Hi All,
New guy here. :)
I have a 98 Ram Sport 1500, 360 with auto trans. Last winter the 4 wheel drive started acting up. Wouldn't go into 4x4 all of the time and sometimes would pop out. I checked the system out as best I could and found that the vacuum lines that hooked to the vacuum canister on the 4x4 actuator were rusted. The truck sat all summer unused. Today I put on a new/used actuator that I know is good. Took it off of my parts truck which I just drove in 4x4 a week or so ago and the 4x4 worked good. Now I have no 4x4 at all on my driver.
I have not yet tested anything, have a few questions first.
1) If I have the tcase in 4x4, should there be constant vacuum at the actuator? If so, how much?
2) What is the first thing I should check? I did visually look at the lines and all look well; no lines appear to be broken or unhooked.
3) If I have the tcase engaged, the front driveshaft should not turn, correct? The shaft should be solid, since the tcase is physically engaged?
Ok, Thanks in advance. I'm going to go and do some poking around and see if I can find anything obvious.
Hope you all had a great Thanksgiving weekend!
John
proud owner
I'll try my best to answer your questions.
First, the vacuum system is garbage. I bought a posilok system in eBay for less than $200 and it hasn't failed me since. There's a possibility that the switch in the top of the t-case is bad but not very likely.
I'm pretty sure there should be constant vacuum at the actuator to hold the fork in place engaging the front axle (but I could be wrong). Those plastic lines crack easily so you could have a leak or the metal lines they connect to could also be rusted causing a leak.
As for the drive shaft, (again I may be mistaken but I'm trying to do what I can to help) but yes, it should be locked and not free spinning.
Have you tried rolling forward and back after engaging the t-case? I have to roll slightly forward while engaging the posi lok bc of the tight fit of the collar that engages the axle. I then have to put the truck in reverse to get the pressure off the collar to get it to disengage fully. Are you feeling anything when you engage the t-case?
Sent from my iPad using Tapatalk
Check the vac at the cad, One line is for disengage and the other for engage. Without good vac the cad won't work.
Discussion Starter #4
Thanks for the replies. So, I think I have some vacuum issues. It looks like there is just one vacuum port on the intake manifold. It seems to power the cruise control, the switch that changes air flow in the heater( from defrost to floor to vent airflow.
Right at the intake manifold, there was a "T" in the vacuum line. One side went to the transfer case, the other went to the vacuum canister on the cruise control, which doesn't work. The line was broken, which may have been why the cruise didn't work. I figured that since the vacuum line going there was broken, that it was a therefore a vacuum leak. I removed the T and hooked the line that goes to the transfer case direct to the intake manifold.
I took the truck for a ride, and the four wheel drive did engage for me, but was intermittent. When I would step hard on the accelerator, it would disengage.
There are four vacuum lines that go to the switch on the transfer case. One goes direct to the intake manifold. Two go to the 4x4 actuator on the front axle. The last one looks like it goes to another T that goes into the firewall. I think this is the line that powers the air control under the dash? I unhooked this one and there was no vacuum there.
Does anyone know how much vacuum there should be at the actuator?
Same as you would have at any of the other places. If your check valves are bad they wont hold the vac. Its located on the passenger side of the intake manifold. Trace the vac line and check the vac at different points down to the cad. The metal lines on the frame have been known to rust up so check them.
Discussion Starter #6
For the time being, I just hooked a vacuum line right from the manifold to the vacuum cannister on the actuator. 4x4 works that way when I shift the transfer case. I have a new set of vacuum lines, but can't quite figure out how to change them. There is the vacuum pug with the 4 lines in it that is near the 4x4 shifter. That I can unplug. Then the lines go to something on the top of the transfer case on the passenger side. It feels like they go into a plug or something. I can't see it and when I put my hand there, I can't feel any way that it can come off. Not quite sure which way to turn now. I tried looking up diagrams of the vacuum lines, but can't find anything that shows this plug thing on the passenger side?
proud owner
I have a manual, let me see what I can find for you. But honestly, these trucks have a horrible time with vacuum and it feels like you're chasing your tail trying to diagnose and fix the vacuum issues.
proud owner
Let me know if this helps, if not I'll keep looking to find a better diagram, but more or less the 4 way plug (vacuum control switch) I believe is on top of the transfer case?
