1 - 7 of 7 Posts
I have a 2006 Ram 1500 with the 4.7L V8, over the past month or two I've started experiencing a strange problem that seems to come and go:
My most common drive is to work, it's about an hour. After about 30 minutes of driving, typically after stopping at a red light the engine will start to judder like the fuel is being restricted (this normally happens while still at the stop idling) when the light goes green and I try to pull away the engine hesitates big time and I can either ride it out (usually takes about 20-30 seconds) or floor the gas a couple of times to get things back to normal again. Sometimes, the check engine light will flash on and off until the episode is over and very rarely a DTC, P0ABC, will be thrown.
I have a scangauge II in my vehicle, when this problem occurs you can see the short term and long term fuel trims for bank one both max out at -33%. Occasionally, bank two will join in the fun although not as heavily.
I've also monitored the O2 sensor voltages during these episodes, both the pre and post-cat sensors for bank one stick at a 1.27v signal, which explains the extreme lean response from the PCM.
As I mentioned, it's usually initiated after stopping and idling the engine, for example at a stop light. Sometimes it will occur during cruise at highway speeds.
Does anyone have any ideas?
Thanks in advance,
Russ.
All Around Great Guy
dealer may need to flash the computer
Finally tied this problem down to a damaged oxygen sensor bias feed wire on bank one. I cut the cracked section out of the harness wire and rejoined the two ends. Looks like vibration was causing intermittent breaks.
I finally worked this out when the truck wouldn't come out of open loop.
good job. what is oxyhydrogen injection anyway?
Basically, it's splitting water (H2O) into hydrogen and oxygen and injecting it into the inlet manifold. It increases the burn speed of the gasoline, increasing thermal efficiency.
cool. how are you coming along with it? are you experimenting on the ram?
So far, I've been working on increasing the output of the oxyhydrogen generator without overloading the alternator. I'm pumping about 4.5 litres a minute of the gas right now and the engine has smoothed out a lot and gained in power too.
I'm running through a full tank of gas right now to see what happens with the MPG, my next step will be tuning the outputs from the O2, MAP & IAT sensors to find the right A/F settings. I want to work with ignition timing too, but I doubt I'll find a tool that will allow me to do that.
1 - 7 of 7 Posts
