1 - 2 of 2 Posts
Anyone has any idea whats wrong with my 2010 Ram1500? Some months back I changed my alternator. When finished I jumped started the truck cause battery was dead. The truck started, ran for about 10-15 secs and died again. Took the battery out and replaced it. Fired and drove fine for a few days. I parked it for about 2 weeks. Tried starting it and it wouldn't fire. Turn over very strong but won't fire up. Changed fuel pump and still no dice. Im thinking I messed up the computer by disconnecting the battery (both terminals). Any suggestions?
I assume you've tried the obvious at this point. Getting gas? spray some starting fluid into the carb and see if it will start. getting spark? getting air?
Do you have a code reader to see if there is anything there?
I would take a look at the following:
cam and crank position sensors.
Throttle position sensor
MAF sensor
I don't remember exactly how to test them all but I had a similar issue in my 05 4.7. Maybe someone else can tell you how to test them easily or the ever-knowing Google.
1 - 2 of 2 Posts
