You don't say what type of tranny you have, but if you have an auto with OD, then first of all, if your #8 cylinder, or any cylinder for that matter, is misfiring you will immediately know as soon as the tranny shifts into overdrive. The truck will bounce up and down. The "bounce" factor by the way gets worse with bigger tires. Hi speed + low rpms will bring out the worst in an engine. You say the truck surges between 40 and 45mph? I'm assuming with the cruise on? I think that's normal, but if you think it's too much, try changing your TPS--the little electronic device on the driver's side of the throttle body. The throttle positioning sensor senses the position of the throttle and feeds it to the ECM. If the ECM is not getting the right info from the position of the throttle, the ECM will in turn try to adjust for it. Hence the "surge". And if you're getting 11mpg pulling a trailer, consider yourself lucky. One of my buddies got 10 pulling a snowmobile trailer up in WI
abe
