1 - 11 of 11 Posts
I'd like to know if adding an extra leaf spring on my 99 Dodge Ram 1500 4x4 5.2l ext cab long bed. How much more can I tow/haul? Exc
Helpful to mention if tow setup is, or will be for new/bigger trailer; 5th wheel, goose neck, or bumper/trailing type hitch.
... Might inspect rear springs closely, both of my long cabs with short boxes had broken rr springs.
R.I.P Big Blue
The stiffer add-a-leafs will allow you to put a heavier load on the hitch without squatting, but not as effectively as bags. And being a 1/2 ton with a 5.2, you'll have to really watch how much weight you're dragging around. I don't think I'd try more than 10-12k on a gooseneck, especially with the stock automatic. And you'll have to make sure it's well balanced to keep the extra weight from the newer/bigger trailer off the tongue.
dont bother with a short add a leaf. the good ones are 44inches to 48 long.
Upgrade to a 2500/3500 truck! :D I doubt that the op reads this anyway since his last post was the 15'th of last year.
R.I.P Big Blue
That is the better option lol
1 - 11 of 11 Posts
