a little back ground--had to replace timing cover as gasket was leaking :frown--all was well no squeaks--then replacing water pump broke bolt and had to remove timing cover as i couldn't get to it while on engine--put back and all was well until it rained--went through some water and developed a squeak--have changed tensioner and idler pulley--have also changed out power steering pump--did find out alternator was loose after belt was chewed up :nono but still have noise--video shows some wobble in harmonic balancer and i had read a post from a few years ago someone had replaced and no noise but would like to get fresh opinions.
