Hi, Been having problems with my caravan. Prior to it not starting the van was hesitating. I'd see the RPM's drop 500 to a grand quite often. Had the computer scanned and the error code was the O2 sensor. Removed the intake manifold, replaced the O2 and did a tune up. plugs, wires. Drove 10 miles with the same problem but getting worst to a point that the van became very hard to start to not starting any more. Since I've replaced the fuel filter, fuel pump in the tank and the ignition module. Still will not run. No error codes from the engine when I turn the key on 3X quickly. just a 1,2 and 5,5 code. What am I missing on this. The engine does crank as it did before this all happened. Tranny replaced in July 2007.
JLEWIS44047
JLEWIS44047
