Originating Member
Do It In A Van
Where does the switch mount? Is there a blank on the dash or does it mount where the power window switches mount? I would pull the door panels off and see if the factory used a common harness. In other words, the power mirror connection may be taped up in the harness. If this is the case you could just plug your mirrors and switch in.
Do It In A Van
The factory probably just used a "blank off" panel that can be popped out. Hopefully the harness for the power mirrors is behind that door panel and is just taped off. Do you have a factory service manual for your van?
When Dodge Rams went from the chrome mirrors to that black plastic design, I seem to remember that quite a lot of the mirrors had loose parts that vibrated. Might want to double check the tightness of all connections before installing.
I myself have wondered if the mirrors off the PT Cruiser would bolt up in place of Van or pickup mirrors.
