i have recently begun to have trouble in my 97 intrepid(3.5L automatic, with autostick). yesterday, i noticed that when i came to a stop sign, it downshifted kind of rough(thunk), and when i took off, i lost high gear. my car starts off just fine in low, then second, then when it is supposed to shift into high gear, it seems like you have just put it into neutral and the engine revs without any pull. when you slow down, it goes back into second gear until it is time to shift to high and then start all over again. check engine light came on and i got three codes. they are p0733(gear 3 ratio incorrect), p0715 turbine speed sensor) and finally p0700(transmission control system malfunction). was told the po715 was a speed sensor and as a result, replaced both of the speed sensors on the side of the tranny. still no luck in changing the problem. any / all help would be greatly appreciated.
aspecialties
