Hi you all back again new question. :VHOT: First i had a missing problem in my 98 Durango so i replaced my plugs and wires and that fixed the problem every thing was fine until 2 weeks ago when my Durango won't turn over on the first crank which i have never had problem with ever so i will crank it a 2nd time it cranks and right at the end of the cranking it sounds like it's not going to start but it dose weird so i replaced my distributor cap,rotor and coil which i should have done when i replaced the plugs and wires o well but after i installed the parts and when i try ed starting it it didn't make any deference at all i was not 2 mad because i need to replace them parts any way now here is were you guys come in what is the most likely problem my dad said i might have to re set my distributor timing I am not sure if thats it or not what you all think holla back. Thanks for your time ~Got Dodge?
