1 - 2 of 2 Posts
Hey so i have a 1996 ram 1500 and i just swapped the motor out because i blew the other one up and ended up puttin a fresh tranny in it. I have replaced 3 injectors because they were leaking and i burnt the radiator out of it so i put a new one in. Has a nee fuel pumP. The truck starts and idles fine but the problem is, when i drive it atleast 15 minutes, when i put it out of gear (put it in park or neutral) the engine revs at 1400rpm. It satys there until it cools down for a while and when you start it back up it idles fine again and repeats itself all over again. Please help, thanks
sounds to me like a vac leak. check the hoses. hope its not the intake mani. theres tests for that!
1 - 2 of 2 Posts
