We will be adding a toilet paper oil filter (Frantz Oil Filter) to this 1993 B250 318 van. The issue we have is where are the best sources of feed (oil to the filter) and return (oil back to the engine from the oil filter)?
The Oil Pressure Sending Unit is a source of feed. We could install a tee at the base of the sending unit. Or, we could purchase an adapter (spin on adapter between the block and spin-on oil filter) as our feed point.
The return line back to the engine is not as straightforward. I could tap into the side of the oil pan with a self-tapping hollow bolt. Or, we can purchase a hollow bolt to replace one of the manifold bolts as our return point.
Many here have probably installed external oil coolers and been through this FEED-RETURN line issue. You may have experience and opinions.
My best opinion is to drop the oil pan and weld a return line fitting on the side. I feel that returning the oil back to the pan (just above the oil lever) is best.
Looking for opinions about feed and return lines for external oil filters.
