I have a 98 b1500 van that has no spark. I have replaced the wires plugs cap rotor dist. magn pickup crank sensor and coil and still no spark the van is a V6 3.9L and I am lost can someone help
Gone but not forgotten
1) Try switching the ASD relay with the AC or Fuel Pump relay in the PDC.
2) Check that the coil is getting power while trying to start the engine. You can also check the Dark Green/Orange strip wire from one of the injectors if that would be easier. This wire powers the coil, injectors, O2 Sensors.
