My Dodge Ram 1500 5.9 has been stalling out. Stalls when driving down the road or just idling. I have put a new IAC in it last week. Still stalls out. And the RPMs are low. Any suggestions? Thanks.
Idle rpm low??
... Dodges are darn fussy about having a near perfect battery and charging system (or can have various weird running/stalling issues).
... Check for codes, key dance works for 97
http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
Thank you! I threw two coded 12 and 32. A friend told me that it could be the Map Sensor? And that even tho I put a new TPS on it back in early summer, it could have gone bad?
Would start by dealing with the codes.
12: if batt was not disconnected in the last 50 key cycles, checkkkkkkkk
32: FAIK last EGR was mid 96; could check your trucks build date (IDK date range).
... Does your 97 have an EGR valve?
