Is there anything for my 06 5.7 in the 9r13 update? Also I assume that I need to restore my factory tune first, then update my programmer then install the new tune in the truck correct?
Two more questions: I installed my original backup and it said something like restore quick adjust failed, so I went back and checked and my tire height is the same as before so does that just mean that it did not change any of those things while going back to stock?
Also when I looked at last tune written it said 93 perf with quick adjust, shouldn't it say original back up?
Sound's like the tune load failed. Try resetting the quick adjust back to it's stock setting. If that goes ok, then go back and reload the original back up. Do Not update the tool until the last tune written say's original back up.
Thanks guys, I believe that is indeed what happened. All is well now, I did notice a slight difference with the throttle booster, and this update has more tranny adjustment too.
Another question, If I were to update the 93 tune that I am currently running, can I change parameters on the tune and install it without going back to the backup tune?
