ok this van is giving me headaches with the electrical issues.
but need input on this issue.
van wont start. no click no nothing. new batt, alt, everything comes on but when turned to start nothing. not even a click.
was able to ark the starter to drive home so not the starter.
im thinking ecu. heres why.
power wire to tcu died had to run new tcu power wire.
dash gauges randomly die. yes i did the solder the solder joints in cluster board. redid both inside and engine grounding straps.
voltage regulator in ecu went out had to install a external voltage regulator.
so before i go and spend a ton of money on a ecu. you guys have any ideas.
the engine and tranny run perfect. mechanically this van is sound. its just the damn electrical
