I am hoping to pick up a 2000 dodge ram, 6sp, ctd, 134k miles.
1) The tranny grinds a little between 5/6 gear, can I just double clutch it or do I need to try and find some synchros?
2) Will a set of 285/75r16 fit on a stock 2wd dodge?
3) When I test drove it, one of the rear brake lines burst. They are suppose to be getting that taken care of this week. This was a Massachusetts truck for 7 years. The frame looked solid from what I can see. Is this brake failure something I should be worried about? I imagine the lines just cracked because they were old, however I wonder if it is an indication of other things to come?
I am getting a good deal on it (10500), the interrior is GREAT. there is some rust on the bottom of the doors but you can not see it from the outside, however I think I can either fix it, or just buy a new set and get the truck repained since there are a few scratches. The engine pulled great, and it shifts perfect minus the 5th and 6th grind.
Overall opinions?
Overall opinions?
