I tried searching this but didn't see anything. I switched out my halogens to LEDs. Now they flicker a lot on low beam and intermittently on high beam. Checked all the grounds and connections, all were good. I gave up and finally bought another set but different brand. The first set I pulled out and put in my 05 Xterra and they worked fine. Put the new second set in the Dakota and they flicker as bad if not worse than the first set. I also have LEDs in my 02 Ram and 03 Civic with no problems. Anybody been across this and have any suggestions.
