My accessory wire on my truck is staying hot when i shut my truck off, it reads about 10 volts, its causing my cdplayer to stay on after i shut the truck off. I have allready replaced the ignition switch, and no success. I noticed that when i pull my turn signal fuse, that the voltage drops off. But when you unplug the multiunit from the steering column, the voltage stays, everything works fine in my truck other then this, hasn't caused any other problems. Has anyone else had this problem or ever heard of anything like this?
