1 - 3 of 3 Posts
Well I was at the lake this weekend, and I saw a 1500 Ram QC, with some Black KMC Rockstar Rims and Superswamper tires. Man did it look mean. It definitly had a lift on it, and when I parked next to it mine was almost as high. His was maybe an inch higher, and I don't even have a lift. Do the 2500's come higher than the 1500's with 20's in them? Also, I don't want to lift my truck so what is the biggest size of rim and tire that I can go with, that won't rub or change much?
Here is the rim. Its the black rockstar model:http://www.kmcwheels.com/xdseries/wheels.html
Dodgezilla
I think you can go with a 285 or 305 with no rub. 315s rub slightly but not enough to worry about. That's with stock rims though. If you go aftermarket with different offset then 315s might even fit w/ no rubbing....
5 Years... 6 Dodges
I had 305s on mine... but they were on 20s and 305/55/20s = 33.2"x12 and they were no problem.
And yes, the 2500s are taller then the 1500s stock.
1 - 3 of 3 Posts
