where to mount it? Also the plug on the bottom back of the intake tube is for the Air Temp Sensor right? Thanks in advance.
Steven
