1 - 3 of 3 Posts
can u stack aals ??? and can u add an aal to a new spring pack that already lifts the truck like the 6" skyjacker pack?
I disgaree...:)
Stacking is not recommended. Adding a certain height AAL to a lifted pack would probably not produce much additional lift out of it, although I have never tried.
The aal are meant for flatter stock springs so when they are added they give a little more arch. If you already have 6" springs the arch would be greater than stock so the only amount of lift you would get out of it is the thickness of the aal.
1 - 3 of 3 Posts
