I'm having a problem in my 99 D with the switch that changes the air flow from A/C to heat to defrost. The air comes out of the defrost if you put it on A/C the air gets cool but still blows on the wind shield. Has anyone had this kind of problem before? :help:
Jbird,
No, I didn't have that problem with my old 98 D which I traded in for my 04. However, you posted in the G2 area. You'll get more responses if you post in the G1 area.
Raiders63
I may be too late, but had the exact same problem on my 2001 Ram. Turned out to be a manifold gasket leak. As it was explained to me, the system works off of a vacuum and the leak did not system to function.
