My 2K Dakota has both fans. What I'm wondering is if the electric fan is a puller or a pusher? And, one should be able to get a new thermostatically controlled radiator switch to turn the fan on from the inside temp's of the radiator. I converted my 1998 BMW M3 over to this setup by using a colder thermostat, colder radiator switch, 2 bottles of Water Wetter combined with BMW-only coolant (+$28/gal.). On my 1991 Nissan 300ZX TT, I also eliminated my clutch fan 6 years ago by installing a 16" Fluidyne puller and setting up a manually-controlled temp. probe much like what Scottcba1 has done to his Dakota. Personally, I don't like my car setup this way. It may work fine for the Dakota, but I would think a radiator switch might work better.
BTW, Scottcba1, where are you located again? If it's anywhere in a hot climate, and you have no cooling issues then I may try this conversion as well on my Dakota. My M3 was just converted 2 weeks ago and we've had 100+ temp's in Idaho; no cooling issues to report for my M3. The conversion should be cost minimal with normal hand tools.
