my abs and brake light keep coming on? the brake fluid is full and my brakes work fine can anyone help ???
svandergrifft said:I had the same problem.
Drop the $45 for the rear speed sensor. I had to go to the dealer for it, but they had it in stock. Takes about 20 minutes to replace (be careful not to break the guard off when removing)
You may also get an engine light after you replace it. Just unhook the battery and let sit for about 5 mins and then reconnect the battery (NEG terminal first) and that should reset everything.
