dont use the extensions with those,in case I didnt tell you so.yamasaki said:i got the BellTech Nitro DropII Shocks
10-4!! :gr_patrioslammed1 said:dont use the extensions with those,in case I didnt tell you so.![]()
2-4 drop?spindles? what front shocks?Prism said:austin4.7l; those are Monroe Reflex series shocks on my truck. They are stock length. I'm using shock extensions on the rear as well.
Ditto here, I've got the McGaughy's 2/4 with air assist from Brian. I also added the on-board compressor from Summit, I would have purchased from Brian, but he was temporarily out of stock on those. I like the kit, but I would consider going lower than 2/4, if I had to do it again.Prism said:I've got the McGaughy's air assist on my truck that works specifically with the McGaughy's flip kit on my truck. I bought everything from Brian(slammed1). He has a website you can check out: www.slammed1.com for more info. I don't remember any of the part numbers so you might want to contact Brian on those. Hope that helps out some. :tup: I've got some pics of my setup for you to check out.
