1 - 6 of 6 Posts
Christopher
Anybody have problems with the airbag light coming on? The last couple of days, mine has been coming on for a few minutes, then it goes back out again, then a few minutes later, it comes back on. The on/off pattern is not consistent in terms of time between events, but it's pretty steady.
It does this whether the seat is empty or if I have an adult passenger.
Any ideas?
Thanks -
Christopher
Sounds like a crash sensor is faulting. Have your data port scanned for code(s), there should be at least one code stored. This should give you some ideas.
same thing happens on my jeep commander, i'll just let the dealership know next time i get the maintenence
Christopher
Airbag light coming on - Resolved.
The problem has been resolved under warranty. There's a "clock spring" in the steering column that is used for steering wheel controls. The spring was shorted out.
Christopher
If it happens again, run it into a tree and make sure the airbags work....lol.. J/K....
Any ideas?
Thanks -
Christopher
Does it 'beep' along with the light being on?
Normally, I wouldn't notice it cuz it came on so quickly a couple times. But when I'm driving and all of a sudden I hear a beep for about 2 seconds....look down and see the airbag light on.
Question for you guys.....
If I take my truck to Autozone/pepboys or whatever to have the codes pulled - will the codes STAY within the computer?? Or do they get erased?
I'd like to get them pulled myself and do some research - but I also want to 'leave it alone' for the dealer to figure out (still under warrantee).
1 - 6 of 6 Posts
