I recently installed a aftermarket radio in my 05 ram, which had the infinity setup in it, and for the longest time I couldn't get any sound to come out, put now I have found a wiring harness that works for the 05 rams with infinity. The harness is made by metra, and it costs around 60 bucks, and you get about 6 feet of wiring with to hook up all the speakers. All you have to do is remove the infinity amp and install the harness. As long as you have a radio powerful enough do power all 7 speakers, the sound difference is better than the infinity. Hope this helps all you guys who are having this problem.
I had the same problem w/ my 01 D w/ an infinity system. Not sure if it's the same thing as the 05 Ram, but I found that the remote wire from your CD player needs to be hooked up to the Power Antenna(correct me if i'm wrong, I think it's a solid blue wire as well) wire of the wiring harness to turn on your Infinity Amp.
