1 - 6 of 6 Posts
Recently purchased a 99 Durango 5.2L. Most of my driving consists of 5 miles or less so it rarely has a chance to really warm up. On two occassions of driving 20 miles or so, the D stalled. Engine cranks full speed, but have not checked for fire at the plugs. Car must sit for 30-45 minutes before it will start. On a third occassion I parked after a 20-mile drive and the car would not restart immediately - had to wait 45 minutes. After cranking for 10-15 seconds I get a Check Engine message with what appears to b a 'No Bus' code. Any suggestions?
Thanks for any help.
Keystoner
usually it's the IAC that needs to be cleaned, but the no bus points to your PCM.
pcm
I had a similar problem last year with my 99. Ended up being the PCM, just like "rockadaous" said. It was under 80,000 miles, so the dealer replaced it for free (some EPA law requires the dealer to warranty up to 80K).
Sko
unRegistered Dog
Check the connections at the PCM they might not be plugged in all the way. Disconnect them and then reconnect them.
Thanks - turned out to be PCM
Thanks for the help. Took the least expensive route and replaced IAC - no help. Replaced PCM and problem resolved.
Spent a lot of time lately on this forum and I think I'm prepared for just abut anything that might happen now. I'm an old-timer with lots of experience re-building 50's thru 70's engines and the electronics on the 'd' kind of had me buffaloed for a while. Thanks, again.
I am having this same problem and got a quote from Dodge for over $900 (parts/labor) to fix the problem. I brought my 99 Durango back home and figured I would find and install my own PCM. When I saw the mention of the 80k miles I quickly went in the garage to look at the odometer. I have 80724 miles on it. I wanted to cry!!!
1 - 6 of 6 Posts
