Well, I finally got enough time to go out and install my Split Second ARM1 (Air/Fuel Ratio Meter). I drove around for about 20 miles or so after the installation and I learned that my truck seems to be operating fairly good from an air/fuel ratio perspective.
-At cold start-up and idle, it is rich, but after it warms up, I dither right around the ideal stoichiometric air/fuel ratio of 14.7:1. A consistant dither speed that is close to 14.7 means the PCM is doing a good job of dialing in the air/fuel ratio while in closed loop mode.
-At cruise speeds (still closed loop), I am in that same ideal range still (good for fuel economy like that).
-The point where I have noticed that I seem to always have the most power (mid rpm, about 1/2 to 3/4 throttle), I am at about 14.5:1 to 14.2:1, just a tad rich. That might explain why it seems to have the most power at that time.
-Lastly, at full throttle (open loop), I am very rich, at least 12.5:1 (not sure how rich for sure, that's as low as it goes on the meter). I expected it to be rich at WOT, but not sure if I want it that rich. I does a good job of reining that in after a few seconds, though.
Next install will be the Split Second ARC1 (Air/Fuel Ratio Calibrator), which will let me manually adjust how rich I want to run in various modes (open loop, closed loop). I'll be able to dial down that WOT richness, and we'll see if that makes any difference.
Here's some pics. I mounted it high so that I could watch it without taking my eyes off the road to much. I think I may install a switch with it so I don't have to have it going all the time, just when I want to see how things are doing, or I need to make an adjustment.
