1 - 6 of 6 Posts
Hi,
I have a 98 Ram 1500 4x4 5.2L automatic with 150,000 miles. It has 2 issues. Im not sure if they are related.
1) The truck literally "bucks" sometimes when accelerating through 45 mph ?? Once I hit 50-55mph no issues.
2) Following cold starts in the morning the motor runs rough, hesitates/sputters abit. After driving a few minutes, engine smoothes out.
Any advice on how to correct these issues would be much appreciated.
Thanks,
Ken
Do a tune up(cap/rotor plugs wires) wouldn't hurt to clean the throttle body either. Was your plenum replaced?
have a 98 1500 with 227000 on it does the same dumped in some seafoam in the tank pulled off the air cleaner scrubbed with two plus two was ok after you could try that also
Discussion Starter #5
I replaced distributor cap/rotor, plugs, and wires and that seems to have stopped the issue. So thank you Moparite. I found that getting to the distributor cap was a real PITA even with taking the air box off. Very hard to see anything back in there.
thanks,
Ken
OH YAH! joint the crowd!
1 - 6 of 6 Posts
