1 - 2 of 2 Posts
CWR
Can High Jacker air shocks be installed on the rear of this van? Someone told me that if my van has abs brakes the shocks wont work is this true? Thanks everyone.
What do you plan to use them for, load leveling, or just jacking up the rear end way up there?
If its the latter you should have no problem.
If jacking up the rear end with no load, you may have problems with the porportioning valve providing your van is equiped with 4 wheel disk brakes and 4 wheel ABS, if not who ever told you that line is only half right.
Cheers
Chet.
1 - 2 of 2 Posts
